macOS Qt5 plan and status
It seems the homebrew folks (i.e. macOS ports system) have dropped support for QT4 completely defaulting the ports repo and packages to QT5. This is causing the macOS builds to fail to build... I know @f3nix and @wmayer have recently made numerous changes to support QT4 but what is the plan to switch FreeCAD 0.17 dev to QT5? Bottom-line, is the QT5 support sufficiently complete that we can safely switch the macOS builds to QT5 now? If not, I will need to find a way to continue to support QT4 that will inevitably be obviated by QT5 support so I would like to avoid any extra QT4 work.
Re: QT5 status and plan?
FreeCAD is already ported to Qt5. There might still be some issues here and there but it should work sufficiently well.
Great. At first blush, it seems there are some platform-specific library naming nuances that will cause some work to bring up QT5 on macOS.
The libraries are there, just named differently (i.e. the same as the QT4 libraries are named).
Does anyone have a suggested "best" strategy to address this macOS platform-specific QT5 difference? Change CMakeLists.txt, rename macOS lib names (yuck) to match other platforms? Has anyone (e.g. @sgrogan) built FreeCAD dev against QT5 on Windows?
For now, I will go down the tailor CMake path to handle macOS-specific nuances unless someone has a better way to handle this difference.
-- Found Eigen3: /usr/local/include/eigen3 (Required is at least version "2.91.0")
CMake Warning at CMakeLists.txt:738 (find_package):
By not providing "FindQt5Network.cmake" in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
"Qt5Network", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Network" with
any of the following names:
Qt5NetworkConfig.cmake
qt5network-config.cmake
Add the installation prefix of "Qt5Network" to CMAKE_PREFIX_PATH or set
"Qt5Network_DIR" to a directory containing one of the above files. If
"Qt5Network" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:739 (find_package):
By not providing "FindQt5Xml.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Xml", but
Could not find a package configuration file provided by "Qt5Xml" with any
Qt5XmlConfig.cmake
qt5xml-config.cmake
Add the installation prefix of "Qt5Xml" to CMAKE_PREFIX_PATH or set
"Qt5Xml_DIR" to a directory containing one of the above files. If "Qt5Xml"
provides a separate development package or SDK, be sure it has been
installed.
CMake Warning at CMakeLists.txt:741 (find_package):
By not providing "FindQt5Widgets.cmake" in CMAKE_MODULE_PATH this project
"Qt5Widgets", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Widgets" with
Qt5WidgetsConfig.cmake
qt5widgets-config.cmake
Add the installation prefix of "Qt5Widgets" to CMAKE_PREFIX_PATH or set
"Qt5Widgets_DIR" to a directory containing one of the above files. If
"Qt5Widgets" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:742 (find_package):
By not providing "FindQt5PrintSupport.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"Qt5PrintSupport", but CMake did not find one.
Could not find a package configuration file provided by "Qt5PrintSupport"
with any of the following names:
Qt5PrintSupportConfig.cmake
qt5printsupport-config.cmake
Add the installation prefix of "Qt5PrintSupport" to CMAKE_PREFIX_PATH or
set "Qt5PrintSupport_DIR" to a directory containing one of the above files.
If "Qt5PrintSupport" provides a separate development package or SDK, be
sure it has been installed.
CMake Warning at CMakeLists.txt:743 (find_package):
By not providing "FindQt5OpenGL.cmake" in CMAKE_MODULE_PATH this project
"Qt5OpenGL", but CMake did not find one.
Could not find a package configuration file provided by "Qt5OpenGL" with
Qt5OpenGLConfig.cmake
qt5opengl-config.cmake
Add the installation prefix of "Qt5OpenGL" to CMAKE_PREFIX_PATH or set
"Qt5OpenGL_DIR" to a directory containing one of the above files. If
"Qt5OpenGL" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:744 (find_package):
By not providing "FindQt5Svg.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Svg", but
Could not find a package configuration file provided by "Qt5Svg" with any
Qt5SvgConfig.cmake
qt5svg-config.cmake
Add the installation prefix of "Qt5Svg" to CMAKE_PREFIX_PATH or set
"Qt5Svg_DIR" to a directory containing one of the above files. If "Qt5Svg"
installed.
CMake Warning at CMakeLists.txt:745 (find_package):
By not providing "FindQt5UiTools.cmake" in CMAKE_MODULE_PATH this project
"Qt5UiTools", but CMake did not find one.
Could not find a package configuration file provided by "Qt5UiTools" with
Qt5UiToolsConfig.cmake
qt5uitools-config.cmake
Add the installation prefix of "Qt5UiTools" to CMAKE_PREFIX_PATH or set
"Qt5UiTools_DIR" to a directory containing one of the above files. If
"Qt5UiTools" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:746 (find_package):
been installed.
CMake Warning at CMakeLists.txt:747 (find_package):
By not providing "FindQt5Concurrent.cmake" in CMAKE_MODULE_PATH this
"Qt5Concurrent", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Concurrent"
Qt5ConcurrentConfig.cmake
qt5concurrent-config.cmake
Add the installation prefix of "Qt5Concurrent" to CMAKE_PREFIX_PATH or set
"Qt5Concurrent_DIR" to a directory containing one of the above files. If
"Qt5Concurrent" provides a separate development package or SDK, be sure it
has been installed.
