Debug build of FreeCAD crashes on startup (TabBar, fcgear and some other addons involved)
looo
Re: Debug build of FreeCAD crashes on startup (TabBar seems to cause it)
Post by looo »
fcgear (module) is clashing with fcgear from part-design. But I don't know if this is a problem here. Maybe using svg as workbench icons?
Founder
Post by wmayer »
8 Gui::Application::activateWorkbench Application.cpp 936 0x7fff454671d5
Check the argument of the activateWorkbench. Then we might know more.
DeepSOIC
Post by DeepSOIC »
Hmm, interesting. I just removed the lock that removed the crash, and got a broken UI but no crash. So these two things are not directly related as I kind of assumed...
DeepSOIC
Post by DeepSOIC »
Now I restored my old cfg files, and I have the crash back.
	Locals
		lock	<not in scope>	Base::PyGILStateLocker
		name	0x3a0f96e110 "PartWorkbench"	char *
		ok	false	bool
		oldWb	0x2395123b730	Gui::Workbench *
		pcOldWorkbench	0x0	_object *
		pcWorkbench	<not in scope>	_object *
		this	0x3a0f96dc20	Gui::Application *
		wc	class Gui::WaitCursor	Gui::WaitCursor
	Inspector
	Expressions
	returned value
	Tooltip
DeepSOIC
Post by DeepSOIC »
My config files, which had never been deleted since my first install of FreeCAD, it was FC v0.14.
deepsoic config.zip
(9.39 KiB) Downloaded 30 times
DeepSOIC
Post by DeepSOIC »
Strangeness continues. Now I removed fcgear and the crash is gone. :shock: :?
It feels like everything is involved in this crash somehow:
* fcgear
* tabbar (todo: check)
* other add-on modules, not clear which exactly (todo:check) assembly2, or freecad-nurbs
* my 3-year-old freecad config files
* debug build
* luck?
Is it worth spending more effort on this? I don't think so. I just disable fcgear for now. It removes the crash and the faulty behavior of UI, and I'm not using it so far anyway...
DeepSOIC
Post by DeepSOIC »
triplus wrote:Can you test if the crash occurs when using official Windows daily build?
Tested. Works fine with all modules in. No crash, no broken UI.
Version: 0.17.10647 (Git)
Hash: 7901cf7ad28952173ec8e2a55c39e8eb5c441e3c
Python version: 2.7.8
OCC version: 7.0.0
triplus
Post by triplus »
Yes. And if my assumption was correct it should also work normally with the debug build. Maybe @sgrogan could provide debug build and you could do a test. If everything would work normally you likely just borked your build a bit. And the crash is only a symptom of that. Debugging the crash would therefore likely be a waste of time. With a bit of luck a new clean (debug) build on your side should do it.
