Gui::InputField precision limitation (2 digits)
I just filed issue 2866 (http://www.freecadweb.org/tracker/view.php?id=2866) about Gui::InputField rounding all entered values to 2 digits, internally. Not sure if I got the category right and everything, hence the post here.
Re: Gui::InputField precision limitation (2 digits)
FYI you can type the issue number and then press the 'bug' button in the forummlampert wrote:I just filed issue 2866 (http://www.freecadweb.org/tracker/view.php?id=2866) about Gui::InputField rounding all entered values to 2 digits, internally. Not sure if I got the category right and everything, hence the post here.
and it will automagically link to the tracker
issue #2866
- bug-button.png (170.73 KiB) Viewed 1624 times
Awesome, tried to figure that out and couldn't make it work. Thanks for the hint.Kunda1 wrote:FYI you can type the issue number and then press the 'bug' button in the forum
issue #2866
is there a relationship with issue #1822 ?
not sure about that.
There is a comment that the # decimals can be set in the preferences. If that applies to the InputField and its internal representation then I guess it would be related. If that is the case then that setting needs some documentation, as it stands it looks like it's for display purposes only.
