[HELP] Maya navigation style
Re: [HELP] Maya navigation style
You are right, I did it on a GitHub branch pablogil-maya.
Do I need to post it again anywhere?
Thanks again
Thanks again
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Yes, the standard procedure is to make a request here: viewforum.php?f=17
Hehehe, I figured it out, I was reading and trying to do it =)wmayer wrote:Yes, the standard procedure is to make a request here: viewforum.php?f=17
Thank again
Are there chances to see maya navigation style in FreeCAD? Pull was archived without merge so it means "no" right?
It's in Master. Right Click on some empty area of the 3D View choose Navigation Styles it should be in the Dropdown menu.Eneen wrote:Are there chances to see maya navigation style in FreeCAD?
My version but it's been there for quite a while.
OS: Windows 7
Version: 0.16.6337 (Git)
Hash: c6740162bc9f8cef2b1acf22e5fc8c8772aae610
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
"fight the good fight"
I was using 0.15 stable, now installed 0.16 pre and there it is. Thank you!
Maybe there are chances for 3dsmax navigation style too where MMB pans and Alt+MMB rotates and AutoCAD/ArchiCAD/Revit style where Shift+MMB rotates? Both are standard in architectural design IHMO.
Best regards.
Best regards.
I'm bumping that thread with little OT for 3dsmax navigation style. Any chances to include this also?
You might want to describe the desired behavior...Eneen wrote:Any chances to include this also?
