Porting to python3
Re: Porting to python3
(This is not meant to hijack the thread.)
Quick question: there is an open ticket on the tracker issue #995 named "Python3 compatibility" assigned to @yorik which is not tracking this thread of development. Please advise.
I compiled the py3-21 and reverted this change to see what has happened.looo wrote:finally a working code. With this the part-design-gui tests are passing.
https://github.com/looooo/FreeCAD/commi ... 8bdcf7d4bc
When running this snippet
doc=App.newDocument()
body=doc.addObject("PartDesign::Body","Body")
body.addObject
In your fix you do this:
which won't work because you must not compare C strings with "==".
Instead you should do:
which is also faster.
for (unsigned int i=0; i< sizeof(this->Methods); i++)
PyMethodDef* meth = & Methods[i];
if (Methods[i].ml_name == attr)
return PyCFunction_New(meth, this);
PyMethodDef *ml = Methods;
for (; ml->ml_name != NULL; ml++) {
if (name[0] == ml->ml_name[0] &&
strcmp(name+1, ml->ml_name+1) == 0)
return PyCFunction_New(ml, self);
Thanks for looking at this.wmayer wrote:it goes through PartDesign::BodyPy::_getattro where PyObject_GenericGetAttr then of course finds "addObject" since we added it to the type object. It then immediately returns to the calling instance __getattro which inspects the PyCFunction and raises an error because no object is bound to it.
So this means we can also use the PyObject_GenericGetAttr and bind the object to the function?
The fix I have pushed to the branch introduce some problems with fem-tests. This one is really difficult, because it only happens when I run TestApp.All. Running only the fem-tests is not leading to a crash and fem tests are succeeding.
I don't know if this trace-back is useful, but it shows the crash is definetly coupled to the _getattro function:
#0 0x00007fff6cbf3f50 in Fem::FemMeshPy::_getattro (this=0x83db4d0, attro=0x7fffb25f2960) from ~/anaconda/envs/fc_py3/lib/Fem.so
#1 0x00007ffff5fa9fea in Base::PyObjectBase::__getattro (obj=0x83db4d8, attro=0x7fffb25f2960) from ~/anaconda/envs/fc_py3/bin/../lib/libFreeCADBase.so
#2 0x00007ffff5a6e9bb in PyEval_EvalFrameEx (f=f@entry=0x8434548, throwflag=throwflag@entry=0) at Python/ceval.c:2758
#3 0x00007ffff5a71a70 in fast_function (nk=<optimized out>, na=<optimized out>, n=1, pp_stack=0x7fffffff9fb0, func=<optimized out>) at Python/ceval.c:4818
#4 call_function (oparg=<optimized out>, pp_stack=0x7fffffff9fb0) at Python/ceval.c:4745
#5 PyEval_EvalFrameEx (f=f@entry=0x7fff421e1408, throwflag=throwflag@entry=0) at Python/ceval.c:3251
#6 0x00007ffff5a71a70 in fast_function (nk=<optimized out>, na=<optimized out>, n=1, pp_stack=0x7fffffffa130, func=<optimized out>) at Python/ceval.c:4818
#7 call_function (oparg=<optimized out>, pp_stack=0x7fffffffa130) at Python/ceval.c:4745
#8 PyEval_EvalFrameEx (f=f@entry=0x6d78048, throwflag=throwflag@entry=0) at Python/ceval.c:3251
#9 0x00007ffff5a74036 in _PyEval_EvalCodeWithName (_co=0x7fffbcbe2d20, globals=<optimized out>, locals=locals@entry=0x0, args=args@entry=0x7fff6c010060, argcount=2, kws=kws@entry=0x7ffff7fb4060,
kwcount=kwcount@entry=0, defs=defs@entry=0x7fffbcbc1220, defcount=defcount@entry=1, kwdefs=kwdefs@entry=0x0, closure=closure@entry=0x0, name=name@entry=0x0, qualname=qualname@entry=0x0)
at Python/ceval.c:4033
No, because the binding of the object can only be done in ExtensionContainerPy::getCustomAttributes.So this means we can also use the PyObject_GenericGetAttr and bind the object to the function?
thanks for the explanation.
maybe some day I will understand it. c++ is quite complex.
