HoWil
Posts: 1279 Joined: Sun Jun 14, 2015 7:31 pm
Post
by HoWil » Thu Mar 16, 2017 2:01 pm
NormandC wrote: Out of 8 tries (each time quitting and restarting FreeCAD), FreeCAD hanged only once, the other tries succeeded without trouble (although I find the subtractive sphere parameters rather slow to open, about 3-4 seconds).
Did you test it with standard radius of 5mm?
BR,
HoWil
HoWil
Post
by HoWil » Thu Mar 16, 2017 2:05 pm
Did build it with bernd's script form
https://forum.freecadweb.org/viewtopic. ... 67#p147887 and it works without problems.
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10490 (Git)
Build type: Unknown
Hash: 378f99f1b318202db3bc89b45d691a0376d07512
Python version: 2.7.12
OCC version: 7.1.0
HoWil
Post
by HoWil » Thu Mar 16, 2017 2:09 pm
EDIT The below is not true!!! I had Part-o-magic installed and with it I do not get the fault. After uninstalling (removing the Part-o-magic folder form 'Mod') I still get the fault with freecad-daily from ppa.
Original (wrong) message:
Did update my freecad-daily via ppa and the error is gone....
..... hopefully it will not come back
Still on the same machine.... should I test something else or do we leave it as is?
Thanks,
BR,
HoWil
Build type: None
OCC version: 7.1.0
HoWil
Post
by HoWil » Thu Mar 16, 2017 3:10 pm
Removed all folders in 'Mod' and still have the problem.... still get :
$ freecad-daily
FreeCAD 0.17, Libs: 0.17R10490 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2017
*** Error in `freecad-daily': double free or corruption (fasttop): 0x00007f5ed8083270 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7f5f7a82e7e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x7fe0a)[0x7f5f7a836e0a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f5f7a83a98c]
/usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x8d88f)[0x7f5f7ae2388f]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace3addERK13TopoDS_Vertex+0x562)[0x7f5ef067da62]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace17initDataStructureEv+0x91a)[0x7f5ef067e3ca]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace3addERKN11opencascade6handleI22BRepMesh_FaceAttributeEE+0xae)[0x7f5ef067efce]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace7PerformERKN11opencascade6handleI22BRepMesh_FaceAttributeEE+0x9)[0x7f5ef067fb19]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZNK20BRepMesh_FastDiscret7ProcessERK11TopoDS_Face+0x125)[0x7f5ef06709b5]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN3tbb10interface98internal24balancing_partition_typeINS1_13adaptive_modeINS1_19auto_partition_typeEEEE12work_balanceINS1_9start_forINS_13blocked_rangeI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorESD_Lb0EEEENS_8internal26parallel_for_each_body_forI20BRepMesh_FastDiscretSG_EEKNS_16auto_partitionerEEESH_EEvRT_RT0_+0x4ec)[0x7f5ef068765c]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN3tbb10interface98internal9start_forINS_13blocked_rangeI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorES7_Lb0EEEENS_8internal26parallel_for_each_body_forI20BRepMesh_FastDiscretSA_EEKNS_16auto_partitionerEE7executeEv+0x1ef)[0x7f5ef0687b7f]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x26fdd)[0x7f5ee7a83fdd]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x200dc)[0x7f5ee7a7d0dc]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x1efd3)[0x7f5ee7a7bfd3]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x1aa91)[0x7f5ee7a77a91]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x1acf9)[0x7f5ee7a77cf9]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba)[0x7f5f7934a6ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7f5f7a8bd82d]
======= Memory map: ========
00400000-00407000 r-xp 00000000 08:02 2635476 /usr/lib/freecad-daily/bin/FreeCAD
00606000-00607000 r--p 00006000 08:02 2635476 /usr/lib/freecad-daily/bin/FreeCAD
00607000-00608000 rw-p 00007000 08:02 2635476 /usr/lib/freecad-daily/bin/FreeCAD
01661000-0631c000 rw-p 00000000 00:00 0 [heap]
7f5ed8000000-7f5ed8210000 rw-p 00000000 00:00 0
7f5ed8210000-7f5edc000000 ---p 00000000 00:00 0
7f5edc000000-7f5edc210000 rw-p 00000000 00:00 0
7f5edc210000-7f5ee0000000 ---p 00000000 00:00 0
7f5ee0000000-7f5ee0210000 rw-p 00000000 00:00 0
7f5ee0210000-7f5ee4000000 ---p 00000000 00:00 0
7f5ee44d1000-7f5ee44e1000 rw-s 10adbb000 00:06 357 /dev/dri/card0
7f5ee44f1000-7f5ee4501000 rw-s 00000000 00:05 564182 /drm mm object (deleted)
7f5ee4501000-7f5ee452a000 r--p 00000000 08:02 4195320 /usr/share/fonts/truetype/liberation/LiberationSans-Italic.ttf
7f5ee452a000-7f5ee452b000 ---p 00000000 00:00 0
7f5ee452b000-7f5ee492b000 rw-p 00000000 00:00 0
7f5ee492b000-7f5ee492c000 ---p 00000000 00:00 0
7f5ee492c000-7f5ee4d2c000 rw-p 00000000 00:00 0
7f5ee4d2c000-7f5ee4d2d000 ---p 00000000 00:00 0
7f5ee4d2d000-7f5ee532d000 rw-p 00000000 00:00 0
7f5ee532d000-7f5ee562d000 rw-s 10aa9b000 00:06 357 /dev/dri/card0
7f5ee562d000-7f5ee5907000 r-xp 00000000 08:02 2623044 /usr/lib/freecad-daily/lib/SketcherGui.so
7f5ee5907000-7f5ee5b06000 ---p 002da000 08:02 2623044 /usr/lib/freecad-daily/lib/SketcherGui.so
7f5ee5b06000-7f5ee5b11000 r--p 002d9000 08:02 2623044 /usr/lib/freecad-daily/lib/SketcherGui.so
7f5ee5b11000-7f5ee5b17000 rw-p 002e4000 08:02 2623044 /usr/lib/freecad-daily/lib/SketcherGui.so
7f5ee5b17000-7f5ee5c3b000 r-xp 00000000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f5ee5c3b000-7f5ee5e3a000 ---p 00124000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f5ee5e3a000-7f5ee5e3d000 r--p 00123000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f5ee5e3d000-7f5ee5e3f000 rw-p 00126000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f5ee5e47000-7f5ee5e87000 rw-p 00000000 00:00 0
7f5ee5e87000-7f5ee618e000 r-xp 00000000 08:02 2623841 /usr/lib/freecad-daily/lib/PartGui.so
7f5ee618e000-7f5ee638e000 ---p 00307000 08:02 2623841 /usr/lib/freecad-daily/lib/PartGui.so
7f5ee638e000-7f5ee63a2000 r--p 00307000 08:02 2623841 /usr/lib/freecad-daily/lib/PartGui.so
7f5ee63a2000-7f5ee63a7000 rw-p 0031b000 08:02 2623841 /usr/lib/freecad-daily/lib/PartGui.so
7f5ee63a7000-7f5ee63a8000 rw-p 00000000 00:00 0
7f5ee63a8000-7f5ee6473000 r-xp 00000000 08:02 2624541 /usr/lib/freecad-daily/lib/_PartDesign.so
7f5ee6473000-7f5ee6672000 ---p 000cb000 08:02 2624541 /usr/lib/freecad-daily/lib/_PartDesign.so
7f5ee6672000-7f5ee667d000 r--p 000ca000 08:02 2624541 /usr/lib/freecad-daily/lib/_PartDesign.so
7f5ee667d000-7f5ee6680000 rw-p 000d5000 08:02 2624541 /usr/lib/freecad-daily/lib/_PartDesign.so
7f5ee6680000-7f5ee6681000 rw-p 00000000 00:00 0
7f5ee6681000-7f5ee68a0000 r-xp 00000000 08:02 2622304 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f5ee68a0000-7f5ee6aa0000 ---p 0021f000 08:02 2622304 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f5ee6aa0000-7f5ee6aaf000 r--p 0021f000 08:02 2622304 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f5ee6aaf000-7f5ee6ab3000 rw-p 0022e000 08:02 2622304 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f5ee6ab3000-7f5ee6bf8000 r-xp 00000000 08:02 2624526 /usr/lib/freecad-daily/lib/Sketcher.so
7f5ee6bf8000-7f5ee6df7000 ---p 00145000 08:02 2624526 /usr/lib/freecad-daily/lib/Sketcher.so
7f5ee6df7000-7f5ee6dfc000 r--p 00144000 08:02 2624526 /usr/lib/freecad-daily/lib/Sketcher.so
7f5ee6dfc000-7f5ee6e00000 rw-p 00149000 08:02 2624526 /usr/lib/freecad-daily/lib/Sketcher.so
7f5ee6e00000-7f5ee6e01000 rw-p 00000000 00:00 0
7f5ee6e01000-7f5ee7075000 r-xp 00000000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7f5ee7075000-7f5ee7275000 ---p 00274000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7f5ee7275000-7f5ee7283000 r--p 00274000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7f5ee7283000-7f5ee7284000 rw-p 00282000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7f5ee7284000-7f5ee7287000 rw-p 00000000 00:00 0
7f5ee7287000-7f5ee7325000 r-xp 00000000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7f5ee7325000-7f5ee7525000 ---p 0009e000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7f5ee7525000-7f5ee7529000 r--p 0009e000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7f5ee7529000-7f5ee752a000 rw-p 000a2000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7f5ee752a000-7f5ee7617000 r-xp 00000000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7f5ee7617000-7f5ee7817000 ---p 000ed000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7f5ee7817000-7f5ee781d000 r--p 000ed000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7f5ee781d000-7f5ee781e000 rw-p 000f3000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7f5ee781e000-7f5ee781f000 rw-p 00000000 00:00 0
7f5ee781f000-7f5ee7838000 r-xp 00000000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7f5ee7838000-7f5ee7a37000 ---p 00019000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7f5ee7a37000-7f5ee7a38000 r--p 00018000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7f5ee7a38000-7f5ee7a3a000 rw-p 00019000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7f5ee7a3a000-7f5ee7a5d000 rw-p 00000000 00:00 0
7f5ee7a5d000-7f5ee7a94000 r-xp 00000000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7f5ee7a94000-7f5ee7c94000 ---p 00037000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7f5ee7c94000-7f5ee7c95000 r--p 00037000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7f5ee7c95000-7f5ee7c97000 rw-p 00038000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7f5ee7c97000-7f5ee7c9a000 rw-p 00000000 00:00 0
7f5ee7c9a000-7f5ee7fb0000 r-xp 00000000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7f5ee7fb0000-7f5ee81b0000 ---p 00316000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7f5ee81b0000-7f5ee81b9000 r--p 00316000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7f5ee81b9000-7f5ee81c2000 rw-p 0031f000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7f5ee81c2000-7f5ee81c5000 rw-p 00000000 00:00 0
