STEP reader improvement (Pass 4): Moving to OpenGL 3.2
- vejmarie
Re: STEP reader improvement (Pass 4): Moving to OpenGL 3.2
The setValue of the progress bar is called and act properly, the issue is that the step value (the one who is supposed to update the progress bar) is always equal to 0 which explain why the progress bar doesn't move. I am still investigating why, but I think that this value is coming directly from the aReader within OCCT.
I wanted to test if i can detect anything when it comes to the load time. But i get this error when compiling against latest OCC:
Therefore i give up for now.
/src/Mod/Part/App/ConePyImp.cpp: In member function ‘virtual int Part::ConePy::PyInit(PyObject*, PyObject*)’:
/src/Mod/Part/App/ConePyImp.cpp:134:53: error: no matching function for call to ‘GC_MakeConicalSurface::GC_MakeConicalSurface(gp_Cone, double&)’
GC_MakeConicalSurface mc(pcone->Cone(), dist);
For me it was always like this that the progress bar was shown and updating when the file was read in. But then when creating the visualization it was still visible and there it could be that the value was set back to 0.vejmarie wrote:The setValue of the progress bar is called and act properly, the issue is that the step value (the one who is supposed to update the progress bar) is always equal to 0 which explain why the progress bar doesn't move. I am still investigating why, but I think that this value is coming directly from the aReader within OCCT.
With your recent change the progress bar was visible but never showed a progress. When reverting your change it is back to normal. So, I doubt that this is related to OCC.
OK i managed to workaround the above compile issue and after got some more errors in:
At the:
Of type:
I managed to workaround that issue too and as for the test. I made sample STEP file and FreeCAD daily from PPA (OCE 0.17) 42s and FreeCAD 0.17 (OCC daily) 38s.
AppImportPy.cpp
AppImportGuiPy.cpp
ImportOCAF.cpp
# include <STEPCAFControl_Writer.hxx>
error: ‘NCollection_Vector’ does not name a type
I can confirm that in win10-64b FC 10084-64b I havewmayer wrote:PR 517 is merged now.
Open points
- in the past when loading step files a progress bar was shown. At the moment this doesn't work any more
- when setting a colour per face then it doesn't work when VBO is on
1) when setting a color per face then it doesn't work when VBO is on
2) when setting a color per all Shape then it doesn't work when VBO is on
3) color will be displayed correctly just changing VBO preferences (so it seems they get assigned correctly, but not displayed w VBO)
new testing results are:vejmarie wrote:Your timing i still very disturbing to me. My system is a Macbook Pro Core i5 2.7Ghz .. Not the fastest stuff (this is a laptop), and I am reading this file in 360s everything included with latest build compares to 340s with CAD Assitant on the same machine
loading time with VBO enabled doesn't change the loading time sensiblyw/out VBO
loading...
Cannot compute Inventor representation for the shape of Part__Feature148.
Cannot compute Inventor representation for the shape of Part__Feature890.
loading time = 925.803999901s
displaying time = 474.888999939s
w/out VBO
875ms/1.1fps
w VBO
170ms/6.2fps
fps is improved a lot!
Still I have a lot of errors "Cannot compute Inventor representation for the shape" and loading and displaying time quite high compared to yours
Please let me know if I can do more test to help in find to solve this riddle on slower performance compared to osx...
It would be nice to have a comparison on Linux and Windows pcs with similar hw
Maurice
I'm working on this but it is slow going.easyw-fc wrote:Still I have a lot of errors "Cannot compute Inventor representation for the shape" and loading and displaying time quite high compared to yours
On windows I have 3 versions of OCCT
1) OCCT 7.0 no TBB (This is what the developer builds use)
2) OCCT 7.0 w/ TBB
3) Vejmarie's OCCT w/ TBB
A given version of FreeCAD has to be built against each of these 3 versions. For 2 and 3 a HAVE_TBB boolean has to be created at FreeCAD CMake (it doesn't exist in the gui)
From previous tests the load time improvements are only evident with vejmarie's OCCT fork w/TBB and FreeCAD CMake HAVE_TBB.
On linux I don't have the required OCCT builds. A previous attempt yielded build errors when using vejmarie's fork.
"fight the good fight"
Sorry I didn't mean to push you... I mean that would be nice if someone would make a comparison to the actual windows build available at FC releases pages and Linux build both with standard OCC chain, to see if results in Win and Linux are comparable...sgrogan wrote: I'm working on this but it is slow going.
Maurice
No worrieseasyw-fc wrote:Sorry I didn't mean to push you... I mean that would be nice if someone would make a comparison to the actual windows build available at FC releases pages and Linux build both with standard OCC chain, to see if results in Win and Linux are comparable...
Maurice
The Ubuntu PPA uses oce 0.17.1 wo/TBB, so that's another variable.
On Win I'm just not getting the fps improvements 1.5 to 2.1-3.0 depending on what mouse model I use. I'm just rotating in the 3D view.
sgrogan wrote: The Ubuntu PPA uses oce 0.17.1 wo/TBB, so that's another variable.
I use this code to test fps in a reproducible mode:sgrogan wrote: On Win I'm just not getting the fps improvements 1.5 to 2.1-3.0 depending on what mouse model I use. I'm just rotating in the 3D view.
Gui.activeDocument().activeView().viewAxonometric()
Gui.SendMsgToActiveView("ViewFit")
Gui.ActiveDocument.ActiveView.startAnimating(0,1,0,0.2)
1.5 fps vs 1.8 fpseasyw-fc wrote: I use this code to test fps in a reproducible mode:
