Text output (mainly stderr) from macros
I find the text output situation from macros in FreeCAD to be a bit confusing and would like to rationalise it, but don't want to break existing desired behaviour, so would like to get your thoughts.
We currently have 3 different places that a script's stderr and stdout can go from a macro; the executable itself, the Report View, and the Python console. There are two main ways to invoke a macro; the Execute Macro dialog (or the equivalent(?) green arrow button), or the Python console via execfile().
There are two settings to redirect Python output/errors to the Report View, but from what I can tell these only affect macros that are run via Execute Macro - if execfile() is used from the Python Console, then stdout and stderr both only go to the Python Console. Any Python output shown in the Report View also appears as stdout from the executable.
So, I've got some questions/proposals:
1 - Currently, both stderr and stdout from Python's are sent out of the FreeCAD executable's stdout. I think it should not merge stderr in to stdout implicitly.
2 - Wouldn't it be a bit more conventional if Python's stderr were sent out from the FreeCAD executable (via stderr), regardless of GUI settings?
3 - Is there a practical scenario where someone would want the Report View to not show Python stderr? It currently shows Qt warnings, for instance, and if the redirect option is turned off then AFAICT there is no visible error output from a macro run via Execute Macro. I'm just wondering if we shouldn't remove the "Redirect internal Python errors to Report View" preference, and always behave like it's turned on.
4 - If the option(s) to redirect Python output/errors to the Report View is selected, shouldn't the redirection work regardless of whether the macro was run from the Python console or Execute Macro dialog? I would expect to see the stdout/stderr shown both in the Python Console and Report View if the redirect option(s) were selected.
5 - I think it would be good if running a macro via the Execute Macro dialog (or the green button) would cause an equivalent Python command to appear in the Python Console, to make REPL style interaction a bit more natural. Right now, exectfile() is a bit of a hidden feature.
Re: Text output (mainly stderr) from macros
Good points. I think where to show error messages originating from Python depends on which place Python has in FreeCAD.
If it's seen as something that's fully encapsulated a case can be made that error messages should only be shown inside FreeCAD's UI and not trickle down to FreeCAD's stderr.
If it's seen as a part of FreeCAD on the same level as the rest of the codebase then it's errors should trickle through to FreeCAD's stderr.
But should the same then be true for any stdout output?
I was surprised to see that none of the Python modules use Python's logging facility, instead custom Msg, Err, etc global functions seem to be used.
Seems like something that should be changed, which would then easily allow one to show/hide certain types of messages.
My feeling is that the Python interpreter is a key part of FreeCAD - it's an easy argument since substantial parts of the functionality we provide are written in Python. Even without the philosophical discussion though, it seems like our current implementation isn't self-consistent.simonvanderveldt wrote:Good points. I think where to show error messages originating from Python depends on which place Python has in FreeCAD.
That's a higher level than what I'm referring to - indeed Python's logging is a nice tool, but it's not going to be as helpful if the underlying stdout/stderr handling isn't done well.simonvanderveldt wrote: I was surprised to see that none of the Python modules use Python's logging facility, instead custom Msg, Err, etc global functions seem to be used.
Sorry, I didn't want to start a philosophical discussion But I do think it's important to make sure that there's a shared view on a high level, that makes it a lot easier to make these lower level/technical decisions.ian.rees wrote:My feeling is that the Python interpreter is a key part of FreeCAD - it's an easy argument since substantial parts of the functionality we provide are written in Python. Even without the philosophical discussion though, it seems like our current implementation isn't self-consistent.simonvanderveldt wrote:Good points. I think where to show error messages originating from Python depends on which place Python has in FreeCAD.
Regarding your points:
When Python is seen as an integral part of FreeCAD it makes sense to always output errors to FreeCAD's stderr.ian.rees wrote:1 - Currently, both stderr and stdout from Python's are sent out of the FreeCAD executable's stdout. I think it should not merge stderr in to stdout implicitly.
Merging of stdout and stderr should of course never happen.
If a user can do something that fails/causes an error and that user isn't notified of that error that seems like bad UX to me.ian.rees wrote:3 - Is there a practical scenario where someone would want the Report View to not show Python stderr? It currently shows Qt warnings, for instance, and if the redirect option is turned off then AFAICT there is no visible error output from a macro run via Execute Macro. I'm just wondering if we shouldn't remove the "Redirect internal Python errors to Report View" preference, and always behave like it's turned on.
