Debug build of FreeCAD crashes on startup (TabBar, fcgear and some other addons involved)
DeepSOIC
Post by DeepSOIC »
Hi!
I'm recently having trouble running debug build of FreeCAD, because it crashes on start-up with this printed to terminal (in Qt creator):
Starting T:\_vt\dev\PC\Qt\FreeCAD\build-debug\bin\FreeCAD_d.exe...
Fatal Python error: PyThreadState_Get: no current thread
The program has unexpectedly finished.
T:\_vt\dev\PC\Qt\FreeCAD\build-debug\bin\FreeCAD_d.exe crashed
The problem happens in activateWorkbench:
0	DebugBreak	KERNELBASE		0x7fff7e946142
1	Py_FatalError	pythonrun.c	1701	0x1e27688d
2	PyThreadState_Get	pystate.c	332	0x1e254fca
3	PyObject_RichCompare	object.c	949	0x1e180568
4	PyObject_RichCompareBool	object.c	1004	0x1e1807c4
5	lookdict	dictobject.c	342	0x1e14125c
6	PyDict_GetItem	dictobject.c	743	0x1e13dc86
7	PyDict_GetItemString	dictobject.c	2425	0x1e13dceb
8	Gui::Application::activateWorkbench	Application.cpp	936	0x7fff454671d5
9	Gui::Application::runApplication	Application.cpp	1724	0x7fff4546be45
10	main	MainGui.cpp	239	0x7ff6b1a435c5
11	WinMain	FreeCAD_d		0x7ff6b1a532d1
12	__tmainCRTStartup	crtexe.c	618	0x7ff6b1a51391
13	WinMainCRTStartup	crtexe.c	466	0x7ff6b1a5110e
14	BaseThreadInitThunk	KERNEL32		0x7fff81d48364
15	RtlUserThreadStart	ntdll		0x7fff81e570d1
This seems to depend on how many add-on modules I have installed. For example, if I have freecad-nurbs by microelly installed, it crashes every time. But if I uninstall it, it starts up OK about 70% of the time. If I run it with debugger attached, it crashes more often.
I tried adding a Base::PyGILStateLocker lock; to the if-block where old workbench is being queried, and it fixes the crash. But then instead of the crash, I get broken UI in main window with about the same hit frequency as the crash used to happen with. I have a small frame which obscures File menu, and with all toolbars hidden (I can unhide them through View->Toolbars).
This has been happening for quite a while already. Also, it seems to be otherwise sensitive
Any ideas?
forgot this initially :oops:
Version: 0.17.10642 (Git)
Build type: Debug
Branch: PyInterface1
Hash: 1cd7463b0c077b1fdd30347c8f3e556b3eaba82f
Python version: 2.7.8
OCC version: 7.0.0
DeepSOIC
Re: Debug build of FreeCAD crashes on startup
Post by DeepSOIC »
I think it is somehow related to triplus' TabBar. I have disabled it, and no crash/UI loss so far...
triplus
Post by triplus »
DeepSOIC wrote:I think it is somehow related to triplus' TabBar. I have disabled it, and no crash/UI loss so far...
Surely not? ;)
Could you please do a test for me. Temporary remove all 3'rd party modules from your user Mod folder. And move user.cfg and system.cfg files to a different location. Install TabBar:
https://github.com/triplus/TabBar
Start FreeCAD. Does the issue persist?
DeepSOIC
Re: Debug build of FreeCAD crashes on startup (TabBar seems to cause it)
Post by DeepSOIC »
If I do it, the issue is gone, but my start-up workbench has changed to no workbench (I don't have Start wb in my build)... and tabbar doesn't appear.
After setting things up, it seems to work fine. I'll check what happens if I re-enable add-ons one-by-one...
DeepSOIC
Post by DeepSOIC »
Started to happen when I added fcgear now. List of add-ons in Mod so far:
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\assembly2"
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\disabled" <-- folder that I move stuff into to disable it, shouldn't have listed it here :oops:
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\fcgear"
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\freecad-nurbs"
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\Lattice2"
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\tabbar"
Update: now I have enabled everything but fcgear, and no problem.
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\long_load"
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\Overlap"
"C:\Users\User\AppData\Roaming\FreeCAD\Mod\Part-o-magic"
Update:
TabBar + FCGear alone = no problem...
Update.
Tabbar + FCGear + freecad-nurbs = PROBLEM
Update. PROBLEM:
I don't seem to notice any reliable pattern so far. Maybe it's just making a fool out of me :P
Update.
assembly2+fcgear+tabbar = PROBLEM
Lattie2+fcgear+tabbar = no problem
Part-o-magic+fcgear+tabbar = no problem
EDIT: "PROBLEM" = broken UI. I've been doing these tests with GIL lock added to code, so no crashes...
triplus
Post by triplus »
Can you test if the crash occurs when using official Windows daily build? To i guess rule out any potential Python 3 port changes (although it isn't debug build). But my feeling is telling me your current build has some sort of Python versions clash going on.
P.S. I likely won't be able to do any more tests (if new info will be provided) before in between 12 to 48 hours.
DeepSOIC
Post by DeepSOIC »
Now I experimented a bit with workbench code. Removing resource imports in InitGui from either Assembly2 or FCGear removes the problem. But PartOMagic loads resources in InitGui too, so why doesn't it contribute to the problem?.. and what is so special about fcgear?.. :?
DeepSOIC
Post by DeepSOIC »
triplus wrote:Can you test if the crash occurs when using official Windows daily build?
It never happens in release builds.
triplus
Post by triplus »
I have debug build available but don't have access to the PC with it ATM. Likely in around 12 hours time i will be able to test the combination of modules that causes issues for you in combination with FreeCAD 0.17 (debug build).
triplus
Post by triplus »
DeepSOIC wrote:assembly2+fcgear+tabbar = PROBLEM
I tested this scenario under FreeCAD 0.17 debug build (Ubuntu 16.04) and i can not confirm the crash. I did another test and added freecad-nurbs, Lattice2 and Part-o-magic modules to the mix and no crash occurred. I changed start up workbench to few options in Preferences.
triplus wrote:But my feeling is telling me your current build has some sort of Python versions clash going on.
Can you do a new fresh build (to leave out all the cache stuff and things like that). And after test the behaviour when all mentioned modules are installed.