Now nearly all tests are passing. One more difficult is remaining:
anybody volunteering?
and also the Path workbench has many small python3-incompatibilities. and many more easy ones:dynamic module does not define module export function (PyInit_ReverseEngineering)
File "Mod/Path/PathScripts/PathDressupDogbone.py", line 954
print i.Group
SyntaxError: Missing parentheses in call to 'print'
File "Mod/Path/PathScripts/example_post.py", line 45
print "This script is unable to write more than one Path object"
File "Mod/Arch/import3DS.py", line 109
print "Skipping object without vertices array: ",d_nobj.obj
File "Mod/Path/PathScripts/PathCompoundExtended.py", line 60
print 'check order'
File "Mod/Path/PathScripts/PathPostProcessor.py", line 38
exec "import %s as current_post" % postname
SyntaxError: Missing parentheses in call to 'exec'
File "Mod/Path/PathScripts/PathKurveUtils.py", line 145
print "in profile: 151"
File "Mod/Path/PathScripts/centroid_post.py", line 88
print "No machine found in this selection"
File "Mod/Path/PathScripts/opensbp_post.py", line 84
print s
File "Mod/Path/PathScripts/dumper_post.py", line 55
print "the object " + obj.Name + " is not a path. Please select only path and Compounds."
File "Mod/Path/PathScripts/opensbp_pre.py", line 84
print "preprocessing..."
File "Mod/Fem/FemMesh2Mesh.py", line 134
print 'found a last Face: ', faceCodeList[actFaceIdx]
File "Mod/Path/PathScripts/PathPost.py", line 193
print "in activated %s" %(selected)
SyntaxError: invalid syntax
File "Mod/Path/PathScripts/linuxcnc_post.py", line 121
File "Mod/Path/PathScripts/generic_post.py", line 288
File "Mod/Arch/Dice3DS/dom3ds.py", line 297
except (File3dsFormatError, FBufError), fe:
File "Mod/Path/PathScripts/PathPocket.py", line 157
print "this base is: " + str(baselist)
File "Mod/Arch/importIFC.py", line 625
print "failed to compute placement ",
File "Mod/Arch/importSH3D.py", line 123
if DEBUG: print "Creating wall: ",name
File "Mod/Path/PathScripts/PathToolLibraryManager.py", line 257
except Exception, e:
File "Mod/Path/PathScripts/PathUtils.py", line 623
print form.cboProject.currentText()
File "Mod/Path/PathScripts/PathSurface.py", line 148
print " loop ", nloop, " with ", len(loop), " points"
File "Mod/Path/PathScripts/PathSanity.py", line 53
print "Checking: " + item.Label
File "Mod/Path/PathScripts/PathDressupDragknife.py", line 454
print i.Group
File "Mod/Fem/FemToolsZ88.py", line 104
print z88_std_location
File "Mod/Path/PathScripts/PathDrilling.py", line 307
print baselist
File "Mod/Path/PathScripts/PathDressup.py", line 93
print i.Group
File "Mod/Fem/importZ88Mesh.py", line 389
print elem_length
File "Mod/Spreadsheet/importXLSX.py", line 370
print 'process Strings: '
File "Mod/Path/PathScripts/PathMillFace.py", line 214
print "in execute"
File "Mod/Path/PathScripts/dynapath_post.py", line 117
File "Mod/Path/PathScripts/PathLog.py", line 85
def _log(level, (module, line, func), msg):
File "Mod/Material/MaterialEditor.py", line 251
print "DrawingPatterns not found"
I saw a link basic c++ i wan't to do it eighter https://developers.google.com/edu/c++/looo wrote:thanks for the explanation.
