[FIXED] Bug #2354 [Drawing] Arcs missing in projections of revolved sketches
Forum thread for continued discussion related to issue #2354
Re: Bug #2354 [Drawing] Arcs missing in projections of revolved sketches
Hello!
With OCC7.1 and files from 0.16 there are small errors. But if you made a new drawing with the wonderful TechDraw workbench it works pefect. I hope, this was helpful.
Greetings user1234
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.9627 (Git)
Build type: Unknown
Hash: e441c2a2fde8f7f8c505169c308975eb1ea0d969
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
Can you highlight them?user1234 wrote:With OCC7.1 and files from 0.16 there are small errors.
user1234 wrote: But if you made a new drawing with the wonderful TechDraw workbench it works pefect.
Thanks!user1234 wrote:OCC version: 7.1.0
"fight the good fight"
If you see the first picture above, the hidden seam from the radius is visible.sgrogan wrote:Can you highlight them?
Greetings user1234
Sorry for my lack of education on this topic. So if the radius is visible it means this bug is no more, correct?user1234 wrote:If you see the first picture above, the hidden seam from the radius is visible.sgrogan wrote:Can you highlight them?
Greetings user1234
I believe user1234 was talking about the edges I highlighted in yellow from his first capture.
These are hidden edges that should not be visible. But as I wrote in another similar bug/topic, the Drawing workbench will be deprecated in favour of TechDraw. If TechDraw no longer shows the bug, we should consider fixed.
Sorry for the loooong delay and that i false worded that.NormandC wrote:I believe user1234 was talking about the edges I highlighted in yellow from his first capture.
If you took a file, that was made with 0.16.XXXX, and make a drawing with 0.17.XXXXX TechDraw, it makes a false smooth visible edge (the invisble is visible). But if you make a complete new model with 0.17.XXXXX and make a new drawing with TechDraw with that, it works perfect. Actual machine:
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10085 (Git)
Build type: Unknown
Hash: 89925e21a3a496fefd20aa47f9a974350330b0c9
Qt version: 4.8.6
OCC version: 7.1.0
Sorry for my bad english.
Greetings
user1234
Re: [FIXED] Bug #2354 [Drawing] Arcs missing in projections of revolved sketches
Now that's puzzling.user1234 wrote:If you took a file, that was made with 0.16.XXXX, and make a drawing with 0.17.XXXXX TechDraw, it makes a false smooth visible edge (the invisble is visible).
I wonder what @wandererfan makes of this?
I still haven't managed to find time to compile OCC 7.1.0 to test this myself.
Issue report was related to arcs not showing correctly and that was resolved in OCC.
If this wouldn't be correct new issue related to hidden line removal would make sense. But as you say it works correctly in TechDraw in your test. Therefore no new issue needs to be reported for now. And if such issue would be detected it wouldn't be related to issue #2354.user1234 wrote:But if you make a complete new model with 0.17.XXXXX and make a new drawing with TechDraw with that, it works perfect.
- wandererfan
Beats me. Definitely have a hidden smooth line getting returned as a visible smooth line using the original model. I made a vaguely similar sketch using 17/7.0.1, rotated it and my hidden lines were fine.NormandC wrote:I wonder what @wandererfan makes of this?
- TechDraw Projection
- 2354VisibleSmoothEdgeDrawing.png (22.08 KiB) Viewed 2526 times
- Drawing Project Shape
- VisibleSmoothEdgeProblem.png (3.73 KiB) Viewed 2526 times
