$ cmake -DBUILD_FEM_NETGEN=ON -DFREECAD_USE_EXTERNAL_KDL=ON -DFREECAD_CREATE_MAC_APP=ON -DCMAKE_BUILD_TYPE=DEBUG -DBUILD_QT5=ON ..
-- The C compiler identification is AppleClang 6.1.0.6020053
-- The CXX compiler identification is AppleClang 6.1.0.6020053
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Looking for GL/gl.h
-- Looking for GL/gl.h - not found
-- Looking for C++ include istream
-- Looking for C++ include istream - found
-- Looking for C++ include ostream
-- Looking for C++ include ostream - found
-- Looking for C++ include fstream
-- Looking for C++ include fstream - found
-- Looking for C++ include sstream
-- Looking for C++ include sstream - found
-- Looking for C++ include ios
-- Looking for C++ include ios - found
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Looking for C++ include iomanip
-- Looking for C++ include iomanip - found
-- Check for STD namespace
-- Check for STD namespace - found
-- prefix: /usr/local
-- datadir: data
-- docdir: doc
-- includedir: include
-- libdir: /usr/local/lib
-- Detected Homebrew install at /usr/local
-- Found PythonInterp: /usr/local/bin/python (found version "2.7.13")
-- Found PythonLibs: /usr/local/opt/python/Frameworks/Python.framework/Versions/2.7/lib/libpython2.7.dylib (Required is exact version "2.7.13")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - found
-- Found Threads: TRUE
-- Boost version: 1.63.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- signals
-- system
-- thread
-- chrono
-- date_time
-- atomic
-- Found Xerces-C: /usr/local/lib/libxerces-c.dylib
-- Found ZLIB: /usr/lib/libz.dylib (found version "1.2.5")
-- PyCXX found:
-- Headers: /Users/blacey/FreeCAD-MacOS-CI/src
-- Sources: /Users/blacey/FreeCAD-MacOS-CI/src/CXX
-- Found OCC: /usr/local/include/opencascade (found version "7.0.0")
-- -- Found OCE/OpenCASCADE version: 7.0.0
-- -- OCE/OpenCASCADE include directory: /usr/local/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/local/lib
-- VTK components: not found or used
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Found HDF5: /usr/local/lib/libhdf5.dylib;/usr/local/lib/libsz.dylib;/usr/lib/libz.dylib;/usr/lib/libdl.dylib;/usr/lib/libm.dylib (found version "1.8.18")
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: /usr/local/include
-- Found NETGEN version 5.3, calculated: 328448
-- Found SWIG: /usr/local/bin/swig (found version "3.0.11")
-- Found Eigen3: /usr/local/include/eigen3 (Required is at least version "2.91.0")
-- Found Freetype: /usr/local/lib/libfreetype.dylib (found version "2.7.1")
-- Found OpenGL: /System/Library/Frameworks/OpenGL.framework
-- Found OpenGLU: /System/Library/Frameworks/OpenGL.framework
-- Could NOT find Spnav (missing: SPNAV_LIBRARY SPNAV_INCLUDE_DIR)
-- libshiboken built for Release
-- Found PySide2 tools: /usr/local/bin/pyside2-uic, /usr/local/bin/pyside2-rcc
-- -- matplotlib-1.5.1 has been found.
-- Platform is 64-bit, set -D_OCC64
-- Build type: DEBUG
However,
make install/fast
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.fseventsd/000000000629d4aa
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.fseventsd/00000000062a0f4b
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.fseventsd/00000000062ad594
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.fseventsd/fseventsd-uuid
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V1
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V1/VolumeConfig.plist
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V2
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V2/643A3640-86AD-461D-AC14-8F14FDC4DD4B
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V2/643A3640-86AD-461D-AC14-8F14FDC4DD4B/.store.db
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V2/643A3640-86AD-461D-AC14-8F14FDC4DD4B/0.directoryStoreFile
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V2/643A3640-86AD-461D-AC14-8F14FDC4DD4B/0.directoryStoreFile.shadow
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V2/643A3640-86AD-461D-AC14-8F14FDC4DD4B/0.indexArrays
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/Store-V2/643A3640-86AD-461D-AC14-8F14FDC4DD4B/tmp.spotlight.state
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Spotlight-V100/VolumeConfiguration.plist
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.Trashes
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.vol
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///.VolumeIcon.icns
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications/.DS_Store
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications/.localized
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications/App Store.app
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications/App Store.app/Contents
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications/App Store.app/Contents/_CodeSignature
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications/App Store.app/Contents/_CodeSignature/CodeResources
-- Installing: /usr/local/FreeCAD.app/Contents/lib/qtplugins///Applications/App Store.app/Contents/Info.plist
Time's up for me so I'm offline for a bit...