7f5ee81c5000-7f5ee821c000 r-xp 00000000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7f5ee821c000-7f5ee841c000 ---p 00057000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7f5ee841c000-7f5ee841e000 r--p 00057000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7f5ee841e000-7f5ee841f000 rw-p 00059000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7f5ee841f000-7f5ee8574000 r-xp 00000000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7f5ee8574000-7f5ee8773000 ---p 00155000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7f5ee8773000-7f5ee8777000 r--p 00154000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7f5ee8777000-7f5ee8779000 rw-p 00158000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7f5ee8779000-7f5ee8c16000 r-xp 00000000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7f5ee8c16000-7f5ee8e16000 ---p 0049d000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7f5ee8e16000-7f5ee8e1c000 r--p 0049d000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7f5ee8e1c000-7f5ee8e5e000 rw-p 004a3000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7f5ee8e5e000-7f5ee8e63000 rw-p 00000000 00:00 0
7f5ee8e63000-7f5ee9397000 r-xp 00000000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7f5ee9397000-7f5ee9597000 ---p 00534000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7f5ee9597000-7f5ee95a0000 r--p 00534000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7f5ee95a0000-7f5ee95a2000 rw-p 0053d000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7f5ee95a2000-7f5ee95a3000 rw-p 00000000 00:00 0
7f5ee95a3000-7f5ee986b000 r-xp 00000000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7f5ee986b000-7f5ee9a6b000 ---p 002c8000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7f5ee9a6b000-7f5ee9a71000 r--p 002c8000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7f5ee9a71000-7f5ee9a73000 rw-p 002ce000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7f5ee9a73000-7f5ee9b5a000 r-xp 00000000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7f5ee9b5a000-7f5ee9d59000 ---p 000e7000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7f5ee9d59000-7f5ee9d5e000 r--p 000e6000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7f5ee9d5e000-7f5ee9d5f000 rw-p 000eb000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7f5ee9d5f000-7f5ee9d60000 rw-p 00000000 00:00 0
7f5ee9d60000-7f5ee9f82000 r-xp 00000000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7f5ee9f82000-7f5eea181000 ---p 00222000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7f5eea181000-7f5eea189000 r--p 00221000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7f5eea189000-7f5eea18b000 rw-p 00229000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7f5eea18b000-7f5eea583000 r-xp 00000000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7f5eea583000-7f5eea783000 ---p 003f8000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7f5eea783000-7f5eea78a000 r--p 003f8000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7f5eea78a000-7f5eea78d000 rw-p 003ff000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7f5eea78d000-7f5eea9fe000 r-xp 00000000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7f5eea9fe000-7f5eeabfd000 ---p 00271000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7f5eeabfd000-7f5eeac07000 r--p 00270000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7f5eeac07000-7f5eeac08000 rw-p 0027a000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7f5eeac08000-7f5eeac1a000 rw-p 00000000 00:00 0
7f5eeac1a000-7f5eeae92000 r-xp 00000000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7f5eeae92000-7f5eeb092000 ---p 00278000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7f5eeb092000-7f5eeb098000 r--p 00278000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7f5eeb098000-7f5eeb09a000 rw-p 0027e000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7f5eeb09a000-7f5eeb09b000 rw-p 00000000 00:00 0
7f5eeb09b000-7f5eeb0be000 r-xp 00000000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7f5eeb0be000-7f5eeb2be000 ---p 00023000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7f5eeb2be000-7f5eeb2bf000 r--p 00023000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7f5eeb2bf000-7f5eeb2c0000 rw-p 00024000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7f5eeb2c0000-7f5eeb685000 r-xp 00000000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7f5eeb685000-7f5eeb884000 ---p 003c5000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7f5eeb884000-7f5eeb892000 r--p 003c4000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7f5eeb892000-7f5eeb894000 rw-p 003d2000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7f5eeb894000-7f5eeb896000 rw-p 00000000 00:00 0
7f5eeb896000-7f5eebad3000 r-xp 00000000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7f5eebad3000-7f5eebcd2000 ---p 0023d000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7f5eebcd2000-7f5eebcdc000 r--p 0023c000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7f5eebcdc000-7f5eebcdd000 rw-p 00246000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7f5eebcdd000-7f5eebcde000 rw-p 00000000 00:00 0
7f5eebcde000-7f5eebdfa000 r-xp 00000000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7f5eebdfa000-7f5eebffa000 ---p 0011c000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7f5eebffa000-7f5eebfff000 r--p 0011c000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7f5eebfff000-7f5eec000000 rw-p 00121000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7f5eec000000-7f5eec021000 rw-p 00000000 00:00 0
7f5eec021000-7f5ef0000000 ---p 00000000 00:00 0
7f5ef0002000-7f5ef0022000 rw-p 00000000 00:00 0
7f5ef0022000-7f5ef008c000 r-xp 00000000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7f5ef008c000-7f5ef028c000 ---p 0006a000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7f5ef028c000-7f5ef028f000 r--p 0006a000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7f5ef028f000-7f5ef0290000 rw-p 0006d000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7f5ef0290000-7f5ef0410000 r-xp 00000000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7f5ef0410000-7f5ef0610000 ---p 00180000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7f5ef0610000-7f5ef0615000 r--p 00180000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7f5ef0615000-7f5ef0616000 rw-p 00185000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7f5ef0616000-7f5ef061b000 rw-p 00000000 00:00 0
7f5ef061b000-7f5ef06ad000 r-xp 00000000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7f5ef06ad000-7f5ef08ad000 ---p 00092000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7f5ef08ad000-7f5ef08b0000 r--p 00092000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7f5ef08b0000-7f5ef08b1000 rw-p 00095000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7f5ef08b1000-7f5ef0b21000 r-xp 00000000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7f5ef0b21000-7f5ef0d21000 ---p 00270000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7f5ef0d21000-7f5ef0d27000 r--p 00270000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7f5ef0d27000-7f5ef0d29000 rw-p 00276000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7f5ef0d29000-7f5ef0d2a000 rw-p 00000000 00:00 0
7f5ef0d32000-7f5ef0d72000 rw-p 00000000 00:00 0
7f5ef0d72000-7f5ef118d000 r-xp 00000000 08:02 2625690 /usr/lib/freecad-daily/lib/Part.so
7f5ef118d000-7f5ef138d000 ---p 0041b000 08:02 2625690 /usr/lib/freecad-daily/lib/Part.so
7f5ef138d000-7f5ef139e000 r--p 0041b000 08:02 2625690 /usr/lib/freecad-daily/lib/Part.so
7f5ef139e000-7f5ef13b5000 rw-p 0042c000 08:02 2625690 /usr/lib/freecad-daily/lib/Part.so
7f5ef13b5000-7f5ef1437000 rw-p 00000000 00:00 0
7f5ef1437000-7f5ef14af000 r-xp 00000000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7f5ef14af000-7f5ef16ae000 ---p 00078000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7f5ef16ae000-7f5ef16af000 r--p 00077000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7f5ef16af000-7f5ef16ea000 rw-p 00078000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7f5ef16ea000-7f5ef172b000 rw-p 00000000 00:00 0
7f5ef172b000-7f5ef1734000 r-xp 00000000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7f5ef1734000-7f5ef1933000 ---p 00009000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7f5ef1933000-7f5ef1934000 r--p 00008000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7f5ef1934000-7f5ef1935000 rw-p 00009000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7f5ef1935000-7f5ef1936000 r-xp 00000000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7f5ef1936000-7f5ef1b35000 ---p 00001000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7f5ef1b35000-7f5ef1b36000 r--p 00000000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7f5ef1b36000-7f5ef1b37000 rw-p 00001000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7f5ef1b37000-7f5ef1b59000 r-xp 00000000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7f5ef1b59000-7f5ef1d58000 ---p 00022000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7f5ef1d58000-7f5ef1d59000 r--p 00021000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7f5ef1d59000-7f5ef1d5a000 rw-p 00022000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7f5ef1d5a000-7f5ef1d98000 r-xp 00000000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7f5ef1d98000-7f5ef1f97000 ---p 0003e000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7f5ef1f97000-7f5ef1f98000 r--p 0003d000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7f5ef1f98000-7f5ef1f99000 rw-p 0003e000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7f5ef1f99000-7f5ef20c2000 r-xp 00000000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7f5ef20c2000-7f5ef22c1000 ---p 00129000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7f5ef22c1000-7f5ef22c2000 r--p 00128000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7f5ef22c2000-7f5ef22c4000 rw-p 00129000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7f5ef22c4000-7f5ef28b8000 r-xp 00000000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7f5ef28b8000-7f5ef2ab7000 ---p 005f4000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7f5ef2ab7000-7f5ef2ab8000 r--p 005f3000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7f5ef2ab8000-7f5ef2abc000 rw-p 005f4000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7f5ef2ac4000-7f5ef2b04000 rw-p 00000000 00:00 0
