Hi what is your gpu ? The big step requires 2G of gpu ramsgrogan wrote:1.5 fps vs 1.8 fpseasyw-fc wrote: I use this code to test fps in a reproducible mode:
STEP reader improvement (Pass 4): Moving to OpenGL 3.2
- vejmarie
Re: STEP reader improvement (Pass 4): Moving to OpenGL 3.2
- vejmarie
Color is not yet fully implemented this is why you see these errors I will try to make it during the weekeasyw-fc wrote:I can confirm that in win10-64b FC 10084-64b I havewmayer wrote:PR 517 is merged now.
Open points
- in the past when loading step files a progress bar was shown. At the moment this doesn't work any more
- when setting a colour per face then it doesn't work when VBO is on
1) when setting a color per face then it doesn't work when VBO is on
2) when setting a color per all Shape then it doesn't work when VBO is on
3) color will be displayed correctly just changing VBO preferences (so it seems they get assigned correctly, but not displayed w VBO)
new testing results are:vejmarie wrote:Your timing i still very disturbing to me. My system is a Macbook Pro Core i5 2.7Ghz .. Not the fastest stuff (this is a laptop), and I am reading this file in 360s everything included with latest build compares to 340s with CAD Assitant on the same machineloading time with VBO enabled doesn't change the loading time sensiblyw/out VBO
loading...
Cannot compute Inventor representation for the shape of Part__Feature148.
Cannot compute Inventor representation for the shape of Part__Feature890.
loading time = 925.803999901s
displaying time = 474.888999939s
w/out VBO
875ms/1.1fps
w VBO
170ms/6.2fps
fps is improved a lot!
Still I have a lot of errors "Cannot compute Inventor representation for the shape" and loading and displaying time quite high compared to yours
Please let me know if I can do more test to help in find to solve this riddle on slower performance compared to osx...
It would be nice to have a comparison on Linux and Windows pcs with similar hw
Maurice
Great! looking forwardvejmarie wrote: Color is not yet fully implemented this is why you see these errors I will try to make it during the week
Thx
M
- vejmarie
@wwmayer, I have revert back the ProgressBar code and still have the same issue. The ProgressBar is updated there
But the Main GUI thread is stuck during the Step reading operation (aka it never enter the code) up to the time the aReader get out (and my bar is displayed at 100%). So the InvokeMethod is called but the bar value is never updated during the step reading. So we are properly receiving the value within the call (there is an issue on macOS where size_t is not properly defined, and OCCT is sending float not int and the casting was totally a mess that is why I was always getting 0. I am now moving between 0 to 100 with 1 or 2 increments which is good). Do you have any idea ? Where does the Gui thread is supposed to stand during the Step reading operation, is it supposed to be the same thread than the one reading ? (One of my option is that OCCT create thread to make the operation and when the call happens QT doesn't recognize the code to be executed by a child thread, but this is pure supposition)
void Sequencer::setValue(int step)
QThread *currentThread = QThread::currentThread();
QThread *thr = d->bar->thread(); // this is the main thread
if ( thr == currentThread )
// if number of total steps is unknown then increment only by one
if (nTotalSteps == 0) {
int elapsed = d->progressTime.elapsed();
// allow an update every 500 milliseconds only
if (elapsed > 500) {
d->progressTime.restart();
if (thr != currentThread) {
QMetaObject::invokeMethod(d->bar, "setValue", Qt::/*Blocking*/QueuedConnection,
QGenericReturnArgument(), Q_ARG(int,d->bar->value()+1));
else {
d->bar->setValue(d->bar->value()+1);
qApp->processEvents();
else {
QGenericReturnArgument(), Q_ARG(int,step));
if (d->bar->isVisible())
showRemainingTime();
else {
d->bar->setValue(step);
d->bar->resetObserveEventFilter();
Note that if we use functionality related to OCC/OCE progress indicator. That functionality is currently not thread-safe.
Ram isn't a problem.vejmarie wrote:Hi what is your gpu ? The big step requires 2G of gpu ram
NVIDIA Quadro 4100M @ 1920 x 1080
I just tested this on Trusty (dual boot with the same hardware) 1.8 > 22 fps!
I need to check Win system settings and the driver versions. On Win I have the latest driver per the manufacturer (Not Win Update) I think I'm using the open source drivers on linux (not sure)
UPDATE: Problem on win was at least partially PEBCAK, some how I was using on board graphics, and indeed gpu ram < 2GB
After fixing this, 1.5 > 8.4 fps, still need to find the rest of the improvement.
"fight the good fight"
- vejmarie
That is some promising results which do correspond to my expectations on such hardware. Regarding your update the ratio you got is the same one than the one I have on my IRIS integrated GPU from Intel. I suspect that your driver is still rendering everything on the IGP instead of the Quadro board.sgrogan wrote:Ram isn't a problem.vejmarie wrote:Hi what is your gpu ? The big step requires 2G of gpu ram
I'm chasing this. I found an interesting parameter in the Nvidia control panel, "OpenGL rendering GPU" it was set to "auto detect" I changed it to point to Nvidia, unfortunately no joy.vejmarie wrote: That is some promising results which do correspond to my expectations on such hardware. Regarding your update the ratio you got is the same one than the one I have on my IRIS integrated GPU from Intel. I suspect that your driver is still rendering everything on the IGP instead of the Quadro board.
I had (and still have) some trouble with this specific IFC. But I found somthing very much better to treat FreeCAD. I was not aware that I have dozens of files which easily breaks FreeCAD. We do reinforcement drawings at work. I tried to import the reinforcement of a 4 storey building into FreeCAD which takes a few hours but works. While exporting to step I run out of memory (16 GB Ram). If someone is interested in treating FreeCAD I provided a few files on my next cloud https://pro.woelkli.com/s/xdhi7FIkQjyhGLu If I use the reinforcement of just one slab my FreeCAD can handle it. The step is 455 MB See screen.bernd wrote:I'm gone provided an step, but it will take a few hours, because ifc importer in FreeCAD is not optimized on speed.vejmarie wrote:I got an IFC not supported on my system. Any idea on how to enable it ?
I can't download the big one
