Deep python bug. Changing an object via propertyLink may touch unnecessary stuff [fix proposed]
DeepSOIC
Re: Deep python bug. Changing an object via propertyLink may touch unnecessary stuff [reopened]
Post by DeepSOIC »
I propose a fix!
https://github.com/FreeCAD/FreeCAD/pull/698
EDIT: my progress over there smashed into a brick wall caused by this bug (a document being an attribute of itself caused infinite recursion). I couldn't move forward without fixing it.
Founder
Re: Deep python bug. Changing an object via propertyLink may touch unnecessary stuff [fix proposed]
Post by wmayer »
Here is an example to force the DAG error:
App.newDocument()
sketch=App.ActiveDocument.addObject("Sketcher::SketchObject","Sketch")
extrude=App.ActiveDocument.addObject("Part::Extrusion","Extrude")
extrude.Base=sketch
from BOPTools import SplitFeatures
slice=SplitFeatures.makeSlice("Slice")
slice.Base=extrude
from CompoundTools import CompoundFilter
filter=CompoundFilter.makeCompoundFilter("CompoundFilter")
filter.Base=slice
extrude.Label = "test"
And here is an example that causes a stack overflow:
class ViewProvider:
  def __init__(self, vobj):
    vobj.Proxy=self
  def attach(self, vobj):
    self.ViewObject = vobj
    self.Object = vobj.Object
  def claimChildren(self):
    children = [self.Object.Base]
    return children
doc=App.newDocument()
obj=doc.addObject("Part::FeaturePython", "Sketch")
obj.addProperty("App::PropertyLink","Base")
ViewProvider(obj.ViewObject)
ext=doc.addObject("Part::FeaturePython", "Extrude")
ext.addProperty("App::PropertyLink","Base").Base=obj
ViewProvider(ext.ViewObject)
sli=doc.addObject("Part::FeaturePython", "Slice")
sli.addProperty("App::PropertyLink","Base").Base=ext
ViewProvider(sli.ViewObject)
com=doc.addObject("Part::FeaturePython", "CompoundFilter")
com.addProperty("App::PropertyLink", "Base").Base=sli
ViewProvider(com.ViewObject)
doc.recompute()
ext.Label="test"
Founder
Post by wmayer »
Here is an example showing the DAG problem with only low-level feature classes:
class ViewProvider:
    vobj.Proxy=self
    children = [self.Object.Link]
    return children
obj=doc.addObject("App::FeaturePython", "Sketch")
obj.addProperty("App::PropertyLink","Link")
ext=doc.addObject("App::FeatureTest", "Extrude")
ext.Link=obj
sli=doc.addObject("App::FeaturePython", "Slice")
sli.addProperty("App::PropertyLink","Link").Link=ext
com=doc.addObject("App::FeaturePython", "CompoundFilter")
com.addProperty("App::PropertyLink", "Link").Link=sli
ext.Label="test"
Founder
Post by wmayer »
git commit a2dd176bc fixes the actual problem. The issue comes up when an object has an attribute e.g. Base and by its parent object it is also known as Base. Since both information are saved in a single dictionary it can happen that parent object & object attribute are mixed up and due to the chain of notification a cyclic dependency is created.
