Unknown C++ exception raised in activateWorkbench
Dear experts,
I built the latest master branch from http://git.code.sf.net/p/free-cad/code on my ubuntu 13.10 system.
When I try to switch the workbench from PartDesign to Draw or Arch, I get the error "Unknown C++ exception raised in activateWorkbench". No more information on the error is emitted.
This error occurs when I run the executable built from the master branch as well as the one of the "jriegel/dev-assembly" branch.
What might be the reason for this error? How can I get more informations?
Thanks for any hints.
Regards, Hannes
Regards, Hannes
Re: Unknown C++ exception raised in activateWorkbench
I haven't done this before. But maybe you can try stop execution right at the place where the exception is thrown.
http://stackoverflow.com/questions/1115 ... ion-occurs
http://www.radford.edu/~nokie/classes/320/gdb.html
Ah, thanks for the tip. Just tried it.
It results in 4 breaks during startup (not reported in the gui, obviously catched somewhere?) and 2 break during workbench switch:
Backtrace of the first:
#0 0x00007ffff4aa1a50 in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#1 0x00007fffefec3b20 in xercesc_3_1::IconvGNULCPTranscoder::calcRequiredSize(unsigned short const*, xercesc_3_1::MemoryManager*) ()
from /usr/lib/x86_64-linux-gnu/libxerces-c-3.1.so
#2 0x00007fffefec37bc in xercesc_3_1::IconvGNULCPTranscoder::transcode(unsigned short const*, xercesc_3_1::MemoryManager*) ()
#3 0x00007ffff6793fe9 in StrX::StrX(unsigned short const*) () from /home/hannes/Programme/freecad-official/build-master/lib/libFreeCADBase.so
#4 0x00007ffff6791b92 in ParameterGrp::FindElement(xercesc_3_1::DOMElement*, char const*, char const*) const ()
#5 0x00007ffff678e98e in ParameterGrp::GetBool(char const*, bool) const ()
#6 0x00007ffff7745625 in Gui::ToolBarManager::setup(Gui::ToolBarItem*) ()
from /home/hannes/Programme/freecad-official/build-master/lib/libFreeCADGui.so
#7 0x00007ffff7749422 in Gui::Workbench::activate() () from /home/hannes/Programme/freecad-official/build-master/lib/libFreeCADGui.so
#8 0x00007ffff7754fcd in Gui::WorkbenchManager::activate(std::string const&, std::string const&) ()
#9 0x00007ffff744c552 in Gui::Application::activateWorkbench(char const*) ()
And the second:
#1 0x00007ffff677328a in Base::InterpreterSingleton::runString(char const*) ()
#2 0x00007ffff74c692b in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) ()
#3 0x00007ffff74db928 in StdCmdWorkbench::activated(int) () from /home/hannes/Programme/freecad-official/build-master/lib/libFreeCADGui.so
#4 0x00007ffff74c61a5 in Gui::Command::invoke(int) () from /home/hannes/Programme/freecad-official/build-master/lib/libFreeCADGui.so
#5 0x00007ffff74be0d3 in Gui::ActionGroup::onActivated(QAction*) ()
#6 0x00007ffff74c2531 in Gui::ActionGroup::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) ()
#7 0x00007ffff4ed5a58 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#8 0x00007ffff563397f in QActionGroup::triggered(QAction*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#9 0x00007ffff56339ff in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#10 0x00007ffff4ed5a58 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#11 0x00007ffff5630a32 in QAction::triggered(bool) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#12 0x00007ffff5632403 in QAction::activate(QAction::ActionEvent) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#13 0x00007ffff74c2fdb in QAction::trigger() () from /home/hannes/Programme/freecad-official/build-master/lib/libFreeCADGui.so
#14 0x00007ffff74bf8ac in Gui::WorkbenchGroup::customEvent(QEvent*) ()
#15 0x00007ffff4ed9e5d in QObject::event(QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#16 0x00007ffff5636dfc in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#17 0x00007ffff563d470 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#18 0x00007ffff7455d03 in Gui::GUIApplication::notify(QObject*, QEvent*) ()
#19 0x00007ffff4ec18bd in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#20 0x00007ffff4ec4e1f in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#21 0x00007ffff4eef073 in ?? () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
Hmm, what does this tell us?