CMake Warning at CMakeLists.txt:750 (find_package):
By not providing "FindQt5WebKitWidgets.cmake" in CMAKE_MODULE_PATH this
"Qt5WebKitWidgets", but CMake did not find one.
Could not find a package configuration file provided by "Qt5WebKitWidgets"
Qt5WebKitWidgetsConfig.cmake
qt5webkitwidgets-config.cmake
Add the installation prefix of "Qt5WebKitWidgets" to CMAKE_PREFIX_PATH or
set "Qt5WebKitWidgets_DIR" to a directory containing one of the above
files. If "Qt5WebKitWidgets" provides a separate development package or
SDK, be sure it has been installed.
CMake Error at CMakeLists.txt:755 (MESSAGE):
Qt5 libraries not found.
$ find /usr/local/Cellar/qt5/5.7.1_1/ -name 'Qt*Network*'
/usr/local/Cellar/qt5/5.7.1_1//Frameworks/QtNetwork.framework
/usr/local/Cellar/qt5/5.7.1_1//include/QtNetwork
/usr/local/Cellar/qt5/5.7.1_1//lib/cmake/Qt5Network
/usr/local/Cellar/qt5/5.7.1_1//lib/cmake/Qt5Network/Qt5Network_QCoreWlanEnginePlugin.cmake
/usr/local/Cellar/qt5/5.7.1_1//lib/cmake/Qt5Network/Qt5Network_QGenericEnginePlugin.cmake
/usr/local/Cellar/qt5/5.7.1_1//lib/cmake/Qt5Network/Qt5NetworkConfig.cmake
/usr/local/Cellar/qt5/5.7.1_1//lib/cmake/Qt5Network/Qt5NetworkConfigVersion.cmake
/usr/local/Cellar/qt5/5.7.1_1//lib/pkgconfig/Qt5Network.pc
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework/QtNetwork
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework/QtNetwork.prl
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework/Versions/5/Headers/5.7.1/QtNetwork
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework/Versions/5/Headers/QtNetwork
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework/Versions/5/Headers/QtNetworkDepends
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework/Versions/5/Headers/QtNetworkVersion
/usr/local/Cellar/qt5/5.7.1_1//lib/QtNetwork.framework/Versions/5/QtNetwork
Hi @blacey.
I think running cmake with:
should do the trick.
Do You have PySide2 built againt 5.7.1 available? I am not able to compile it on Linux right now.
So far I have tested building against Qt5.3.2, Qt 5.4.2, Qt 5.5.1, Qt 5.6.2.
It works with 5.7.1 (PySide2 built againt 5.6.2). But this mismatch causes some runtime problems (small, but still...).
Cheers,
Mateusz
-DCMAKE_PREFIX_PATH=/usr/local/Cellar/qt5/5.7.1_1/lib/cmake
Cheers,
Mateusz
@f3nix, thanks for the pointer...
I'm actually working through pyside2 as I type... I am using clang 6.1 but pyside2 complains that my compiler is not C++11 compliant yet it is.f3nix wrote: Do You have PySide2 built againt 5.7.1 available? I am not able to compile it on Linux right now.
-- The C compiler identification is AppleClang 6.1.0.6020053
-- The CXX compiler identification is AppleClang 6.1.0.6020053
In file included from /usr/local/lib/QtCore.framework/Headers/qglobal.h:83:
/usr/local/lib/QtCore.framework/Headers/qcompilerdetection.h:562:6: error: Qt requires a C++11 compiler and yours does not seem to be that.
# error Qt requires a C++11 compiler and yours does not seem to be that.
I do not have access to an Apple machine. But maybe some cmake flags are not set right in pyside.
I would also suggest staying with Qt 5.6.2 if it is an option.
Are you using pyside2-setup? Or compiling each component? I have always had more success with the second approach. shiboken2 -> pyside2 -> pyside2-tools
Cheers,
Mateusz
Cheers,
Mateusz
Hi Mateusz,f3nix wrote:I do not have access to an Apple machine. But maybe some cmake flags are not set right in pyside.
Cheers,
Mateusz
I took your advise and dropped back to QT5.5, the only version available other than 5.7.1. I was able to build pyside2 using pyside2-setup.
Installing pyside2-uic script to /usr/local/bin
Installed /usr/local/lib/python2.7/site-packages/PySide2-2.0.0.dev0-py2.7-macosx-10.10-x86_64.egg
Processing dependencies for PySide2==2.0.0.dev0
Finished processing dependencies for PySide2==2.0.0.dev0
$ find /usr/local -name 'shiboken2*'
/usr/local/lib/python2.7/site-packages/PySide2-2.0.0.dev0-py2.7-macosx-10.10-x86_64.egg/PySide2/include/shiboken2
/usr/local/lib/python2.7/site-packages/PySide2-2.0.0.dev0-py2.7-macosx-10.10-x86_64.egg/PySide2/shiboken2
/usr/local/lib/python2.7/site-packages/PySide2-2.0.0.dev0-py2.7-macosx-10.10-x86_64.egg/PySide2/shiboken2.so
Perhaps I will look at installing each element individually or at least shiboken2 Do you mind providing the installation command-line arguments that you are using on Linux?
