[Fixed] Crash Bug #2710 Freecad doesn't show sketch elements added when overconstrained
Post by Kunda1 »
issue #2710
Description
If you have an overconstrained sketch, Freecad will not show sketched features drawn without any constraints. The features show up by either adding another feature and creating auto constraints or by saving and re-opening the file. If you are in the state with any "hidden" features and press undo (cmd+z), Freecad crashes.
This bug works the same way in both version 0.16 (6706) and 0.17 (8471).
Steps To Reproduce
1. Open the attached file (HiddenSketchFeatures017 or 016) file
2. Add any number sketch elements without auto-added constraints. They will all be hidden. Some will even crash Freecad immediately (like the more advanced such as rectangle or slot).
3. Add any constraint. The hidden elements will now appear.
4. Use the "Undo" action (cmd+z or the Undo menu item). Freecad will crash when removing one of these hidden (or previously hidden) elements.
Additional Information
These are the about-dumps for my Freecad versions. They were downloaded today:
0.16:
OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
0.17:
OS: Mac OS X
Version: 0.17.8471 (Git)
Branch: (detached from f944ab3)
Hash: f944ab3846a52e8f19bb2d4f6ec66e392669cdf5
Python version: 2.7.12
Coin version: 3.1.3
OCC version: 7.0.0
jnxd
Re: Crash Bug #2710 Freecad doesn't show sketch elements added when overconstrained
Post by jnxd »
Kunda1, I think the project should be changed to Sketcher rather than FreeCAD.
kkremitzki
Post by kkremitzki »
jnxd wrote:Kunda1, I think the project should be changed to Sketcher rather than FreeCAD.
Moved.
Post by Kunda1 »
Abdullah wrote:...
Can you offer any feedback on this ticket?
abdullah
Post by abdullah »
Kunda1 wrote:
Abdullah wrote:...
I have downloaded the zip, opened the 017. It is overconstrain. Then I add lines:
They appear.
Maybe I do not understand the "they all will be hidden" of the issue. I have also tried undoing. Not problem with crashes. I can not reproduce the indicated behaviour.
I am running for these tests:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10950 (Git)
Build type: None
Hash: 6368b2f822cf838ee6c50ebf62480ff86c214317
OCC version: 7.1.0
I have also tried the 016. Same behaviour as 017.
Post by Kunda1 »
This may be MacOSX specific. Can any test on OSX?
Kunda1 wrote:This may be MacOSX specific. Can any test on OSX?
I tested with exactly the same OSX FreeCAD-version. No problems here either.
My recommendation to the original poster sterna is to delete his config files, as 0.16 and 0.17 share the same config.
Post by Kunda1 »
@chrisb do u mind notating the ticket with a mention to @sterna to do just as you said? Thx!
abdullah
Post by abdullah »
I have been working on a design today and something related to this ticket happened to me.
I was using the polyline tool. I wanted to do a segment coincident with the vertical axis. Some autoconstraint got applied and the following segments won't appear. Ultimately FC crashed.
The problem: I had been unable to reproduce it afterwards.
Bottom line: There is a bug. I do not have a way to reproduce it yet. So we can not debug it and fix it.
Did you do any Ctrl-Z before, perhaps even multiple? That's a use case where my FreeCAD crashes with some regularity but not repeatable. That's why I haven't reported it yet. The extremely good thing about this crash is, that it was the only one occuring in months (with 0.16).
