Porting to python3
Re: Porting to python3
thanks for the testing. There are still many problems with the branch. But most of them shouldn't be that difficult. The only show-stopper at the moment is the problem with extensions. Hopefully this will be solved soon.
My plan is to slowly move all the commits into master. First all the modules and then the difficult things. it's a long way: https://github.com/looooo/FreeCAD/issues/8
@wmayer should this function call the getCustomAttributes of ExtensionContainer.cpp?
in the header file (ExtensionContainerPy.h) there is a definition of this function, but not in the cpp file (ExtensionContainerPy.cpp).
So what function is called.
ps.: Looking at the ExtensionContainerPyImp.cpp the getCustomAttributes function is implemented. So this means that the generators are failing here. So again a problem with generators.
ps.: the function is taken from the ExtensionContainerPyImp.cpp... But it is never called. This is strange.
PyObject *ExtensionContainerPy::_getattro(PyObject *attro) // __getattr__ function: note only need to handle new state
char *attr;
#if PY_MAJOR_VERSION >= 3
attr = PyUnicode_AsUTF8(attro);
#else
attr = PyString_AsString(attro);
#endif
try {
// getter method for special Attributes (e.g. dynamic ones)
printf("before getCustomAttributes");
PyObject *r = getCustomAttributes(attr);
printf("after getCustomAttributes");
if(r) return r;
this is too difficult.
Can anybody confirm this with master-branch:
It seems I am testing stuff not really working in master-branch
import sys
sys.path.append("/usr/lib/freecad/lib")
import FreeCAD as App
Doc = App.newDocument()
BodySource = Doc.addObject('PartDesign::Body','Body')
Sketch = Doc.addObject('Sketcher::SketchObject','Sketch')
BodySource.addObject(Sketch)
AttributeError: 'Part.Feature' object has no attribute 'addObject'
- kkremitzki
I just compiled master and that worked for me...
Also as a python script? It does work for me in the freecad gui. But not when running it as a exzternal script.
found the problem:
1: PyObjectBase.cpp L135 __getattro is connected to tp_getattro
2: PyObjectBase.cpp L152 _getattro is called
3: (template) BodyPy.cpp here starts the implementation of _getattro
4: (template) BodyPy.cpp this line was changed for the python3 branch (PyFindMethod->PyObject_GenericGetAttr) and GenericGetAttr finds something so the father in line 785 is never called. Thats why the inheritance tree is not moved upwards and the _getattro of ExtensionContainerPy.cpp is never called.
So there is a difference between PyFindMethod and PyObject_GenericGetAttro.
Yes, there is definitely a different behaviour. When using Py_FindMethod you pass an array of methods and the name and it returns a valid pointer if a method of this name is in the array.So there is a difference between PyFindMethod and PyObject_GenericGetAttro.
However, PyObject_GenericGetAttro doesn't just look for method names but arbitrary attributes. But I wonder why does it find "addObject" and the system still raises an error that this attribute doesn't exist. Hmm, I think it's time to update my Python3 test environment.
https://docs.python.org/3.5/c-api/object.html
maybe this allready looks in the father class for an object called addObject. when you look at the attributes in mro you will also find a parent class.PyObject_GenericGetAttr...It looks for a descriptor in the dictionary of classes in the object’s MRO
type(BodySource).__mro__
>>> (<type 'PartDesign.Body'>, <type 'Part.BodyBase'>, <type 'Part.Feature'>, <type 'App.DocumentObject'>, <type 'App.ExtensionContainer'>, <type 'App.PropertyContainer'>, <type 'Base.Persistence'>, <type 'Base.BaseClass'>, <type 'PyObjectBase'>, <type 'object'>)
A solution could be to make the new implementation work the same as the PyFind method which only looked for function defined within the class. Only an idea:
PyObject *rvalue = PyObject_GenericGetAttr(this, attro);
if (rvalue != NULL)
for (PyMethodDef method: this->Methods)
if (method.ml_meth == reinterpret_cast<PyCFunctionObject*>(rvalue))
return rvalue;
PyErr_Clear();
return @self.export.Father@::_getattro(attro);
finally a working code. With this the part-design-gui tests are passing.
https://github.com/looooo/FreeCAD/commi ... 8bdcf7d4bc
