I remembered another use case and this solution still misbehaving:
- Add arc (coincident constraint at origin)
- Add radius constraint after
- Add coincident constraint between end points and observe the result.
abdullah wrote:This latter case is also interesting (it is like you had a bug detector ).
issue #0002289In any case, feel free to make a different issue, so that I (or you) tag it with the "solver" tag. It is good to have these in a single place...