Also, if you would like access to an Apple Machine, I can provide that... I can create a VM and install all the necessary ports and provide you with ssh access if you would like (I would only need a preferred username and associated public rsa key from you).
Cheers,
Bruce
Setting this:
-DShiboken2_Dir=/Users/blacey/pyside2-setup/pyside_install/py2.7-qt5.5.1-64bit-release/lib/cmake/Shiboken2-2.0.0
-DPySide2_DIR=/Users/blacey/pyside2-setup/pyside_install/py2.7-qt5.5.1-64bit-release/lib/cmake/PySide2-2.0.0
should hopefully allow you to move forward
Cheers,
Mateusz
Thank You. This is a very generous offer. But I wouldn't want to waste your time on this. I don't know nothing about this environment...blacey wrote: Also, if you would like access to an Apple Machine, I can provide that... I can create a VM and install all the necessary ports and provide you with ssh access if you would like (I would only need a preferred username and associated public rsa key from you).
Cheers,
Mateusz
I tried the above but no joy. It finds shiboken2 but not pyside2 tools...f3nix wrote:Setting this:
$ cmake -DBUILD_FEM_NETGEN=ON -DFREECAD_USE_EXTERNAL_KDL=ON -DFREECAD_CREATE_MAC_APP=ON -DCMAKE_BUILD_TYPE=DEBUG -DBUILD_QT5=ON -DShiboken2_DIR=/Users/blacey/pyside2-setup/pyside_install/py2.7-qt5.5.1-64bit-release/lib/cmake/Shiboken2-2.0.0 -DPySide2_DIR=/Users/blacey/pyside2-setup/pyside_install/py2.7-qt5.5.1-64bit-release/lib/cmake/PySide2-2.0.0 ..
-- prefix: /usr/local
-- datadir: data
-- docdir: doc
-- includedir: include
-- libdir: /usr/local/lib
-- Detected Homebrew install at /usr/local
-- Boost version: 1.62.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- signals
-- system
-- thread
-- chrono
-- date_time
-- atomic
-- Found Xerces-C: /usr/local/lib/libxerces-c.dylib
-- PyCXX found:
-- Headers: /Users/blacey/FreeCAD-MacOS-CI/src
-- Sources: /Users/blacey/FreeCAD-MacOS-CI/src/CXX
-- -- Found OCE/OpenCASCADE version: 7.0.0
-- -- OCE/OpenCASCADE include directory: /usr/local/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/local/lib
-- VTK components: not found or used
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Check for medfile (libmed and libmedc) ...
-- Found NETGEN version 5.3, calculated: 328448
-- Could NOT find Spnav (missing: SPNAV_LIBRARY SPNAV_INCLUDE_DIR)
-- libshiboken built for Release
CMake Error at cMake/FindPySide2Tools.cmake:88 (message):
PySide2 tools could not be found, but are required.
CMakeLists.txt:854 (find_package)
-- Configuring incomplete, errors occurred!
See also "/Users/blacey/FreeCAD-MacOS-CI/build/CMakeFiles/CMakeOutput.log".
See also "/Users/blacey/FreeCAD-MacOS-CI/build/CMakeFiles/CMakeError.log".
$ cat /Users/blacey/FreeCAD-MacOS-CI/build/CMakeFiles/CMakeError.log
Determining if the include file GL/gl.h exists failed with the following output:
Change Dir: /Users/blacey/FreeCAD-MacOS-CI/build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/make" "cmTC_46ac7/fast"
/Applications/Xcode.app/Contents/Developer/usr/bin/make -f CMakeFiles/cmTC_46ac7.dir/build.make CMakeFiles/cmTC_46ac7.dir/build
Building C object CMakeFiles/cmTC_46ac7.dir/CheckIncludeFile.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -o CMakeFiles/cmTC_46ac7.dir/CheckIncludeFile.c.o -c /Users/blacey/FreeCAD-MacOS-CI/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c
/Users/blacey/FreeCAD-MacOS-CI/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c:1:10: fatal error: 'GL/gl.h' file not found
#include <GL/gl.h>
1 error generated.
make[1]: *** [CMakeFiles/cmTC_46ac7.dir/CheckIncludeFile.c.o] Error 1
make: *** [cmTC_46ac7/fast] Error 2
Do you have the commands you used to build and install the pyside2 components?
Sorry. No.blacey wrote:Do you have the commands you used to build and install the pyside2 components?
I have "installed" the files by hand I'm too lazy.
But
-DPYSIDE2UICBINARY=/Users/blacey/pyside2-setup/pyside_install/py2.7-qt5.5.1-64bit-release/bin/pyside2-uic
-DPYSIDE2RCCBINARY=/Users/blacey/pyside2-setup/pyside_install/py2.7-qt5.5.1-64bit-release/bin/pyside2-rcc
should do it for now.
Cheers,
Mateusz