7f5ef2b04000-7f5ef2b07000 r-xp 00000000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7f5ef2b07000-7f5ef2d06000 ---p 00003000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7f5ef2d06000-7f5ef2d07000 r--p 00002000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7f5ef2d07000-7f5ef2d08000 rw-p 00003000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7f5ef2d08000-7f5ef2e48000 rw-p 00000000 00:00 0
7f5ef2e48000-7f5ef2e66000 r-xp 00000000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7f5ef2e66000-7f5ef3065000 ---p 0001e000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7f5ef3065000-7f5ef3066000 r--p 0001d000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7f5ef3066000-7f5ef306a000 rw-p 0001e000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7f5ef306a000-7f5ef3121000 r-xp 00000000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7f5ef3121000-7f5ef3321000 ---p 000b7000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7f5ef3321000-7f5ef3322000 r--p 000b7000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7f5ef3322000-7f5ef3328000 rw-p 000b8000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7f5ef3328000-7f5ef332a000 rw-p 00000000 00:00 0
7f5ef332a000-7f5ef3398000 r-xp 00000000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7f5ef3398000-7f5ef3597000 ---p 0006e000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7f5ef3597000-7f5ef3598000 r--p 0006d000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7f5ef3598000-7f5ef3599000 rw-p 0006e000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7f5ef35a1000-7f5ef35e1000 rw-p 00000000 00:00 0
7f5ef35e1000-7f5ef3751000 r-xp 00000000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7f5ef3751000-7f5ef3950000 ---p 00170000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7f5ef3950000-7f5ef3952000 r--p 0016f000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7f5ef3952000-7f5ef395f000 rw-p 00171000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7f5ef395f000-7f5ef39b1000 rw-p 00000000 00:00 0
7f5ef3b1b000-7f5ef3b41000 rw-s 00000000 00:05 30441494 /SYSV00000000 (deleted)
7f5ef3b41000-7f5ef3b49000 rw-s 10a81e000 00:06 357 /dev/dri/card0
7f5ef3b49000-7f5ef3b51000 rw-s 00000000 00:05 565889 /drm mm object (deleted)
7f5ef3b51000-7f5ef3b59000 rw-s 10a816000 00:06 357 /dev/dri/card0
7f5ef3b59000-7f5ef3b61000 rw-s 00000000 00:05 565888 /drm mm object (deleted)
7f5ef3b61000-7f5ef3b69000 rw-s 10a80e000 00:06 357 /dev/dri/card0
7f5ef3b69000-7f5ef3b71000 rw-s 00000000 00:05 564190 /drm mm object (deleted)
7f5ef3b71000-7f5ef3b79000 rw-s 00000000 00:05 564189 /drm mm object (deleted)
7f5ef3b79000-7f5ef3b81000 rw-s 00000000 00:05 564187 /drm mm object (deleted)
7f5ef3b81000-7f5ef3b89000 rw-s 00000000 00:05 564215 /drm mm object (deleted)
7f5ef3b91000-7f5ef3b99000 rw-s 00000000 00:05 564195 /drm mm object (deleted)
7f5ef3ba1000-7f5ef3ba9000 rw-s 00000000 00:05 564191 /drm mm object (deleted)
7f5ef3ba9000-7f5ef3bb1000 rw-s 10a7fe000 00:06 357 /dev/dri/card0
7f5ef3bb1000-7f5ef3bb9000 rw-s 10a7f6000 00:06 357 /dev/dri/card0
7f5ef3bb9000-7f5ef3bc1000 rw-s 00000000 00:05 565857 /drm mm object (deleted)
7f5ef3bc1000-7f5ef3bc9000 rw-s 10a7ee000 00:06 357 /dev/dri/card0
7f5ef3bc9000-7f5ef3bd1000 rw-s 00000000 00:05 565856 /drm mm object (deleted)
7f5ef3bd1000-7f5ef3bd9000 rw-s 10a7e6000 00:06 357 /dev/dri/card0
7f5ef3bd9000-7f5ef3be1000 rw-s 00000000 00:05 564202 /drm mm object (deleted)
7f5ef3be9000-7f5ef3bf1000 rw-s 00000000 00:05 564200 /drm mm object (deleted)
7f5ef3bf1000-7f5ef3bf9000 rw-s 10a7d6000 00:06 357 /dev/dri/card0
7f5ef3bf9000-7f5ef3c01000 rw-s 00000000 00:05 565854 /drm mm object (deleted)
7f5ef3c01000-7f5ef3c11000 rw-s 00000000 00:05 564184 /drm mm object (deleted)
7f5ef3c11000-7f5ef3c19000 rw-s 10a7ce000 00:06 357 /dev/dri/card0
7f5ef3c31000-7f5ef3c39000 rw-s 10a7be000 00:06 357 /dev/dri/card0
7f5ef3c39000-7f5ef3c41000 rw-s 00000000 00:05 564858 /drm mm object (deleted)
7f5ef3c41000-7f5ef3c49000 rw-s 10a7b6000 00:06 357 /dev/dri/card0
7f5ef3c49000-7f5ef3c51000 rw-s 00000000 00:05 564197 /drm mm object (deleted)
7f5ef3c51000-7f5ef3c59000 rw-s 10a7ae000 00:06 357 /dev/dri/card0
7f5ef3c59000-7f5ef3c61000 rw-s 00000000 00:05 564196 /drm mm object (deleted)
7f5ef3c61000-7f5ef3c69000 rw-s 10a7a6000 00:06 357 /dev/dri/card0
7f5ef3c69000-7f5ef3c71000 rw-s 10adb3000 00:06 357 /dev/dri/card0
7f5ef3c71000-7f5ef3c79000 rw-s 00000000 00:05 564194 /drm mm object (deleted)
7f5ef3c81000-7f5ef3c91000 rw-s 00000000 00:05 566513 /drm mm object (deleted)
7f5ef3c91000-7f5ef3c99000 rw-s 10a79e000 00:06 357 /dev/dri/card0
7f5ef3ca1000-7f5ef3ca9000 rw-s 10a78e000 00:06 357 /dev/dri/card0
7f5ef3ca9000-7f5ef3cb1000 rw-s 10a786000 00:06 357 /dev/dri/card0
7f5ef3cb1000-7f5ef3db1000 rw-p 00000000 00:00 0
7f5ef3db1000-7f5ef3db6000 r-xp 00000000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f5ef3db6000-7f5ef3fb6000 ---p 00005000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f5ef3fb6000-7f5ef3fb7000 r--p 00005000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f5ef3fb7000-7f5ef3fb8000 rw-p 00006000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f5ef3fb9000-7f5ef3fc1000 rw-s 10ada3000 00:06 357 /dev/dri/card0
7f5ef3fc1000-7f5ef3fc9000 rw-s 10ad9b000 00:06 357 /dev/dri/card0
7f5ef3fc9000-7f5ef3ff8000 rw-s 00000000 00:05 30408725 /SYSV00000000 (deleted)
7f5ef3ff8000-7f5ef4000000 rw-s 00000000 00:05 564186 /drm mm object (deleted)
7f5ef4000000-7f5ef4080000 rw-p 00000000 00:00 0
7f5ef4080000-7f5ef8000000 ---p 00000000 00:00 0
7f5ef8000000-7f5ef8024000 rw-p 00000000 00:00 0
7f5ef8024000-7f5efc000000 ---p 00000000 00:00 0
7f5efc000000-7f5efc035000 rw-p 00000000 00:00 0
7f5efc035000-7f5f00000000 ---p 00000000 00:00 0
7f5f00000000-7f5f00010000 rw-s 10aa86000 00:06 357 /dev/dri/card0
7f5f00010000-7f5f00011000 ---p 00000000 00:00 0
7f5f00011000-7f5f00811000 rw-p 00000000 00:00 0
7f5f00811000-7f5f00812000 ---p 00000000 00:00 0
7f5f00812000-7f5f01012000 rw-p 00000000 00:00 0
7f5f01012000-7f5f01013000 ---p 00000000 00:00 0
7f5f01013000-7f5f01813000 rw-p 00000000 00:00 0
7f5f01813000-7f5f01832000 rw-p 00000000 00:00 0
7f5f01832000-7f5f01e18000 rw-p 00000000 00:00 0
7f5f01e18000-7f5f01e98000 rw-s 00000000 00:05 30375955 /SYSV00000000 (deleted)
7f5f01e98000-7f5f01ef8000 rw-s 00000000 00:05 30343186 /SYSV00000000 (deleted)
7f5f01ef8000-7f5f026af000 rw-s 00000000 00:05 30310406 /SYSV00000000 (deleted)
7f5f026af000-7f5f026e0000 r-xp 00000000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f5f026e0000-7f5f028df000 ---p 00031000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f5f028df000-7f5f028e0000 r--p 00030000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f5f028e0000-7f5f028e1000 rw-p 00031000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f5f028e1000-7f5f028f0000 r-xp 00000000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f5f028f0000-7f5f02af0000 ---p 0000f000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f5f02af0000-7f5f02af1000 r--p 0000f000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f5f02af1000-7f5f02af2000 rw-p 00010000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f5f02af2000-7f5f02b34000 r-xp 00000000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f5f02b34000-7f5f02d34000 ---p 00042000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f5f02d34000-7f5f02d36000 r--p 00042000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f5f02d36000-7f5f02d37000 rw-p 00044000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f5f02d37000-7f5f02d38000 ---p 00000000 00:00 0
7f5f02d38000-7f5f03538000 rw-p 00000000 00:00 0
7f5f03538000-7f5f035f1000 r--p 00000000 08:02 4195278 /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf
7f5f035f1000-7f5f0369d000 r--p 00000000 08:02 4195277 /usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf
7f5f0369d000-7f5f0379d000 rw-p 00000000 00:00 0
7f5f0379d000-7f5f03d30000 rw-p 00000000 00:00 0
7f5f03d30000-7f5f03d31000 ---p 00000000 00:00 0
7f5f03d31000-7f5f04531000 rw-p 00000000 00:00 0
7f5f04531000-7f5f04532000 ---p 00000000 00:00 0
7f5f04532000-7f5f44532000 rwxp 00000000 00:00 0
7f5f44532000-7f5f44533000 ---p 00000000 00:00 0
7f5f44533000-7f5f44673000 rw-p 00000000 00:00 0
7f5f44673000-7f5f446d1000 r-xp 00000000 08:02 1051702 /lib/x86_64-linux-gnu/libssl.so.1.0.0
7f5f446d1000-7f5f448d1000 ---p 0005e000 08:02 1051702 /lib/x86_64-linux-gnu/libssl.so.1.0.0
7f5f448d1000-7f5f448d5000 r--p 0005e000 08:02 1051702 /lib/x86_64-linux-gnu/libssl.so.1.0.0
7f5f448d5000-7f5f448dc000 rw-p 00062000 08:02 1051702 /lib/x86_64-linux-gnu/libssl.so.1.0.0
7f5f448dc000-7f5f448e4000 rw-s 00000000 00:05 564851 /drm mm object (deleted)
7f5f448e4000-7f5f44924000 rw-p 00000000 00:00 0
7f5f44924000-7f5f44939000 r-xp 00000000 08:02 2758134 /usr/lib/python2.7/lib-dynload/_ssl.x86_64-linux-gnu.so
7f5f44939000-7f5f44b38000 ---p 00015000 08:02 2758134 /usr/lib/python2.7/lib-dynload/_ssl.x86_64-linux-gnu.so
7f5f44b38000-7f5f44b39000 r--p 00014000 08:02 2758134 /usr/lib/python2.7/lib-dynload/_ssl.x86_64-linux-gnu.so
7f5f44b39000-7f5f44b3d000 rw-p 00015000 08:02 2758134 /usr/lib/python2.7/lib-dynload/_ssl.x86_64-linux-gnu.so
7f5f44b3d000-7f5f44b7d000 rw-p 00000000 00:00 0
7f5f44b7d000-7f5f44d97000 r-xp 00000000 08:02 1051700 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0
7f5f44d97000-7f5f44f96000 ---p 0021a000 08:02 1051700 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0