Your suggestion to always enable forwarding Python errors to the report view would make sense to fix this. On the other hand it's also already shown in the Python console.
It seems like no normal output from the Python console (including error messages) gets posted to the Report view.
Only when calling the FreeCAD specific functions like Msg the output is only shown in the Report View, and only in the Report View it's not shown in the Python console in that case.
Personally I don't really see the need for the Report View, I prefer to have my output only in the console. Though I guess opinions will differ on that
+1 for consistencyian.rees wrote:5 - I think it would be good if running a macro via the Execute Macro dialog (or the green button) would cause an equivalent Python command to appear in the Python Console, to make REPL style interaction a bit more natural. Right now, exectfile() is a bit of a hidden feature.
Though it seems like Execute macro actually does something different than just a simple execfile()
https://github.com/FreeCAD/FreeCAD/blob ... o.cpp#L248
https://github.com/FreeCAD/FreeCAD/blob ... r.cpp#L318
It would be bit strange wouldn't it. If the code not interpreted in the Python console would redirect the output to the Python console?ian.rees wrote:I would expect to see the stdout/stderr shown both in the Python Console and Report View if the redirect option(s) were selected.
I don't think it would be any stranger than the Report View.triplus wrote:It would be bit strange wouldn't it. If the code not interpreted in the Python console would redirect the output to the Python console?ian.rees wrote:I would expect to see the stdout/stderr shown both in the Python Console and Report View if the redirect option(s) were selected.
But, that's not the main point of #4. I was suggesting that if the setting to redirect errors/output to report view is turned ON, then errors/output from the Python Console should appear in the Python Console AND in the report view. As things are now, the redirect settings are effectively ignored for code executed via the Python Console, which I think is inconsistent.
Right, it's a silent failure, which is no good, if the redirection settings aren't enabled. But, output is not already shown in the Python console when run via Execute Macro (I forgot to put that in the OP).simonvanderveldt wrote: If a user can do something that fails/causes an error and that user isn't notified of that error that seems like bad UX to me.
I think it effectively does the same thing, barring the redirection stuff which I think needs some attention. But, the implementation details don't really matter - the point is that the Python Console should show the user (who's likely working with Python anyways) how to run their macro via the console, just like we show how to do other operations in the Python console.simonvanderveldt wrote:+1 for consistencyian.rees wrote:5 - I think it would be good if running a macro via the Execute Macro dialog (or the green button) would cause an equivalent Python command to appear in the Python Console, to make REPL style interaction a bit more natural. Right now, exectfile() is a bit of a hidden feature.
I see. Well to be honest there was a similar discussion about this area about a month back. And thinking about it again i don't really have any strong opinion on the matter. Improvements if possible in consistency and/or in just making sense. Both work for me.ian.rees wrote:I don't think it would be any stranger than the Report View.
Which perfectly makes sense because having output in the Report view and Python console doesn't have any benefit and I would find it rather annoying.There are two settings to redirect Python output/errors to the Report View, but from what I can tell these only affect macros that are run via Execute Macro - if execfile() is used from the Python Console, then stdout and stderr both only go to the Python Console.
What exactly do you consider the executable's stdout? And where is stderr merged to stdout?Currently, both stderr and stdout from Python's are sent out of the FreeCAD executable's stdout. I think it should not merge stderr in to stdout implicitly.
Well, actually the redirection is intended for developers to make functions written in Python robust enough. For a user it shouldn't happen that Python raises any errors.Is there a practical scenario where someone would want the Report View to not show Python stderr?
But only in debug mode, not in release mode. Also aimed for developers.It currently shows Qt warnings, for instance
See above. I don't see any benefit and find this annoying behaviour.I would expect to see the stdout/stderr shown both in the Python Console and Report View if the redirect option(s) were selected.
Because this is a completely different mechanism.Only when calling the FreeCAD specific functions like Msg the output is only shown in the Report View, and only in the Report View it's not shown in the Python console in that case.
Internally it uses PyRun_File of C API of Python.Though it seems like Execute macro actually does something different than just a simple execfile()
What should happen when an error does happen?wmayer wrote:Well, actually the redirection is intended for developers to make functions written in Python robust enough. For a user it shouldn't happen that Python raises any errors.