And the second:
can you extract the string parameter from the stack for the second backtrace?
Dear shoogen,
I just did a "Debug"-rebuild and repeated the steps (note: switching to Arch instead to Drawing workbench and dev-assembly branch instead of master, but seems to fail at the same location). The second backtrace then is:
#0 0x00007ffff4abba50 in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#1 0x00007ffff678b890 in Base::InterpreterSingleton::runString (this=0x645cb0, sCmd=0x201fe70 "Gui.activateWorkbench(\"ArchWorkbench\")")
at /home/hannes/Programme/freecad-official/src/Base/Interpreter.cpp:163
#2 0x00007ffff74c9875 in Gui::Command::doCommand (eType=Gui::Command::Gui, sCmd=0x7ffff79e0385 "Gui.activateWorkbench(\"%s\")")
at /home/hannes/Programme/freecad-official/src/Gui/Command.cpp:427
#3 0x00007ffff74de8b2 in StdCmdWorkbench::activated (this=0xd89f10, i=1) at /home/hannes/Programme/freecad-official/src/Gui/CommandStd.cpp:100
#4 0x00007ffff74c9133 in Gui::Command::invoke (this=0xd89f10, i=1) at /home/hannes/Programme/freecad-official/src/Gui/Command.cpp:288
#5 0x00007ffff74c0da5 in Gui::ActionGroup::onActivated (this=0xab39a0, a=0xabecf0)
at /home/hannes/Programme/freecad-official/src/Gui/Action.cpp:336
#6 0x00007ffff74c533e in Gui::ActionGroup::qt_static_metacall (_o=0xab39a0, _c=QMetaObject::InvokeMetaMethod, _id=2, _a=0x7fffffffc1f0)
at /home/hannes/Programme/freecad-official/build/src/Gui/moc_Action.cpp:129
#7 0x00007ffff4eefa58 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#8 0x00007ffff564d97f in QActionGroup::triggered(QAction*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#9 0x00007ffff564d9ff in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#10 0x00007ffff4eefa58 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#11 0x00007ffff564aa32 in QAction::triggered(bool) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#12 0x00007ffff564c403 in QAction::activate(QAction::ActionEvent) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#13 0x00007ffff74c5e21 in QAction::trigger (this=0xabecf0) at /usr/include/qt4/QtGui/qaction.h:218
#14 0x00007ffff74c25c4 in Gui::WorkbenchGroup::customEvent (this=0xab39a0, e=0x1ddf480)
at /home/hannes/Programme/freecad-official/src/Gui/Action.cpp:557
#15 0x00007ffff4ef3e5d in QObject::event(QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#16 0x00007ffff5650dfc in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#17 0x00007ffff5657470 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#18 0x00007ffff745a1f3 in Gui::GUIApplication::notify (this=0x7fffffffcf60, receiver=0xab39a0, event=0x1ddf480)
at /#0 0x00007ffff4abba50 in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
at /home/hannes/Programme/freecad-official/src/Gui/Application.cpp:1510
#19 0x00007ffff4edb8bd in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#20 0x00007ffff4edee1f in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#21 0x00007ffff4f09073 in ?? () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#22 0x00007fffee4863b6 in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
So the parameter is obviously "Gui.activateWorkbench(\"ArchWorkbench\")"
Have you tried to enter the python string on the python commandline. As it seems to have better eroor reporting then the function that handles GUI events?
I just tried. But this not more enlighting:
>>> Gui.activateWorkbench("ArchWorkbench")
Exception: Unknown C++ exception raised in activateWorkbench
I would simply abbandon the master for a moment and try if it works in version 698899e6d70d89da70f9fa205bb75a136ac63351. Because werner did something i did not understand in 7506e740e076f27f6619618ec4cda5762ec5acfb concerning the activation of Workbenches.
Ok, I did a
$ git checkout master
and then
$ git checkout 698899e6d70d89da70f9fa205bb75a136ac63351
on my working copy and recompiled everything with BUILD_TYPE "Debug"
Unfortunately, this gives the same error.
and then
sorry it was just, an idea in the mean time i complied the master version and could not reporduce your problem.
I guess you need to set a breakpoint in Base::Interpreter line 160 and singlestep through the python interpreter.
