getElement() should returns solids too
bernd
Post by bernd »
The getElement() method only returns Faces, Edges and Vertices. Would it not make sense to return solids too? Attached an example for a CompSolid. The method returns an unknown exception
bernd
doc = App.ActiveDocument
# build a CompSolid out of two boxes
import Part
box_obj1 = doc.addObject('Part::Box', 'Box1')
box_obj2 = doc.addObject('Part::Box', 'Box2')
box_obj2.Placement.Base = (10, 0, 0)
import BOPTools.SplitFeatures
cs = BOPTools.SplitFeatures.makeBooleanFragments(name= 'CompSolid')
cs.Objects = [box_obj1, box_obj2]
cs.Mode = "CompSolid"
for obj in cs.ViewObject.Proxy.claimChildren():
    obj.ViewObject.hide()
doc.recompute()
# test if we have solids
cs.Shape.Solids
# try to get the element 'Solid1'
solid_element = 'Solid1'
ele = cs.Shape.getElement(solid_element)
output:
SystemError: error return without exception set
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.9166 (Git)
Build type: Unknown
Hash: 7a32aed27e5febf94611a3356d4f20b2bc6b6bf3
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
Founder
Re: getElement() should returns solids too
Post by wmayer »
The idea of this function was to handle only shape types with a direct geometrical meaning and these are only vertex, edge and face. All other shape types have a pure topological meaning and one place where this becomes obvious is the view provider and the selection framework. There you can only interact with points, lines and faces but not with wires, shells, solids, ...
bernd
Post by bernd »
Hi Werner,
I assumed you gone write something like this.
wmayer wrote:... and one place where this becomes obvious is the view provider and the selection framework. There you can only interact with points, lines and faces but not with wires, shells, solids, ...
May be that's the real problem we gone face. Try to select a Solid out of the CompSolid. Not a box the solid is made off, but a solid of the CompSolid.
For my the new mesh region object exact this is needed, select one of the Solids a CompSolid is made off (not build from!). I did a work around I'm not happy with because it is implemented in the task panel and not in the selection frame work. IMHO this should be implemented in the selection frame work at some point in the future. FEM topic of mesh region object: viewtopic.php?f=18&p=147507#p147507 See screen and commit https://github.com/berndhahnebach/FreeC ... 81c1a1b192
cheers bernd
bernd
Post by bernd »
I solved it on various places in FEM the following way:
if eles.startswith('Solid'):
    ele_shape = sub[0].Shape.Solids[int(eles.lstrip('Solid')) - 1]  # Solid
else:
    ele_shape = sub[0].Shape.getElement(eles)  # Face, Edge, Vertex
bernd
Post by bernd »
added an own method for the use in FEM since it is cumbersome to distinguish every time: https://github.com/berndhahnebach/FreeC ... it/87f0058
bernd
Post by bernd »
bernd wrote:added an own method for the use in FEM since it is cumbersome to distinguish every time: https://github.com/berndhahnebach/FreeC ... it/87f0058
in master ... git commit d64e2cf and https://github.com/FreeCAD/FreeCAD/comm ... 92998R1235
