Would some global shim help the transition to Qt5 and PySide2 for module developers?
f3nix
Re: Would some global shim help the transition to Qt5 and PySide2 for module developers?
Postby f3nix » Mon Mar 06, 2017 11:12 pm
yorik wrote:H f3nix,
thanks for the help offer! I am on debian with qt5.7.
Hello. No problem.
Building PySide2 against Qt > 5.6.2 is not supported at the moment. I'm using self-built 5.6.2 on debian unstable. This should work without problems for you.
HTH.
Cheers,
Mateusz
yorik
Site Admin
Postby yorik » Wed Mar 08, 2017 4:19 pm
f3nix wrote:Building PySide2 against Qt > 5.6.2 is not supported at the moment
Ah that explains it all :) Thanks!
I'll wait a little bit to see if that changes, otherwise I'll compile an earlier version here.
