Yes likely we should do that at some point. If @probono will read this he can change the .yml file or we can make a pull request with the change at some point in the future. But i guess lets wait for some actual user feedback first.sgrogan wrote:I agree, remove calculix from the AppImage, to avoid confusion, the license is irrelevant.
In the past OCC used GPL incompatible licence. No amount of packaging would resolve that. Luckily OCC licence changed and is now compatible with GPL. Therefore you can mix FreeCAD, OCC and GPL software in a single package.I'm having trouble articulating my opinion. An aggregation is OK as @probono has pointed out.
If you would do that and would want in addition to add some code with GPL incompatible licence in the package then you would likely start caring about aggregation. For example you could add OsiFont licensed under GPL in a bundle with FreeCAD and after add some code in that bundle that is incompatible with GPL licence but doesn't prevent bundling in such way. And that would work as long as you would make it clear OsiFont is basically a standalone solution/package/library at the install time.