7f5f44f96000-7f5f44fb2000 r--p 00219000 08:02 1051700 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0
7f5f44fb2000-7f5f44fbe000 rw-p 00235000 08:02 1051700 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0
7f5f44fbe000-7f5f44fc1000 rw-p 00000000 00:00 0
7f5f44fc1000-7f5f44fc7000 r-xp 00000000 08:02 2758129 /usr/lib/python2.7/lib-dynload/_hashlib.x86_64-linux-gnu.so
7f5f44fc7000-7f5f451c6000 ---p 00006000 08:02 2758129 /usr/lib/python2.7/lib-dynload/_hashlib.x86_64-linux-gnu.so
7f5f451c6000-7f5f451c7000 r--p 00005000 08:02 2758129 /usr/lib/python2.7/lib-dynload/_hashlib.x86_64-linux-gnu.so
7f5f451c7000-7f5f451c8000 rw-p 00006000 08:02 2758129 /usr/lib/python2.7/lib-dynload/_hashlib.x86_64-linux-gnu.so
7f5f451c8000-7f5f451ce000 r-xp 00000000 08:02 2622417 /usr/lib/freecad-daily/lib/Start.so
7f5f451ce000-7f5f453ce000 ---p 00006000 08:02 2622417 /usr/lib/freecad-daily/lib/Start.so
7f5f453ce000-7f5f453cf000 r--p 00006000 08:02 2622417 /usr/lib/freecad-daily/lib/Start.so
7f5f453cf000-7f5f453d0000 rw-p 00007000 08:02 2622417 /usr/lib/freecad-daily/lib/Start.so
7f5f453d0000-7f5f4540f000 r-xp 00000000 08:02 2622295 /usr/lib/freecad-daily/lib/WebGui.so
7f5f4540f000-7f5f4560f000 ---p 0003f000 08:02 2622295 /usr/lib/freecad-daily/lib/WebGui.so
7f5f4560f000-7f5f45611000 r--p 0003f000 08:02 2622295 /usr/lib/freecad-daily/lib/WebGui.so
7f5f45611000-7f5f45612000 rw-p 00041000 08:02 2622295 /usr/lib/freecad-daily/lib/WebGui.so
7f5f45612000-7f5f4567e000 r-xp 00000000 08:02 2622853 /usr/lib/freecad-daily/lib/StartGui.so
7f5f4567e000-7f5f4587d000 ---p 0006c000 08:02 2622853 /usr/lib/freecad-daily/lib/StartGui.so
7f5f4587d000-7f5f4587e000 r--p 0006b000 08:02 2622853 /usr/lib/freecad-daily/lib/StartGui.so
7f5f4587e000-7f5f4587f000 rw-p 0006c000 08:02 2622853 /usr/lib/freecad-daily/lib/StartGui.so
7f5f4587f000-7f5f45888000 r-xp 00000000 08:02 2762666 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f5f45888000-7f5f45a87000 ---p 00009000 08:02 2762666 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f5f45a87000-7f5f45a88000 r--p 00008000 08:02 2762666 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f5f45a88000-7f5f45a89000 rw-p 00009000 08:02 2762666 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f5f45a89000-7f5f45d89000 rw-p 00000000 00:00 0
7f5f45d89000-7f5f4687f000 r-xp 00000000 08:02 2762783 /usr/lib/python2.7/dist-packages/PySide/QtGui.so
7f5f4687f000-7f5f46a7e000 ---p 00af6000 08:02 2762783 /usr/lib/python2.7/dist-packages/PySide/QtGui.so
7f5f46a7e000-7f5f46a93000 r--p 00af5000 08:02 2762783 /usr/lib/python2.7/dist-packages/PySide/QtGui.so
7f5f46a93000-7f5f46b35000 rw-p 00b0a000 08:02 2762783 /usr/lib/python2.7/dist-packages/PySide/QtGui.so
7f5f46b35000-7f5f46bfb000 rw-p 00000000 00:00 0
7f5f46bfb000-7f5f46c25000 r-xp 00000000 08:02 2628985 /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2.2
7f5f46c25000-7f5f46e24000 ---p 0002a000 08:02 2628985 /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2.2
7f5f46e24000-7f5f46e25000 r--p 00029000 08:02 2628985 /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2.2
7f5f46e25000-7f5f46e27000 rw-p 0002a000 08:02 2628985 /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2.2
7f5f46e27000-7f5f470b1000 r-xp 00000000 08:02 2762780 /usr/lib/python2.7/dist-packages/PySide/QtCore.so
7f5f470b1000-7f5f472b1000 ---p 0028a000 08:02 2762780 /usr/lib/python2.7/dist-packages/PySide/QtCore.so
7f5f472b1000-7f5f472b4000 r--p 0028a000 08:02 2762780 /usr/lib/python2.7/dist-packages/PySide/QtCore.so
7f5f472b4000-7f5f472e4000 rw-p 0028d000 08:02 2762780 /usr/lib/python2.7/dist-packages/PySide/QtCore.so
7f5f472e4000-7f5f472e7000 rw-p 00000000 00:00 0
7f5f472e7000-7f5f47736000 r-xp 00000000 08:02 2629043 /usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so.4.8.7
7f5f47736000-7f5f47935000 ---p 0044f000 08:02 2629043 /usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so.4.8.7
7f5f47935000-7f5f4796b000 r--p 0044e000 08:02 2629043 /usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so.4.8.7
7f5f4796b000-7f5f4796c000 rw-p 00484000 08:02 2629043 /usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so.4.8.7
7f5f4796c000-7f5f4796d000 rw-p 00000000 00:00 0
7f5f4796d000-7f5f479ac000 r-xp 00000000 08:02 2629040 /usr/lib/x86_64-linux-gnu/libQtSql.so.4.8.7
7f5f479ac000-7f5f47bab000 ---p 0003f000 08:02 2629040 /usr/lib/x86_64-linux-gnu/libQtSql.so.4.8.7
7f5f47bab000-7f5f47bad000 r--p 0003e000 08:02 2629040 /usr/lib/x86_64-linux-gnu/libQtSql.so.4.8.7
7f5f47bad000-7f5f47bae000 rw-p 00040000 08:02 2629040 /usr/lib/x86_64-linux-gnu/libQtSql.so.4.8.7
7f5f47bae000-7f5f47e3c000 r-xp 00000000 08:02 2629037 /usr/lib/x86_64-linux-gnu/libQtScript.so.4.8.7
7f5f47e3c000-7f5f4803b000 ---p 0028e000 08:02 2629037 /usr/lib/x86_64-linux-gnu/libQtScript.so.4.8.7
7f5f4803b000-7f5f4804d000 r--p 0028d000 08:02 2629037 /usr/lib/x86_64-linux-gnu/libQtScript.so.4.8.7
7f5f4804d000-7f5f4804e000 rw-p 0029f000 08:02 2629037 /usr/lib/x86_64-linux-gnu/libQtScript.so.4.8.7
7f5f4804e000-7f5f48071000 rw-p 00000000 00:00 0
7f5f48071000-7f5f48411000 r-xp 00000000 08:02 2629049 /usr/lib/x86_64-linux-gnu/libQtDeclarative.so.4.8.7
7f5f48411000-7f5f48610000 ---p 003a0000 08:02 2629049 /usr/lib/x86_64-linux-gnu/libQtDeclarative.so.4.8.7
7f5f48610000-7f5f4862f000 r--p 0039f000 08:02 2629049 /usr/lib/x86_64-linux-gnu/libQtDeclarative.so.4.8.7
7f5f4862f000-7f5f48632000 rw-p 003be000 08:02 2629049 /usr/lib/x86_64-linux-gnu/libQtDeclarative.so.4.8.7
7f5f48632000-7f5f48633000 rw-p 00000000 00:00 0
7f5f48633000-7f5f48683000 r-xp 00000000 08:02 2762631 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so
7f5f48683000-7f5f48883000 ---p 00050000 08:02 2762631 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so
7f5f48883000-7f5f48888000 r--p 00050000 08:02 2762631 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so
7f5f48888000-7f5f48889000 rw-p 00055000 08:02 2762631 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so
7f5f48889000-7f5f488c7000 r-xp 00000000 08:02 2762849 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessiblebridge/libqspiaccessiblebridge.so
7f5f488c7000-7f5f48ac7000 ---p 0003e000 08:02 2762849 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessiblebridge/libqspiaccessiblebridge.so
7f5f48ac7000-7f5f48ac8000 r--p 0003e000 08:02 2762849 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessiblebridge/libqspiaccessiblebridge.so
7f5f48ac8000-7f5f48ac9000 rw-p 0003f000 08:02 2762849 /usr/lib/x86_64-linux-gnu/qt4/plugins/accessiblebridge/libqspiaccessiblebridge.so
7f5f48ac9000-7f5f48b00000 r-xp 00000000 08:02 2628157 /usr/lib/x86_64-linux-gnu/libtxc_dxtn_s2tc.so.0.0.0
7f5f48b00000-7f5f48cff000 ---p 00037000 08:02 2628157 /usr/lib/x86_64-linux-gnu/libtxc_dxtn_s2tc.so.0.0.0
7f5f48cff000-7f5f48d00000 r--p 00036000 08:02 2628157 /usr/lib/x86_64-linux-gnu/libtxc_dxtn_s2tc.so.0.0.0
7f5f48d00000-7f5f48d01000 rw-p 00037000 08:02 2628157 /usr/lib/x86_64-linux-gnu/libtxc_dxtn_s2tc.so.0.0.0
7f5f48d01000-7f5f48d09000 r-xp 00000000 08:02 2627906 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
7f5f48d09000-7f5f48f09000 ---p 00008000 08:02 2627906 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
7f5f48f09000-7f5f48f0a000 r--p 00008000 08:02 2627906 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
7f5f48f0a000-7f5f48f0b000 rw-p 00009000 08:02 2627906 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
7f5f48f0b000-7f5f48f16000 r-xp 00000000 08:02 2621588 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
7f5f48f16000-7f5f49115000 ---p 0000b000 08:02 2621588 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
7f5f49115000-7f5f49116000 r--p 0000a000 08:02 2621588 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
7f5f49116000-7f5f49117000 rw-p 0000b000 08:02 2621588 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
7f5f49117000-7f5f4911e000 r-xp 00000000 08:02 2622208 /usr/lib/x86_64-linux-gnu/libdrm_nouveau.so.2.0.0
7f5f4911e000-7f5f4931d000 ---p 00007000 08:02 2622208 /usr/lib/x86_64-linux-gnu/libdrm_nouveau.so.2.0.0
7f5f4931d000-7f5f4931e000 r--p 00006000 08:02 2622208 /usr/lib/x86_64-linux-gnu/libdrm_nouveau.so.2.0.0
7f5f4931e000-7f5f4931f000 rw-p 00007000 08:02 2622208 /usr/lib/x86_64-linux-gnu/libdrm_nouveau.so.2.0.0
7f5f4931f000-7f5f4933f000 r-xp 00000000 08:02 2621734 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
7f5f4933f000-7f5f4953e000 ---p 00020000 08:02 2621734 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
7f5f4953e000-7f5f4953f000 r--p 0001f000 08:02 2621734 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
7f5f4953f000-7f5f49540000 rw-p 00020000 08:02 2621734 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
7f5f49540000-7f5f49ba0000 r-xp 00000000 08:02 3016378 /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
7f5f49ba0000-7f5f49da0000 ---p 00660000 08:02 3016378 /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
7f5f49da0000-7f5f49ddf000 r--p 00660000 08:02 3016378 /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
7f5f49ddf000-7f5f49de7000 rw-p 0069f000 08:02 3016378 /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
7f5f49de7000-7f5f49def000 rw-p 00000000 00:00 0
7f5f49def000-7f5f49dfa000 r-xp 00000000 08:02 2627681 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7f5f49dfa000-7f5f49ff9000 ---p 0000b000 08:02 2627681 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7f5f49ff9000-7f5f49ffa000 r--p 0000a000 08:02 2627681 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7f5f49ffa000-7f5f49ffd000 rw-p 0000b000 08:02 2627681 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7f5f49ffd000-7f5f4a06d000 r-xp 00000000 08:02 2629670 /usr/lib/x86_64-linux-gnu/libtiff.so.5.2.4
7f5f4a06d000-7f5f4a26d000 ---p 00070000 08:02 2629670 /usr/lib/x86_64-linux-gnu/libtiff.so.5.2.4
