appimage
triplus
Re: appimage
Post by triplus »
I made a quick test and created the AppImage on Ubuntu 16.04. I don't detect such issue.
sgrogan
Re: appimage
Post by sgrogan »
NormandC wrote:Last week I tried to build an AppImage of freecad-daily. The AppImage binary is created, but when I launch it I get this error:
triplus wrote:I made a quick test and created the AppImage on Ubuntu 16.04. I don't detect such issue.
Works with no problems for me on Kubuntu 14.04
I uploaded it to https://github.com/FreeCAD/FreeCAD/rele ... g/0.17_pre
I left the old one in case there is a problem.
Anybody got a moment to test?
"fight the good fight"
Re: appimage
Post by NormandC »
sgrogan wrote:Works with no problems for me on Kubuntu 14.04
Thank you both for checking.
What the heck is wrong with my config then. :?
sgrogan wrote:Anybody got a moment to test?
It works here.
Its FreeCAD info:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10600 (Git)
Build type: None
Hash: 4d9169faf778e9716fc647fb3fcf46462b5d99a4
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
triplus
Re: appimage
Post by triplus »
Well there is always a chance you are doing it differently.
Re: appimage
Post by NormandC »
What could I have possibly done differently when all that is required is to copy-paste the two same commands posted here that you and sgrogan have most probably used?
https://forum.freecadweb.org/viewtopic. ... 20#p152068
I used the FreeCAD-nightly recipe.
EDIT: is the path where the AppImage is built important? I built it in a sub-folder 3 levels below my Home folder. There were no special characters in the path. The error message seems to indicate it cannot find the local python path...
Re: appimage
Post by NormandC »
NormandC wrote:EDIT: is the path where the AppImage is built important? I built it in a sub-folder 3 levels below my Home folder.
... And that was it. :roll:
After building a new AppImage directly in $HOME, I can launch the binary.
Thank you triplus for asking the obvious question...
triplus
Re: appimage
Post by triplus »
NormandC wrote:Thank you triplus for asking the obvious question...
You're welcome.
Re: appimage
Post by Kunda1 »
Bug: Clicking on any hyperlink in FC to fire up browser will fail. I can't seem to find where to set the correct path to the browser from within FC.
Running latest appimage FreeCAD-0.17.git201703220057.glibc2.17-x86_64.AppImage
OS: "Manjaro Linux"
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
Error:
Failed to execute default Web Browser.
input/output error
Re: appimage
Post by Kunda1 »
In addition to the above issue, I added a Feature Request issue #2987 so that FC recognizes when it's been built by as an Appimage.
Re: appimage
Post by NormandC »
Kunda1 wrote:Bug: Clicking on any hyperlink in FC to fire up browser will fail
Can't reproduce on Ubuntu 16.04 LTS.
What about a self-compiled FreeCAD? Does it show the same problem?
AFAICT this is a simple html page with href tags.
https://github.com/FreeCAD/FreeCAD/blob ... e.html#L61
Not sure what the "ext" prefix is supposed to do though. Open in an external browser?
Might be related:
http://stackoverflow.com/questions/5116 ... lt-browser
http://askubuntu.com/questions/8252/how ... e-terminal
