Description
One of the most useful constraint in the sketcher is the Distance constraint. The keyboard shortcut for this is (and has been for a while) shift+D. Recently, the function "Docked" has been assigned to the same shortfuct, which conflicts, and hinders the function. Please change the default shortcut for Docked to something else.
Steps To Reproduce
Open Sketcher
Draw a line
Press shift+D (nothing happens, since windows are docked be default)
Additional Information
Workaround: Using the Customize menu, re-assign the keyboard shortcut for Docked (under Standard view) to something else.
[Fixed] Bug #2815: Default shortcut for "Constrain distance" has conflict
issue #2815: Default shortcut for "Constrain distance" has conflict
Re: Bug #2815: Default shortcut for "Constrain distance" has conflict
Seems like, as of version 0.17.10967, this is no longer a problem. If some of you nice developers also found this to not be an issue anymore, this issue can be closed.
It might also have been something weird with my config files (as was in another issue: https://forum.freecadweb.org/viewtopic.php?f=10&t=19923).
- kkremitzki
This is no longer an issue, Shift+D is not the default mapping anymore: https://github.com/FreeCAD/FreeCAD/comm ... cc040R1400