In https://github.com/looooo/FreeCAD/blob/ ... g.cpp#L748 replacedynamic module does not define module export function (PyInit_ReverseEngineering)
PyMODINIT_FUNC initReverseEngineering()
PyMOD_INIT_FUNC(ReverseEngineering)
- kkremitzki
I adapted Bernd's script, tested on Ubuntu 16.04, to build FreeCAD 0.17 + OCCT 7.0.0 + VTK 7.0.0 + Netgen 5.3.1 + libMED, from here, and added the compile instructions from this thread. The script, available here:
https://gist.github.com/kkremitzki/324f ... cad_all-sh
compiles and installs from the py3-21 branch in looooo's FreeCAD repo against Python 3.5.
Hopefully this can make it easier for other people to test the Python 3 port. Let me know if anyone has any feedback!
- kkremitzki
PR submittedlooo wrote: and also the Path workbench has many small python3-incompatibilities. and many more easy ones:anybody volunteering?Code: Select all
File "Mod/Path/PathScripts/PathDressupDogbone.py", line 954 print i.Group ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/example_post.py", line 45 print "This script is unable to write more than one Path object" ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Arch/import3DS.py", line 109 print "Skipping object without vertices array: ",d_nobj.obj ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathCompoundExtended.py", line 60 print 'check order' ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathPostProcessor.py", line 38 exec "import %s as current_post" % postname ^ SyntaxError: Missing parentheses in call to 'exec' File "Mod/Path/PathScripts/PathKurveUtils.py", line 145 print "in profile: 151" ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/centroid_post.py", line 88 print "No machine found in this selection" ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/opensbp_post.py", line 84 print s ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/dumper_post.py", line 55 print "the object " + obj.Name + " is not a path. Please select only path and Compounds." ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/opensbp_pre.py", line 84 print "preprocessing..." ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Fem/FemMesh2Mesh.py", line 134 print 'found a last Face: ', faceCodeList[actFaceIdx] ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathPost.py", line 193 print "in activated %s" %(selected) ^ SyntaxError: invalid syntax File "Mod/Path/PathScripts/linuxcnc_post.py", line 121 print "the object " + obj.Name + " is not a path. Please select only path and Compounds." ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/generic_post.py", line 288 print "the object " + obj.Name + " is not a path. Please select only path and Compounds." ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Arch/Dice3DS/dom3ds.py", line 297 except (File3dsFormatError, FBufError), fe: ^ SyntaxError: invalid syntax File "Mod/Path/PathScripts/PathPocket.py", line 157 print "this base is: " + str(baselist) ^ SyntaxError: invalid syntax File "Mod/Arch/importIFC.py", line 625 print "failed to compute placement ", ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Arch/importSH3D.py", line 123 if DEBUG: print "Creating wall: ",name ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathToolLibraryManager.py", line 257 except Exception, e: ^ SyntaxError: invalid syntax File "Mod/Path/PathScripts/PathUtils.py", line 623 print form.cboProject.currentText() ^ SyntaxError: invalid syntax File "Mod/Path/PathScripts/PathSurface.py", line 148 print " loop ", nloop, " with ", len(loop), " points" ^ SyntaxError: invalid syntax File "Mod/Path/PathScripts/PathSanity.py", line 53 print "Checking: " + item.Label ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathDressupDragknife.py", line 454 print i.Group ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Fem/FemToolsZ88.py", line 104 print z88_std_location ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathDrilling.py", line 307 print baselist ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathDressup.py", line 93 print i.Group ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Fem/importZ88Mesh.py", line 389 print elem_length ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Spreadsheet/importXLSX.py", line 370 print 'process Strings: ' ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathMillFace.py", line 214 print "in execute" ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/dynapath_post.py", line 117 print "the object " + obj.Name + " is not a path. Please select only path and Compounds." ^ SyntaxError: Missing parentheses in call to 'print' File "Mod/Path/PathScripts/PathLog.py", line 85 def _log(level, (module, line, func), msg): ^ SyntaxError: invalid syntax File "Mod/Material/MaterialEditor.py", line 251 print "DrawingPatterns not found" ^ SyntaxError: Missing parentheses in call to 'print'