7f5f4a26d000-7f5f4a26e000 r--p 00070000 08:02 2629670 /usr/lib/x86_64-linux-gnu/libtiff.so.5.2.4
7f5f4a26e000-7f5f4a271000 rw-p 00071000 08:02 2629670 /usr/lib/x86_64-linux-gnu/libtiff.so.5.2.4
7f5f4a271000-7f5f4a278000 r-xp 00000000 08:02 2762636 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f5f4a278000-7f5f4a477000 ---p 00007000 08:02 2762636 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f5f4a477000-7f5f4a478000 r--p 00006000 08:02 2762636 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f5f4a478000-7f5f4a479000 rw-p 00007000 08:02 2762636 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f5f4a479000-7f5f4a47e000 r-xp 00000000 08:02 2762664 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f5f4a47e000-7f5f4a67d000 ---p 00005000 08:02 2762664 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f5f4a67d000-7f5f4a67e000 r--p 00004000 08:02 2762664 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f5f4a67e000-7f5f4a67f000 rw-p 00005000 08:02 2762664 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f5f4a67f000-7f5f4a6d1000 r-xp 00000000 08:02 2627707 /usr/lib/x86_64-linux-gnu/liblcms2.so.2.0.6
7f5f4a6d1000-7f5f4a8d0000 ---p 00052000 08:02 2627707 /usr/lib/x86_64-linux-gnu/liblcms2.so.2.0.6
7f5f4a8d0000-7f5f4a8d1000 r--p 00051000 08:02 2627707 /usr/lib/x86_64-linux-gnu/liblcms2.so.2.0.6
7f5f4a8d1000-7f5f4a8d5000 rw-p 00052000 08:02 2627707 /usr/lib/x86_64-linux-gnu/liblcms2.so.2.0.6
7f5f4a8d5000-7f5f4a8d6000 rw-p 00000000 00:00 0
7f5f4a8d6000-7f5f4a94f000 r-xp 00000000 08:02 2627412 /usr/lib/x86_64-linux-gnu/libmng.so.2.0.2
7f5f4a94f000-7f5f4ab4f000 ---p 00079000 08:02 2627412 /usr/lib/x86_64-linux-gnu/libmng.so.2.0.2
7f5f4ab4f000-7f5f4ab51000 r--p 00079000 08:02 2627412 /usr/lib/x86_64-linux-gnu/libmng.so.2.0.2
7f5f4ab51000-7f5f4ab52000 rw-p 0007b000 08:02 2627412 /usr/lib/x86_64-linux-gnu/libmng.so.2.0.2
7f5f4ab52000-7f5f4ab57000 r-xp 00000000 08:02 2762633 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f5f4ab57000-7f5f4ad57000 ---p 00005000 08:02 2762633 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f5f4ad57000-7f5f4ad58000 r--p 00005000 08:02 2762633 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f5f4ad58000-7f5f4ad59000 rw-p 00006000 08:02 2762633 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f5f4ad59000-7f5f4ad60000 r-xp 00000000 08:02 2762637 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f5f4ad60000-7f5f4af5f000 ---p 00007000 08:02 2762637 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f5f4af5f000-7f5f4af60000 r--p 00006000 08:02 2762637 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f5f4af60000-7f5f4af61000 rw-p 00007000 08:02 2762637 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f5f4af61000-7f5f4af68000 r-xp 00000000 08:02 2762634 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so
7f5f4af68000-7f5f4b167000 ---p 00007000 08:02 2762634 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so
7f5f4b167000-7f5f4b168000 r--p 00006000 08:02 2762634 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so
7f5f4b168000-7f5f4b169000 rw-p 00007000 08:02 2762634 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so
7f5f4b169000-7f5f4b170000 r-xp 00000000 08:02 2762638 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqgif.so
7f5f4b170000-7f5f4b36f000 ---p 00007000 08:02 2762638 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqgif.so
7f5f4b36f000-7f5f4b370000 r--p 00006000 08:02 2762638 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqgif.so
7f5f4b370000-7f5f4b371000 rw-p 00007000 08:02 2762638 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqgif.soAborted (core dumped)
Could not reproduce this problem on a second ubuntu 16.04 machine. Therefore will completely uninstall this version of FC-daily and reinstall it
HoWil
Post
by HoWil » Thu Mar 16, 2017 3:39 pm
I did a complete removal of freecad-daily and the .FreeCAD settings folder in home. Followed by a reinstall from ppa.
After that everything worked fine. Than I installed 'Lattice2' via 'Addon manager' and got the following error (was truncated because longer than the allowed 6000 char.)! After a restart everything works again. I am confused!
Will test this again from time to time but for now I cant reproduce the original Segmentation fault.
So let us hope that this was only a storm in the teacup and I will not report again!!!
BR,
HoWil
$ freecad-daily
*** Error in `freecad-daily': double free or corruption (fasttop): 0x000000000522e410 ***
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7fbc842fd7e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x7fe0a)[0x7fbc84305e0a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7fbc8430998c]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace3addERK13TopoDS_Vertex+0x55d)[0x7fbbf63b9a5d]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace17initDataStructureEv+0x91a)[0x7fbbf63ba3ca]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace3addERKN11opencascade6handleI22BRepMesh_FaceAttributeEE+0xae)[0x7fbbf63bafce]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace7PerformERKN11opencascade6handleI22BRepMesh_FaceAttributeEE+0x9)[0x7fbbf63bbb19]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZNK20BRepMesh_FastDiscret7ProcessERK11TopoDS_Face+0x125)[0x7fbbf63ac9b5]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN3tbb10interface98internal24balancing_partition_typeINS1_13adaptive_modeINS1_19auto_partition_typeEEEE12work_balanceINS1_9start_forINS_13blocked_rangeI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorESD_Lb0EEEENS_8internal26parallel_for_each_body_forI20BRepMesh_FastDiscretSG_EEKNS_16auto_partitionerEEESH_EEvRT_RT0_+0x4ec)[0x7fbbf63c365c]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN3tbb10interface98internal9start_forINS_13blocked_rangeI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorES7_Lb0EEEENS_8internal26parallel_for_each_body_forI20BRepMesh_FastDiscretSA_EEKNS_16auto_partitionerEE7executeEv+0x1ef)[0x7fbbf63c3b7f]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x26fdd)[0x7fbbf17e1fdd]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x241f0)[0x7fbbf17df1f0]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN3tbb17parallel_for_eachI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorES4_Lb0EE20BRepMesh_FastDiscretEEvT_S9_RKT0_+0x199)[0x7fbbf63c2f49]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN12OSD_Parallel7ForEachI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorES4_Lb0EE20BRepMesh_FastDiscretEEvT_S9_RKT0_b+0x1a6)[0x7fbbf63c3126]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_IncrementalMesh6updateEv+0x19f)[0x7fbbf63c1c2f]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_IncrementalMeshC2ERK12TopoDS_Shapedbdbb+0x336)[0x7fbbf63c2036]
/usr/lib/freecad-daily/lib/PartGui.so(_ZN7PartGui19ViewProviderPartExt12updateVisualERK12TopoDS_Shape+0x297)[0x7fbbefd2b9f7]
/usr/lib/freecad-daily/lib/PartGui.so(_ZN7PartGui19ViewProviderPartExt10updateDataEPKN3App8PropertyE+0xeb)[0x7fbbefd2f4fb]
/usr/lib/freecad-daily/lib/PartDesignGui.so(_ZN13PartDesignGui12ViewProvider10updateDataEPKN3App8PropertyE+0x60)[0x7fbbf04f6a50]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui12ViewProvider6updateEPKN3App8PropertyE+0x5f)[0x7fbc870d0aff]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui8Document17slotChangedObjectERKN3App14DocumentObjectERKNS1_8PropertyE+0x3f)[0x7fbc86e6934f]
/usr/lib/freecad-daily/lib/libFreeCADApp.so(_ZN5boost7signal2IvRKN3App14DocumentObjectERKNS1_8PropertyENS_10last_valueIvEEiSt4lessIiENS_8functionIFvS4_S7_EEEEclES4_S7_+0x603)[0x7fbc867b1e83]
/usr/lib/freecad-daily/lib/libFreeCADApp.so(_ZN3App14DocumentObject9onChangedEPKNS_8PropertyE+0x21)[0x7fbc867c85d1]
/usr/lib/freecad-daily/lib/Part.so(_ZN4Part7Feature9onChangedEPKN3App8PropertyE+0x4f)[0x7fbbf6c042ef]
/usr/lib/freecad-daily/lib/libFreeCADApp.so(_ZN3App8Property11hasSetValueEv+0x19)[0x7fbc86835579]
/usr/lib/freecad-daily/lib/_PartDesign.so(_ZN10PartDesign16FeaturePrimitive7executeERK12TopoDS_Shape+0x3e5)[0x7fbbf01992f5]
/usr/lib/freecad-daily/lib/_PartDesign.so(_ZN10PartDesign6Sphere7executeEv+0x138)[0x7fbbf0199da8]
/usr/lib/freecad-daily/lib/libFreeCADApp.so(_ZN3App14DocumentObject9recomputeEv+0x15)[0x7fbc867c5cd5]
/usr/lib/freecad-daily/lib/Part.so(_ZN4Part7Feature9recomputeEv+0x1f)[0x7fbbf6c0418f]
/usr/lib/freecad-daily/lib/libFreeCADApp.so(_ZN3App8Document17_recomputeFeatureEPNS_14DocumentObjectE+0xac)[0x7fbc8679395c]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN11QMetaObject8activateEP7QObjectPKS_iPPv+0x4d0)[0x7fbc84d86010]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui15QuantitySpinBox12valueChangedEd+0x43)[0x7fbc87126d83]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui15QuantitySpinBox9userInputERK7QString+0x5f1)[0x7fbc87127391]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN9QLineEdit11textChangedERK7QString+0x32)[0x7fbc856d0582]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x5f69b9)[0x7fbc856d09b9]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN12QLineControl11textChangedERK7QString+0x35)[0x7fbc85946fc5]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN12QLineControl12finishChangeEibb+0x1f8)[0x7fbc856d4b38]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN12QLineControl15internalSetTextERK7QStringib+0x1ab)[0x7fbc856d508b]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui15QuantitySpinBox10updateTextERKN4Base8QuantityE+0x5f)[0x7fbc871257df]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui15QuantitySpinBox8setValueEd+0x37)[0x7fbc871258f7]
/usr/lib/freecad-daily/lib/PartDesignGui.so(_ZN13PartDesignGui17TaskBoxPrimitivesC2EPNS_21ViewProviderPrimitiveEP7QWidget+0xc8e)[0x7fbbf04db99e]
/usr/lib/freecad-daily/lib/PartDesignGui.so(_ZN13PartDesignGui23TaskPrimitiveParametersC2EPNS_21ViewProviderPrimitiveE+0x5e)[0x7fbbf04dbc9e]
