Bug #2670 Bad boolean operations on meshes
Post by Kunda1 »
Discussion related to issue #2670:
OP writes:
Description
the boolean operations(intersect/unite/difference) on two spheres have weird results.
Steps To Reproduce
1. Open FreeCAD
2. Press the "create new document" button
3. enter the python codes:
import Mesh
m1 = Mesh.createSphere(1, 50)
m1.translate(1,0,0)
m2 = Mesh.createSphere(1, 50)
m2.translate(0,0,1)
m3 = m1.intersect(m2)
Mesh.show(m3)
Additional Information
OS: Windows 7
Version: 0.17.7745 (Git)
Hash: 79dcdfbc782e24bb34db882143af7ce8ebd237bd
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
@NormandC replies:
NormandC wrote:Since some time (0.15.4671 I believe, maybe sooner) mesh Booleans are managed by OpenSCAD. Therefore you must install OpenSCAD. The python code will be different. It will be something like this (output from doing it through the GUI):
import OpenSCADUtils
mesh = OpenSCADUtils.meshoptempfile('intersection',(App.ActiveDocument.Sphere.Mesh,App.ActiveDocument.Sphere001.Mesh))
The real bug here may be that "m3 = m1.intersect(m2)" does not produce a warning/error.
Re: Bug #2670 Bad boolean operations on meshes
Post by Kunda1 »
bump
