I am using FreeCADLibs_8.2_x86_VC9.
>>> import sip
>>> print sip.__file__
C:\Users\ubrammer\FreeCAD-git\FreeCAD_sf_master\Build\bin\sip.pyd
>>> dir(sip)
['SIP_VERSION', 'SIP_VERSION_STR', '_C_API', '__doc__', '__file__', '__name__', '__package__', '_unpickle_enum', '_unpickle_type', 'cast', 'delete', 'dump', 'getapi', 'isdeleted', 'ispyowned', 'setapi', 'setdeleted', 'settracemask', 'simplewrapper', 'transferback', 'transferto', 'unwrapinstance', 'voidptr', 'wrapinstance', 'wrapper', 'wrappertype']
%define SOQT_MODULE_DOCSTRING
"The soqt module is a wrapper for the SoQt library. The module will try
to import the sip module which is used for PyQt. If found the involved
wrapped Qt structures are converted to ones suitable for PyQt,
otherwise it will fall back to regular SWIG structures."
%enddef
The error-messages were all around sip is complaining to get PySide-structures instead of PyQT-structures.
But my knowledge does not go so far, to be able to build the needed version of Pivy.
Ulrich