/usr/lib/freecad-daily/lib/PartDesignGui.so(_ZN13PartDesignGui21ViewProviderPrimitive7setEditEi+0x208)[0x7fbbf050c178]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui12ViewProvider12startEditingEi+0x3a)[0x7fbc870cdf0a]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui20View3DInventorViewer22setEditingViewProviderEPNS_12ViewProviderEi+0x2d)[0x7fbc870a909d]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui8Document7setEditEPNS_12ViewProviderEi+0xfd)[0x7fbc86e6a0ed]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui10DocumentPy7setEditEP7_object+0xa9)[0x7fbc86e786c9]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui10DocumentPy22staticCallback_setEditEP7_objectS2_+0x37)[0x7fbc86e78817]
/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8a51)[0x7fbc85e8d751]
/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x85c)[0x7fbc85fb601c]
/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCode+0x19)[0x7fbc85e84b89]
/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyRun_StringFlags+0x76)[0x7fbc85ef2166]
/usr/lib/freecad-daily/lib/libFreeCADBase.so(_ZN4Base20InterpreterSingleton9runStringB5cxx11EPKc+0x66)[0x7fbc863f6f76]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui7Command9doCommandENS0_10DoCmd_TypeEPKcz+0x130)[0x7fbc86ea76d0]
/usr/lib/freecad-daily/lib/PartDesignGui.so(_ZN26CmdPrimtiveCompSubtractive9activatedEi+0x1dc)[0x7fbbf0483a5c]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui7Command6invokeEi+0x7c)[0x7fbc86eabc7c]
/usr/lib/freecad-daily/lib/libFreeCADGui.so(_ZN3Gui11ActionGroup11onActivatedEP7QAction+0x18a)[0x7fbc86ea137a]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN12QActionGroup9triggeredEP7QAction+0x3f)[0x7fbc8529b66f]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x1c171f)[0x7fbc8529b71f]
00400000-00407000 r-xp 00000000 08:02 2628836 /usr/lib/freecad-daily/bin/FreeCAD
00606000-00607000 r--p 00006000 08:02 2628836 /usr/lib/freecad-daily/bin/FreeCAD
00607000-00608000 rw-p 00007000 08:02 2628836 /usr/lib/freecad-daily/bin/FreeCAD
00754000-05af8000 rw-p 00000000 00:00 0 [heap]
7fbbe0000000-7fbbe0210000 rw-p 00000000 00:00 0
7fbbe0210000-7fbbe4000000 ---p 00000000 00:00 0
7fbbe4000000-7fbbe4210000 rw-p 00000000 00:00 0
7fbbe4210000-7fbbe8000000 ---p 00000000 00:00 0
7fbbe8000000-7fbbe8210000 rw-p 00000000 00:00 0
7fbbe8210000-7fbbec000000 ---p 00000000 00:00 0
7fbbee364000-7fbbee38a000 rw-s 00000000 00:05 33718278 /SYSV00000000 (deleted)
7fbbee38a000-7fbbee392000 rw-s 00000000 00:05 590393 /drm mm object (deleted)
7fbbee392000-7fbbee39a000 rw-s 107847000 00:06 357 /dev/dri/card0
7fbbee39a000-7fbbee3a2000 rw-s 10783f000 00:06 357 /dev/dri/card0
7fbbee3aa000-7fbbee3b2000 rw-s 107837000 00:06 357 /dev/dri/card0
7fbbee3b2000-7fbbee3ba000 rw-s 00000000 00:05 586647 /drm mm object (deleted)
7fbbee3ba000-7fbbee3c2000 rw-s 10782f000 00:06 357 /dev/dri/card0
7fbbee3c2000-7fbbee3ca000 rw-s 00000000 00:05 586646 /drm mm object (deleted)
7fbbee3ca000-7fbbee3d2000 rw-s 00000000 00:05 590406 /drm mm object (deleted)
7fbbee3d2000-7fbbee3d3000 ---p 00000000 00:00 0
7fbbee3d3000-7fbbee7d3000 rw-p 00000000 00:00 0
7fbbee7d3000-7fbbee7d4000 ---p 00000000 00:00 0
7fbbee7d4000-7fbbeebd4000 rw-p 00000000 00:00 0
7fbbeebd4000-7fbbef38b000 rw-s 00000000 00:05 33685526 /SYSV00000000 (deleted)
7fbbef38b000-7fbbef665000 r-xp 00000000 08:02 2622499 /usr/lib/freecad-daily/lib/SketcherGui.so
7fbbef665000-7fbbef864000 ---p 002da000 08:02 2622499 /usr/lib/freecad-daily/lib/SketcherGui.so
7fbbef864000-7fbbef86f000 r--p 002d9000 08:02 2622499 /usr/lib/freecad-daily/lib/SketcherGui.so
7fbbef86f000-7fbbef875000 rw-p 002e4000 08:02 2622499 /usr/lib/freecad-daily/lib/SketcherGui.so
7fbbef875000-7fbbef999000 r-xp 00000000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7fbbef999000-7fbbefb98000 ---p 00124000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7fbbefb98000-7fbbefb9b000 r--p 00123000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7fbbefb9b000-7fbbefb9d000 rw-p 00126000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7fbbefb9d000-7fbbefba5000 rw-s 00000000 00:05 590402 /drm mm object (deleted)
7fbbefba5000-7fbbefbe5000 rw-p 00000000 00:00 0
7fbbefbe5000-7fbbefeec000 r-xp 00000000 08:02 2622501 /usr/lib/freecad-daily/lib/PartGui.so
7fbbefeec000-7fbbf00ec000 ---p 00307000 08:02 2622501 /usr/lib/freecad-daily/lib/PartGui.so
7fbbf00ec000-7fbbf0100000 r--p 00307000 08:02 2622501 /usr/lib/freecad-daily/lib/PartGui.so
7fbbf0100000-7fbbf0105000 rw-p 0031b000 08:02 2622501 /usr/lib/freecad-daily/lib/PartGui.so
7fbbf0105000-7fbbf0106000 rw-p 00000000 00:00 0
7fbbf0106000-7fbbf01d1000 r-xp 00000000 08:02 2623044 /usr/lib/freecad-daily/lib/_PartDesign.so
7fbbf01d1000-7fbbf03d0000 ---p 000cb000 08:02 2623044 /usr/lib/freecad-daily/lib/_PartDesign.so
7fbbf03d0000-7fbbf03db000 r--p 000ca000 08:02 2623044 /usr/lib/freecad-daily/lib/_PartDesign.so
7fbbf03db000-7fbbf03de000 rw-p 000d5000 08:02 2623044 /usr/lib/freecad-daily/lib/_PartDesign.so
7fbbf03de000-7fbbf03df000 rw-p 00000000 00:00 0
7fbbf03df000-7fbbf05fe000 r-xp 00000000 08:02 2622288 /usr/lib/freecad-daily/lib/PartDesignGui.so
7fbbf05fe000-7fbbf07fe000 ---p 0021f000 08:02 2622288 /usr/lib/freecad-daily/lib/PartDesignGui.so
7fbbf07fe000-7fbbf080d000 r--p 0021f000 08:02 2622288 /usr/lib/freecad-daily/lib/PartDesignGui.so
7fbbf080d000-7fbbf0811000 rw-p 0022e000 08:02 2622288 /usr/lib/freecad-daily/lib/PartDesignGui.so
7fbbf0811000-7fbbf0956000 r-xp 00000000 08:02 2622933 /usr/lib/freecad-daily/lib/Sketcher.so
7fbbf0956000-7fbbf0b55000 ---p 00145000 08:02 2622933 /usr/lib/freecad-daily/lib/Sketcher.so
7fbbf0b55000-7fbbf0b5a000 r--p 00144000 08:02 2622933 /usr/lib/freecad-daily/lib/Sketcher.so
7fbbf0b5a000-7fbbf0b5e000 rw-p 00149000 08:02 2622933 /usr/lib/freecad-daily/lib/Sketcher.so
7fbbf0b5e000-7fbbf0b5f000 rw-p 00000000 00:00 0
7fbbf0b5f000-7fbbf0dd3000 r-xp 00000000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7fbbf0dd3000-7fbbf0fd3000 ---p 00274000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7fbbf0fd3000-7fbbf0fe1000 r--p 00274000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7fbbf0fe1000-7fbbf0fe2000 rw-p 00282000 08:02 2631608 /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7.1.0
7fbbf0fe2000-7fbbf0fe5000 rw-p 00000000 00:00 0
7fbbf0fe5000-7fbbf1083000 r-xp 00000000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7fbbf1083000-7fbbf1283000 ---p 0009e000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7fbbf1283000-7fbbf1287000 r--p 0009e000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7fbbf1287000-7fbbf1288000 rw-p 000a2000 08:02 2631614 /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7.1.0
7fbbf1288000-7fbbf1375000 r-xp 00000000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7fbbf1375000-7fbbf1575000 ---p 000ed000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7fbbf1575000-7fbbf157b000 r--p 000ed000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7fbbf157b000-7fbbf157c000 rw-p 000f3000 08:02 2631611 /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7.1.0
7fbbf157c000-7fbbf157d000 rw-p 00000000 00:00 0
7fbbf157d000-7fbbf1596000 r-xp 00000000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7fbbf1596000-7fbbf1795000 ---p 00019000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7fbbf1795000-7fbbf1796000 r--p 00018000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7fbbf1796000-7fbbf1798000 rw-p 00019000 08:02 2628609 /usr/lib/x86_64-linux-gnu/libtbbmalloc.so.2
7fbbf1798000-7fbbf17bb000 rw-p 00000000 00:00 0
7fbbf17bb000-7fbbf17f2000 r-xp 00000000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7fbbf17f2000-7fbbf19f2000 ---p 00037000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7fbbf19f2000-7fbbf19f3000 r--p 00037000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7fbbf19f3000-7fbbf19f5000 rw-p 00038000 08:02 2628611 /usr/lib/x86_64-linux-gnu/libtbb.so.2
7fbbf19f5000-7fbbf19f8000 rw-p 00000000 00:00 0
7fbbf19f8000-7fbbf1d0e000 r-xp 00000000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7fbbf1d0e000-7fbbf1f0e000 ---p 00316000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7fbbf1f0e000-7fbbf1f17000 r--p 00316000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7fbbf1f17000-7fbbf1f20000 rw-p 0031f000 08:02 2631618 /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7.1.0
7fbbf1f20000-7fbbf1f23000 rw-p 00000000 00:00 0
7fbbf1f23000-7fbbf1f7a000 r-xp 00000000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7fbbf1f7a000-7fbbf217a000 ---p 00057000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7fbbf217a000-7fbbf217c000 r--p 00057000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7fbbf217c000-7fbbf217d000 rw-p 00059000 08:02 2627523 /usr/lib/x86_64-linux-gnu/libTKPrim.so.7.1.0
7fbbf217d000-7fbbf22d2000 r-xp 00000000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7fbbf22d2000-7fbbf24d1000 ---p 00155000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7fbbf24d1000-7fbbf24d5000 r--p 00154000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7fbbf24d5000-7fbbf24d7000 rw-p 00158000 08:02 2627323 /usr/lib/x86_64-linux-gnu/libTKOffset.so.7.1.0
7fbbf24d7000-7fbbf2974000 r-xp 00000000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7fbbf2974000-7fbbf2b74000 ---p 0049d000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7fbbf2b74000-7fbbf2b7a000 r--p 0049d000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7fbbf2b7a000-7fbbf2bbc000 rw-p 004a3000 08:02 2622816 /usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.1.0
7fbbf2bbc000-7fbbf2bc1000 rw-p 00000000 00:00 0
7fbbf2bc1000-7fbbf30f5000 r-xp 00000000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7fbbf30f5000-7fbbf32f5000 ---p 00534000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7fbbf32f5000-7fbbf32fe000 r--p 00534000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7fbbf32fe000-7fbbf3300000 rw-p 0053d000 08:02 2627437 /usr/lib/x86_64-linux-gnu/libTKGeomAlgo.so.7.1.0
