PySide migration
jreinhardt
Re: PySide migration
Post by jreinhardt »
A user of BOLTS experiences some strange issues related to loading ui files. He uses:
Windows 7
Platform: 32-bit
Version: 0.14.3389
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
BOLTS fails to load a ui file called "bolts_widget.ui", the error message suggests a escaping issue:
0.14\bin\python26.zip\xml\etree\ElementTree.py", line 579, in parse <type 'exceptions.IOError'>:
[Errno 22] invalid mode ('rb') or filename: 'C:\Program Files (x86)\FreeCAD 0.14\BOLTS\gui\x08oltswidget.ui
Apparently, the "\b" in the path gets interpreted as an escape sequence. However, I use os.path.join to construct all the paths, so everything should be properly escaped.
Further investigation suggests that the problem might be in uic
as
open(r"C:\Program Files (x86)\FreeCAD 0.14\BOLTS\gui\boltswidget.ui")
open("C:\\Program Files (x86)\\FreeCAD 0.14\\BOLTS\\gui\\boltswidget.ui")
succeed, but
uic.loadUiType(r"C:\Program Files (x86)\FreeCAD 0.14\BOLTS\gui\boltswidget.ui")
uic.loadUiType("C:\\Program Files (x86)\\FreeCAD 0.14\\BOLTS\\gui\\boltswidget.ui")
fail with the aforementioned error.
Looking at the PySideUicModule code (src/Gui/WidgetFactory.cpp:445), I believe escaping might be lost when constructing the python script in-memory.
Now I am not sure about how to best work around this. Just replacing the backslashes to forward slashes might work, as apparently windows recognises them as path separators.
BOLTS, standard parts library for FreeCAD Thread, Help with Translation
Founder
Post by wmayer »
git commit 8dbbdd3 fixes the issue by replacing backslashes with slashes. The reason for the failure of the backslashes is that the path internally goes through Python and thus loses one backslash. And then it goes through Python calls again and then the simple backslashes are handled as escape sequences.
jreinhardt
Thanks a lot.
jmaustpc
Post by jmaustpc »
Hi all
I have updated this wiki page section which was previously PyQt4 to PySide. If I should not have done so, then someone can click "undo" ... or re-edit the wiki page. :)
http://www.freecadweb.org/wiki/index.ph ... y_PyQt4.29
1) could a Mac person tell me what to put in the Mac section please? Can I just simply change "PyQt in Home Brew" reference, to PySide or not....?
2) Can one of you RPM based distro people check what the package name typically is for PySide in the common RPM based distros? This is a link to the paragraph in question. http://www.freecadweb.org/wiki/index.ph ... ules#Linux
3) I left the PyQt4 tutorial links at the bottom for now as I though they could probably still be of some value (considering the similarities between PyQt4 and PySide)....if someone wants to post some links for something similar in PySide I will happily add them to the wiki and, if appropriate, I can delete the older PyQt4 at some point in the future.
Jim
mario52
Post by mario52 »
hi
in addition to changing all PyQt4 in PySide
here few some modifications to adapt PyQt4 to PySide (observed in my macro)
unicode :
#        text = unicode(text, 'ISO-8859-1').encode('UTF-8') # PyQt4
change by
       text = text.encode('utf-8')                         # PySide
________________________________________________
QFileDialog : getOpenFileName
#        OpenName = QFileDialog.getOpenFileName(None,QString.fromLocal8Bit("Read a txt file"),path,"*.FCInfo *.txt")            # PyQt4
change by
        OpenName, Filter = PySide.QtGui.QFileDialog.getOpenFileName(None, "Read a txt file", path, "*.FCInfo *.txt")  # PySide
QFileDialog : getSaveFileName
#        SaveName = QFileDialog.getSaveFileName(None,QString.fromLocal8Bit("Save a file FCInfo"),path,"*.FCInfo")   # PyQt4
change by
        SaveName, Filter = PySide.QtGui.QFileDialog.getSaveFileName(None, "Save a file FCInfo", path, "*.FCInfo")   # PySide
test op self.pushButton (accentuated, over 128)
#        if self.pushButton_Ra.text() == "Degré":   # PyQt4
change by
        choice = self.pushButton_Ra.text()          # PySide
        choice = choice.encode('utf-8')             # PySide
        if choice == "Degré":                       # PySide
base program
#app = QtGui.qApp                                 # PyQt4
#FCmw = app.activeWindow()                        # PyQt4
change by
FCmw = FreeCADGui.getMainWindow()                 # PySide
mario
