units, try to find if a base quantity has a unit
Postby bernd » Mon Mar 13, 2017 11:24 am
I would like to know if a base quantity has a unit or not to get around a value errror if a base.quantity has no unit ... Has anyone an idea how to do this?
tc_new_unit = "W/m/K"
withUnit = u'43.0 W/m/K'
tc = FreeCAD.Units.Quantity(withUnit)
tc
tc_with_new_unit = tc.getValueAs(tc_new_unit)
tc_with_new_unit
withoutUnit = u'0.000009'
tc = FreeCAD.Units.Quantity(withoutUnit)
tc
Re: units, try to find if a base quantity has a unit
Postby bernd » Tue Mar 14, 2017 3:57 pm
Found something, but it does not work as expected :( An empty base unit does return True :(
FreeCAD.Units.Unit(withUnit)
if FreeCAD.Units.Unit(withUnit):
    print 'has unit'
else:
    print 'has no unit'
FreeCAD.Units.Unit(withoutUnit)
if FreeCAD.Units.Unit(withoutUnit):
    print 'has unit'
else:
    print 'has no unit'
output:
43000 mm*kg/(s^3*K)
Unit: mm*kg/(s^3*K) (1,1,-3,0,-1,0,0,0) [ThermalConductivity]
...     print 'has unit'
... else:
...     print 'has no unit'
has unit
9e-06
Unit:  (0,0,0,0,0,0,0,0)
... else:
has unit
Still I don not know how to check if a base quantity has no unit to get around the following problem:
FreeCAD.Units.Quantity(withUnit).getValueAs(tc_new_unit)
FreeCAD.Units.Quantity(withoutUnit).getValueAs(tc_new_unit)
output
43
ValueError: Unit mismatch
ian.rees
Postby ian.rees » Fri Mar 17, 2017 6:09 am
I think the Pythonic thing to wrap it in a try/catch block, but maybe I'm misunderstanding the issue? So, in your first example:
try:
    print "it has a unit"
except ValueError:
    print "it doesn't have a unit"
Postby bernd » Fri Mar 17, 2017 10:48 am
ian.rees wrote:I think the Pythonic thing to wrap it in a try/catch block, but maybe I'm misunderstanding the issue? So, in your first example:
try:
except ValueError:
This is exactly what I would like to avoid, add dozens of try except int the code just to check if a Base.Quantity has a unit.
Postby bernd » Fri Mar 17, 2017 10:57 am
found a possibility, search the unit type in the string ...
if 'ThermalConductivity' in str(FreeCAD.Units.Unit(withUnit)):
    print 'has unit for ThermalConductivity'
else:
    print 'has NO unit for ThermalConductivity'
if 'ThermalConductivity' in str(FreeCAD.Units.Unit(withoutUnit)):
else:
output:
43000 mm*kg/(s^3*K)
...     print 'has unit for ThermalConductivity'
... else:
...     print 'has NO unit for ThermalConductivity'
9e-06
... else:
ian.rees
Postby ian.rees » Fri Mar 17, 2017 7:30 pm
I see, it seems like there are at least a couple options then:
1) The getValueAs() method could be made to "succeed" if it's run on an object where the Unit is (0,0,0,0,0,0,0,0). I feel like this is maybe a little too sloppy.
2) Could make a new method "hasUnit()" that returns a boolean like:
>>> tc
9e-06
>>> tc.hasUnit()
False
But, I don't really understand what the situation is, that's creating objects that have Unit == (0,0,0,0,0,0,0,0) when they really mean something like ThermalConductivity. It feels like there might be an earlier problem to be solved, which would prevent the issue you're having. -Ian-