7fbbf3300000-7fbbf3301000 rw-p 00000000 00:00 0
7fbbf3301000-7fbbf35c9000 r-xp 00000000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7fbbf35c9000-7fbbf37c9000 ---p 002c8000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7fbbf37c9000-7fbbf37cf000 r--p 002c8000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7fbbf37cf000-7fbbf37d1000 rw-p 002ce000 08:02 2627521 /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7.1.0
7fbbf37d1000-7fbbf38b8000 r-xp 00000000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7fbbf38b8000-7fbbf3ab7000 ---p 000e7000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7fbbf3ab7000-7fbbf3abc000 r--p 000e6000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7fbbf3abc000-7fbbf3abd000 rw-p 000eb000 08:02 2625845 /usr/lib/x86_64-linux-gnu/libTKBRep.so.7.1.0
7fbbf3abd000-7fbbf3abe000 rw-p 00000000 00:00 0
7fbbf3abe000-7fbbf3ce0000 r-xp 00000000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7fbbf3ce0000-7fbbf3edf000 ---p 00222000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7fbbf3edf000-7fbbf3ee7000 r--p 00221000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7fbbf3ee7000-7fbbf3ee9000 rw-p 00229000 08:02 2627484 /usr/lib/x86_64-linux-gnu/libTKBO.so.7.1.0
7fbbf3ee9000-7fbbf42e1000 r-xp 00000000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7fbbf42e1000-7fbbf44e1000 ---p 003f8000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7fbbf44e1000-7fbbf44e8000 r--p 003f8000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7fbbf44e8000-7fbbf44eb000 rw-p 003ff000 08:02 2627520 /usr/lib/x86_64-linux-gnu/libTKBool.so.7.1.0
7fbbf44eb000-7fbbf475c000 r-xp 00000000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7fbbf475c000-7fbbf495b000 ---p 00271000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7fbbf495b000-7fbbf4965000 r--p 00270000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7fbbf4965000-7fbbf4966000 rw-p 0027a000 08:02 2631616 /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7.1.0
7fbbf4966000-7fbbf4978000 rw-p 00000000 00:00 0
7fbbf4978000-7fbbf4bf0000 r-xp 00000000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7fbbf4bf0000-7fbbf4df0000 ---p 00278000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7fbbf4df0000-7fbbf4df6000 r--p 00278000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7fbbf4df6000-7fbbf4df8000 rw-p 0027e000 08:02 2627531 /usr/lib/x86_64-linux-gnu/libTKShHealing.so.7.1.0
7fbbf4df8000-7fbbf4df9000 rw-p 00000000 00:00 0
7fbbf4df9000-7fbbf4e1c000 r-xp 00000000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7fbbf4e1c000-7fbbf501c000 ---p 00023000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7fbbf501c000-7fbbf501d000 r--p 00023000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7fbbf501d000-7fbbf501e000 rw-p 00024000 08:02 2631619 /usr/lib/x86_64-linux-gnu/libTKSTL.so.7.1.0
7fbbf501e000-7fbbf53e3000 r-xp 00000000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7fbbf53e3000-7fbbf55e2000 ---p 003c5000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7fbbf55e2000-7fbbf55f0000 r--p 003c4000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7fbbf55f0000-7fbbf55f2000 rw-p 003d2000 08:02 2631519 /usr/lib/x86_64-linux-gnu/libTKIGES.so.7.1.0
7fbbf55f2000-7fbbf55f4000 rw-p 00000000 00:00 0
7fbbf55f4000-7fbbf5831000 r-xp 00000000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7fbbf5831000-7fbbf5a30000 ---p 0023d000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7fbbf5a30000-7fbbf5a3a000 r--p 0023c000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7fbbf5a3a000-7fbbf5a3b000 rw-p 00246000 08:02 2621937 /usr/lib/x86_64-linux-gnu/libTKMath.so.7.1.0
7fbbf5a3b000-7fbbf5a3c000 rw-p 00000000 00:00 0
7fbbf5a3c000-7fbbf5b58000 r-xp 00000000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7fbbf5b58000-7fbbf5d58000 ---p 0011c000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7fbbf5d58000-7fbbf5d5d000 r--p 0011c000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7fbbf5d5d000-7fbbf5d5e000 rw-p 00121000 08:02 2625090 /usr/lib/x86_64-linux-gnu/libTKG3d.so.7.1.0
7fbbf5d5e000-7fbbf5dc8000 r-xp 00000000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7fbbf5dc8000-7fbbf5fc8000 ---p 0006a000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7fbbf5fc8000-7fbbf5fcb000 r--p 0006a000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7fbbf5fcb000-7fbbf5fcc000 rw-p 0006d000 08:02 2625598 /usr/lib/x86_64-linux-gnu/libTKG2d.so.7.1.0
7fbbf5fcc000-7fbbf614c000 r-xp 00000000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7fbbf614c000-7fbbf634c000 ---p 00180000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7fbbf634c000-7fbbf6351000 r--p 00180000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7fbbf6351000-7fbbf6352000 rw-p 00185000 08:02 2621908 /usr/lib/x86_64-linux-gnu/libTKernel.so.7.1.0
7fbbf6352000-7fbbf6357000 rw-p 00000000 00:00 0
7fbbf6357000-7fbbf63e9000 r-xp 00000000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7fbbf63e9000-7fbbf65e9000 ---p 00092000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7fbbf65e9000-7fbbf65ec000 r--p 00092000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7fbbf65ec000-7fbbf65ed000 rw-p 00095000 08:02 2627519 /usr/lib/x86_64-linux-gnu/libTKMesh.so.7.1.0
7fbbf65ed000-7fbbf685d000 r-xp 00000000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7fbbf685d000-7fbbf6a5d000 ---p 00270000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7fbbf6a5d000-7fbbf6a63000 r--p 00270000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7fbbf6a63000-7fbbf6a65000 rw-p 00276000 08:02 2627532 /usr/lib/x86_64-linux-gnu/libTKFillet.so.7.1.0
7fbbf6a65000-7fbbf6a66000 rw-p 00000000 00:00 0
7fbbf6a66000-7fbbf6a6e000 rw-s 107827000 00:06 357 /dev/dri/card0
7fbbf6a6e000-7fbbf6aae000 rw-p 00000000 00:00 0
7fbbf6aae000-7fbbf6ec9000 r-xp 00000000 08:02 2623807 /usr/lib/freecad-daily/lib/Part.so
7fbbf6ec9000-7fbbf70c9000 ---p 0041b000 08:02 2623807 /usr/lib/freecad-daily/lib/Part.so
7fbbf70c9000-7fbbf70da000 r--p 0041b000 08:02 2623807 /usr/lib/freecad-daily/lib/Part.so
7fbbf70da000-7fbbf70f1000 rw-p 0042c000 08:02 2623807 /usr/lib/freecad-daily/lib/Part.so
7fbbf70f1000-7fbbf7173000 rw-p 00000000 00:00 0
7fbbf7173000-7fbbf71eb000 r-xp 00000000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7fbbf71eb000-7fbbf73ea000 ---p 00078000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7fbbf73ea000-7fbbf73eb000 r--p 00077000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7fbbf73eb000-7fbbf7426000 rw-p 00078000 08:02 3025732 /usr/local/lib/python2.7/dist-packages/numpy/random/mtrand.so
7fbbf7426000-7fbbf7467000 rw-p 00000000 00:00 0
7fbbf7467000-7fbbf7470000 r-xp 00000000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7fbbf7470000-7fbbf766f000 ---p 00009000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7fbbf766f000-7fbbf7670000 r--p 00008000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7fbbf7670000-7fbbf7671000 rw-p 00009000 08:02 3161170 /usr/local/lib/python2.7/dist-packages/numpy/fft/fftpack_lite.so
7fbbf7671000-7fbbf7672000 r-xp 00000000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7fbbf7672000-7fbbf7871000 ---p 00001000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7fbbf7871000-7fbbf7872000 r--p 00000000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7fbbf7872000-7fbbf7873000 rw-p 00001000 08:02 2758122 /usr/lib/python2.7/lib-dynload/future_builtins.x86_64-linux-gnu.so
7fbbf7873000-7fbbf7895000 r-xp 00000000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7fbbf7895000-7fbbf7a94000 ---p 00022000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7fbbf7a94000-7fbbf7a95000 r--p 00021000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7fbbf7a95000-7fbbf7a96000 rw-p 00022000 08:02 3161120 /usr/local/lib/python2.7/dist-packages/numpy/linalg/_umath_linalg.so
7fbbf7a96000-7fbbf7ad4000 r-xp 00000000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7fbbf7ad4000-7fbbf7cd3000 ---p 0003e000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7fbbf7cd3000-7fbbf7cd4000 r--p 0003d000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7fbbf7cd4000-7fbbf7cd5000 rw-p 0003e000 08:02 2628886 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7fbbf7cd5000-7fbbf7dfe000 r-xp 00000000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7fbbf7dfe000-7fbbf7ffd000 ---p 00129000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7fbbf7ffd000-7fbbf7ffe000 r--p 00128000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7fbbf7ffe000-7fbbf8000000 rw-p 00129000 08:02 2623129 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7fbbf8000000-7fbbf8024000 rw-p 00000000 00:00 0
7fbbf8024000-7fbbfc000000 ---p 00000000 00:00 0
7fbbfc000000-7fbbfc021000 rw-p 00000000 00:00 0
7fbbfc021000-7fbc00000000 ---p 00000000 00:00 0
7fbc00000000-7fbc00080000 rw-p 00000000 00:00 0
7fbc00080000-7fbc04000000 ---p 00000000 00:00 0
7fbc04003000-7fbc0400b000 rw-s 10781f000 00:06 357 /dev/dri/card0
7fbc0400b000-7fbc04013000 rw-s 00000000 00:05 590391 /drm mm object (deleted)
7fbc04013000-7fbc0401b000 rw-s 00000000 00:05 586645 /drm mm object (deleted)
7fbc0401b000-7fbc0402b000 rw-s 10780f000 00:06 357 /dev/dri/card0
7fbc0403b000-7fbc0462f000 r-xp 00000000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7fbc0462f000-7fbc0482e000 ---p 005f4000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7fbc0482e000-7fbc0482f000 r--p 005f3000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7fbc0482f000-7fbc04833000 rw-p 005f4000 08:02 2626125 /usr/lib/lapack/liblapack.so.3.6.0
7fbc04833000-7fbc0483b000 rw-s 00000000 00:05 590395 /drm mm object (deleted)
7fbc0483b000-7fbc0487b000 rw-p 00000000 00:00 0
