FIXED - ASCII weirdness in Import WB source + typo clarity
Post by Kunda1 »
Below are links to lines in /src/Mod/Import/App/SCL/Builtin.py
I encountered a lot of ascii char weirdness in this file and have been able to clean most of it up. But there is an issue with several lines that I need help deciphering. The lines are below. I've attached a screenshot of how they look in my editor since GitHub sanitizes them.
https://github.com/luzpaz/FreeCAD/blob/ ... in.py#L125
https://github.com/luzpaz/FreeCAD/blob/ ... in.py#L152
https://github.com/luzpaz/FreeCAD/blob/ ... in.py#L200
https://github.com/luzpaz/FreeCAD/blob/ ... in.py#L570
typo:
https://github.com/luzpaz/FreeCAD/blob/ ... in.py#L708
#EXAMPLE 153 { The following test ensures that each point is a set is at a different position, (by
#definition they are distinct, i.e., instance unique).
should this be: The following test ensures that each point is a set at a different position, ?
any help would be appreciated
Re: ASCII weirdness in Import WB source + typo clarity
Post by Kunda1 »
bump
Re: FIXED - ASCII weirdness in Import WB source + typo clarity
Post by Kunda1 »
