Porting to python3
looo
Re: Porting to python3
Post by looo »
PR submitted :)
thanks for your efforts. This went straight into master.
Most test are working now. Only two path-specific tests are not working (some import errors). But I think we can fix this directly in master.
So what is next? There are for sure some python3 incompatibilities remaining. But it's quite difficult to find them. Some testing would be nice.
I will try to upload a build of the current state of the python3 branch to anaconda, so everybody on linux can test the branch.
looo
Post by looo »
found a little problem. with python3 this will lead to a endless loop:
doc = FreeCAD.newDocument()
ellipse = doc.addObject("Part::Ellipse","Ellipse")
ellipse.MajorRadius = 0.5
ellipse.MinorRadius = 0.0
With python2 I get this exception:
Cannot compute Inventor representation for the shape
Founder
Post by wmayer »
Doesn't seem to be Python3 specific. On Windows with Python2 I get the exception in Debug mode, but in Release mode the program freezes.
looo
Post by looo »
strange I get the exception with release + python2 (ubuntu-daily) but freeze with debug + python3.
Founder
Post by wmayer »
Anyway, an ellipse with a null radius is invalid and should be explicitly handled as error. See git commit 1afa150
looo
Post by looo »
Thanks. There are also other bugs with the draft workbench. It's quite difficult to distinguish between python3 problems and problems from current master...
Another problem with python3 is a random order of the tracker-symbols.
looo
Post by looo »
The Snapping tool uses dicts. This dicts are somehow ordered with python2 (at least the elements are always at the same position) For python3 the order is random. But changing the dicts to collections.OrderedDicts solves this issue.
https://github.com/looooo/FreeCAD/commi ... 69fe181353
Founder
Post by wmayer »
Does this cause any problems? My experience with Python dicts is that the order is undefined which was surprising me at the beginning because the counterpart in C++ is a map and there it's always sorted by the key.
looo
Post by looo »
http://stackoverflow.com/questions/1495 ... in-python3
Python has never guaranteed iteration order of keys in a dict or set
HASH RANDOMIZATION IS DISABLED BY DEFAULT.
which was changed for python 3.3 regarding this link.
So we shouldn't rely on the ordered dicts in python2. As it's not good to randomly order the draft-tracker/snap-symbols (python3) I think it's best to use the collections.OrderedDicts. https://docs.python.org/2/library/colle ... rderedDict
yorik
Founder
Post by yorik »
wmayer wrote:Does this cause any problems? My experience with Python dicts is that the order is undefined
Yes that's what I believed too... Certainly in Draft I never relied on the order of dict elements I think.