7fbc0487b000-7fbc0487e000 r-xp 00000000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7fbc0487e000-7fbc04a7d000 ---p 00003000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7fbc04a7d000-7fbc04a7e000 r--p 00002000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7fbc04a7e000-7fbc04a7f000 rw-p 00003000 08:02 3161115 /usr/local/lib/python2.7/dist-packages/numpy/linalg/lapack_lite.so
7fbc04a7f000-7fbc04bbf000 rw-p 00000000 00:00 0
7fbc04bbf000-7fbc04bdd000 r-xp 00000000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7fbc04bdd000-7fbc04ddc000 ---p 0001e000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7fbc04ddc000-7fbc04ddd000 r--p 0001d000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7fbc04ddd000-7fbc04de1000 rw-p 0001e000 08:02 2752576 /usr/lib/python2.7/lib-dynload/_ctypes.x86_64-linux-gnu.so
7fbc04de1000-7fbc04e98000 r-xp 00000000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7fbc04e98000-7fbc05098000 ---p 000b7000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7fbc05098000-7fbc05099000 r--p 000b7000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7fbc05099000-7fbc0509f000 rw-p 000b8000 08:02 3161159 /usr/local/lib/python2.7/dist-packages/numpy/core/umath.so
7fbc0509f000-7fbc050a1000 rw-p 00000000 00:00 0
7fbc050a1000-7fbc0510f000 r-xp 00000000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7fbc0510f000-7fbc0530e000 ---p 0006e000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7fbc0530e000-7fbc0530f000 r--p 0006d000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7fbc0530f000-7fbc05310000 rw-p 0006e000 08:02 2626232 /usr/lib/libblas/libblas.so.3.6.0
7fbc05318000-7fbc05358000 rw-p 00000000 00:00 0
7fbc05358000-7fbc054c8000 r-xp 00000000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7fbc054c8000-7fbc056c7000 ---p 00170000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7fbc056c7000-7fbc056c9000 r--p 0016f000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7fbc056c9000-7fbc056d6000 rw-p 00171000 08:02 3161152 /usr/local/lib/python2.7/dist-packages/numpy/core/multiarray.so
7fbc056d6000-7fbc05728000 rw-p 00000000 00:00 0
7fbc05728000-7fbc0579f000 rw-s 00000000 00:05 33652757 /SYSV00000000 (deleted)
7fbc0579f000-7fbc0589f000 rw-p 00000000 00:00 0
7fbc0589f000-7fbc058a4000 r-xp 00000000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7fbc058a4000-7fbc05aa4000 ---p 00005000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7fbc05aa4000-7fbc05aa5000 r--p 00005000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7fbc05aa5000-7fbc05aa6000 rw-p 00006000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7fbc05aa6000-7fbc05aa7000 ---p 00000000 00:00 0
7fbc05aa7000-7fbc062a7000 rw-p 00000000 00:00 0
7fbc062a7000-7fbc062a8000 ---p 00000000 00:00 0
7fbc062a8000-7fbc06aa8000 rw-p 00000000 00:00 0
7fbc06aa8000-7fbc06aa9000 ---p 00000000 00:00 0
7fbc06aa9000-7fbc0788f000 rw-p 00000000 00:00 0
7fbc07896000-7fbc0789e000 rw-s 00000000 00:05 590405 /drm mm object (deleted)
7fbc0789e000-7fbc078a6000 rw-s 1077ff000 00:06 357 /dev/dri/card0
7fbc078ae000-7fbc078b6000 rw-s 00000000 00:05 590392 /drm mm object (deleted)
7fbc078b6000-7fbc078be000 rw-s 1077f7000 00:06 357 /dev/dri/card0
7fbc078be000-7fbc078c6000 rw-s 00000000 00:05 590403 /drm mm object (deleted)
7fbc078c6000-7fbc078ce000 rw-s 1077ef000 00:06 357 /dev/dri/card0
7fbc078ce000-7fbc078d6000 rw-s 1077e7000 00:06 357 /dev/dri/card0
7fbc078d6000-7fbc078de000 rw-s 00000000 00:05 590401 /drm mm object (deleted)
7fbc078de000-7fbc078e6000 rw-s 1077df000 00:06 357 /dev/dri/card0
7fbc078e6000-7fbc078ee000 rw-s 1077d7000 00:06 357 /dev/dri/card0
7fbc078ee000-7fbc078f6000 rw-s 00000000 00:05 590922 /drm mm object (deleted)
7fbc078f6000-7fbc078fe000 rw-s 1077cf000 00:06 357 /dev/dri/card0
7fbc0790e000-7fbc07916000 rw-s 00000000 00:05 590399 /drm mm object (deleted)
7fbc07916000-7fbc0791e000 rw-s 1077c7000 00:06 357 /dev/dri/card0
7fbc0791e000-7fbc0792e000 rw-s 00000000 00:05 590337 /drm mm object (deleted)
7fbc0792e000-7fbc07936000 rw-s 1077bf000 00:06 357 /dev/dri/card0
7fbc07936000-7fbc0793e000 rw-s 00000000 00:05 590397 /drm mm object (deleted)
7fbc07946000-7fbc0794e000 rw-s 1077af000 00:06 357 /dev/dri/card0
7fbc0794e000-7fbc07956000 rw-s 1077a7000 00:06 357 /dev/dri/card0
7fbc07956000-7fbc07966000 rw-s 107744000 00:06 357 /dev/dri/card0
7fbc07966000-7fbc0796e000 rw-s 10779f000 00:06 357 /dev/dri/card0
7fbc0796e000-7fbc07976000 rw-s 107797000 00:06 357 /dev/dri/card0
7fbc07976000-7fbc0797e000 rw-s 10778f000 00:06 357 /dev/dri/card0
7fbc07986000-7fbc07996000 rw-s 00000000 00:05 590421 /drm mm object (deleted)
7fbc079a6000-7fbc079b6000 rw-s 00000000 00:05 590339 /drm mm object (deleted)
7fbc079b6000-7fbc079df000 r--p 00000000 08:02 4195320 /usr/share/fonts/truetype/liberation/LiberationSans-Italic.ttf
7fbc079df000-7fbc079e0000 ---p 00000000 00:00 0
7fbc079e0000-7fbc08000000 rw-p 00000000 00:00 0
7fbc08000000-7fbc08035000 rw-p 00000000 00:00 0
7fbc08035000-7fbc0c000000 ---p 00000000 00:00 0
7fbc0c004000-7fbc0c014000 rw-s 107755000 00:06 357 /dev/dri/card0
7fbc0c014000-7fbc0c01c000 rw-s 00000000 00:05 590342 /drm mm object (deleted)
7fbc0c024000-7fbc0c12c000 rw-p 00000000 00:00 0
7fbc0c133000-7fbc0c13b000 rw-s 00000000 00:05 590326 /drm mm object (deleted)
7fbc0c143000-7fbc0c14b000 rw-s 00000000 00:05 587481 /drm mm object (deleted)
7fbc0c14b000-7fbc0c16a000 rw-p 00000000 00:00 0
7fbc0c16a000-7fbc0c1ea000 rw-s 00000000 00:05 33619987 /SYSV00000000 (deleted)
7fbc0c1ea000-7fbc0c24a000 rw-s 00000000 00:05 33587218 /SYSV00000000 (deleted)
7fbc0c24a000-7fbc0c27b000 r-xp 00000000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7fbc0c27b000-7fbc0c47a000 ---p 00031000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7fbc0c47a000-7fbc0c47b000 r--p 00030000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7fbc0c47b000-7fbc0c47c000 rw-p 00031000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7fbc0c47c000-7fbc0c48b000 r-xp 00000000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7fbc0c48b000-7fbc0c68b000 ---p 0000f000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7fbc0c68b000-7fbc0c68c000 r--p 0000f000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7fbc0c68c000-7fbc0c68d000 rw-p 00010000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7fbc0c68d000-7fbc0c6cf000 r-xp 00000000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7fbc0c6cf000-7fbc0c8cf000 ---p 00042000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7fbc0c8cf000-7fbc0c8d1000 r--p 00042000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7fbc0c8d1000-7fbc0c8d2000 rw-p 00044000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7fbc0c8d2000-7fbc0c8d3000 ---p 00000000 00:00 0
7fbc0c8d3000-7fbc0d0d3000 rw-p 00000000 00:00 0
7fbc0d0d3000-7fbc0d18c000 r--p 00000000 08:02 4195278 /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf
7fbc0d18c000-7fbc0d238000 r--p 00000000 08:02 4195277 /usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf
7fbc0d238000-7fbc0d338000 rw-p 00000000 00:00 0
7fbc0d338000-7fbc0d8cb000 rw-p 00000000 00:00 0
7fbc0d8cb000-7fbc0d8cc000 ---p 00000000 00:00 0
7fbc0d8cc000-7fbc0e0cc000 rw-p 00000000 00:00 0
7fbc0e0cc000-7fbc0e0d6000 r--p 00000000 08:02 4196320 /usr/share/icons/hicolor/icon-theme.cache
7fbc0e0d6000-7fbc0e0f2000 r--p 00000000 08:02 3804653 /usr/share/icons/gnome/icon-theme.cache
7fbc0e0f2000-7fbc0e0f3000 ---p 00000000 00:00 0
7fbc0e0f3000-7fbc4e0f3000 rwxp 00000000 00:00 0
7fbc4e0f3000-7fbc4e0f4000 ---p 00000000 00:00 0
7fbc4e0f4000-7fbc4e234000 rw-p 00000000 00:00 0
7fbc879d4000-7fbc879d5000 rw-s 107743000 00:06 357 /dev/dri/card0
7fbc879d5000-7fbc879d6000 rw-p 00000000 00:00 0
7fbc879d6000-7fbc879ee000 rw-p 00000000 00:00 0
7fbc879ee000-7fbc87a04000 r--p 00000000 08:02 4332675 /usr/share/texmf/fonts/opentype/public/tex-gyre/texgyrecursor-bold.otf
7fbc87a04000-7fbc87aaf000 rw-p 00000000 00:00 0
7fbc87aaf000-7fbc87ab0000 r--s 00000000 08:02 5247624 /home/user/.cache/fontconfig/95d412832590ff3c210ec388f2cda8e2-le64.cache-6
7fbc87ab0000-7fbc87af0000 rw-p 00000000 00:00 0
7fbc87af0000-7fbc87af7000 r--s 00000000 08:02 3038381 /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache
7fbc87af7000-7fbc87afa000 rw-p 00000000 00:00 0
7fbc87afa000-7fbc87afb000 r--p 00025000 08:02 1062755 /lib/x86_64-linux-gnu/ld-2.23.so
7fbc87afb000-7fbc87afc000 rw-p 00026000 08:02 1062755 /lib/x86_64-linux-gnu/ld-2.23.so
7fbc87afc000-7fbc87afd000 rw-p 00000000 00:00 0
7ffd77eaf000-7ffd77edd000 rw-p 00000000 00:00 0 [stack]
7ffd77fe9000-7ffd77feb000 r--p 00000000 00:00 0 [vvar]
7ffd77feb000-7ffd77fed000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
user1234
Posts: 3512 Joined: Mon Jul 11, 2016 5:08 pm
Post
by user1234 » Thu Mar 16, 2017 5:01 pm
Sorry for my fail.
HoWil wrote:
change to Part-Design-wb
Create body
Create additive box
Select XY-Plane and Z-Axis for Attachment (does also work with XZ and Y)
Extra placement: X: -5mm, Y: -5mm, Z: -5mm
Leave dialogue with OK
Select Subractive-Sphere (Subtractive-Box is working)
Is that now right (here with section view)?
Worked also.
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10490 (Git)
Build type: Unknown
Hash: 378f99f1b318202db3bc89b45d691a0376d07512
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
Also with a bigger radius.
If i make a mistake again, please let me know. I am in a few hours available.
I hope that helped.
Greeings user1234
HoWil
Posts: 1279 Joined: Sun Jun 14, 2015 7:31 pm
Post
by HoWil » Fri Mar 17, 2017 3:12 pm
user1234 wrote: Sorry for my fail.
No worries. Thanks for your effort! Until now is the problem solved after a clean reinstall and hopefully it will stay so.
BR
Howil
NormandC
Posts: 18589 Joined: Sat Feb 06, 2010 9:52 pm
Post
by NormandC » Sat Mar 18, 2017 6:03 am
HoWil wrote: Did you test it with standard radius of 5mm?
BR,
HoWil
My reply may not be relevant anymore, but FYI, I did. It is in fact the default radius for spheres in PD.
