Description
The DXF/SVG export of a sketch is broken when the sketch is oriented any other way than on the XY-plane. Lines are affected differently than arcs.
If the sketch is copied and reoriented to XY, export works fine.
Steps To Reproduce
- Create a line and an arc or circle in a sketch on XZ-plane
- Export to DXF or flattened SVG
- Look at output
Bug #2663 DXF export wrong when sketch is rotated
issue #2663:
Re: Bug #2663 DXF export wrong when sketch is rotated
Hey Kunda1,
sorry for the late reply. As posted on the bug tracker, the behavior is still present with this version:
OS: Ubuntu Zesty Zapus (development branch)
Version: 0.17.10035 (Git)
Build type: None
Hash: 0598af8a081f762039fa43efaf90ece4ca0b5e6f
Python version: 2.7.13
OCC version: 6.8.0.oce-0.17
Left side: Sketch in XZ-plane in FreeCAD
Right side: Exported as Autodesk DXF, resulting file opened in LibreCAD
Build type: None
bumping thread for community input
care to weigh in on this?yorik wrote:ping
