Assembly 2 workbench for FreeCAD v0.15
triplus
Re: Assembly 2 workbench for FreeCAD v0.15
Post by triplus »
paul18 wrote:First of all thanks for the answer.
You're welcome.
It works fine but this information should be easily accessible (that's why I've been thinking in using planes at the first time).
There is always room for improvement BUT property view in FreeCAD is something that can be expected users will look at and use often.
Actually I understood that you've created separately the parts and the plane (i.e. the plane is not linked to a part), so the contexte is different than the mine!
Yes i created them separately as seen on the first image and after i used Plane Constraint between them.
terrym
Assembly 2 workbench with FreeCAD v0.16: CRASH
Post by terrym »
Hi
Using FreeCAD v0.16 as it had an easy built in installer for such modules as Assembly2.
Machine is 64 bit AMD FX, 8 cores, running Ubuntu 14.04.3, with Gnome.
Open FreeCAD, create a cylinder, save it, close FreeCAD.
Open FreeCAD, create a cone, save it, close FreeCAD.
Open FreeCAD, create a new document, switch to the Assembly2 workbench.
... Click the blue cube with the red +, imported cylinder document.
... Click the blue cube with the red +, import the cone... CRASH! Vanishes from screen immediately!
Is that how the Assembly2 workbench is to be used?
When running from a terminal window, the only error message is:
terry@terry-desktop:~$ freecad
FreeCAD 0.16, Libs: 0.16R6428 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
importing part from /home/terry/CAD/test.fcstd
importing part from /home/terry/CAD/test2.fcstd
*** Abort *** an exception was raised, but no catch was found.
... The exception is:SIGSEGV 'segmentation violation' detected. Address 0
Any ideas?
Thanks
Terry
yorik
Founder
Post by yorik »
Assembly2 is an external project, not part of the official package. Although there is no problem in discussing this here, you'll get better chances if you report this directly on the Assembl2 github page...
eivindkvedalen
Re: Assembly 2 workbench with FreeCAD v0.16: CRASH
Post by eivindkvedalen »
terrym wrote:Hi
Any ideas?
Thanks
Terry
This could be related to issue #2389, #2418, or #2436; these might all end in unexpected crashes. I'm requesting a pull request for a fix shortly.
Eivind
Science-projectsW
Post by Science-projectsW »
I find the Assembly 2 module very useful, but I have a problem with using it.
It needs a "mate planes" function as well as an "align planes" function. This is causing a problem for me on an hourly basis.
For example, say I creat an L shaped bracket.
If I then want to place them on opposite sides of a square object, [ ], I can place the first one fine. Like so: L[ ]
However, if I then import the object again, I cannot mirror it, because it tries to align the face rather than mate, and I end up with something looking (roughly) like this : L[L]
At the moment, I'm having to draw every part twice to make my assembly, which defeats the purpose of an assembly module. Even if I rotate it using the move tool, it puts it back how it started the second I try and align planes.
If anyone can offer a suggestion on how to fix this, that would be great.
Also, a way to offest alignments would be very helpful as well. For eaxmple, I cannot create a part that looks like this: |_|_| using one long base (which I will weld together in real life).
Any help will be appreciated.
-W
microelly2
Post by microelly2 »
Hello Science-projectsW and welcome to the forum,
there are lots of tools inside FreeCAD that you can use to avoid double work.
The Draft module has clones which allow to duplicat, scale and "mirror" objects.
Draft has the Array to repeat objects linear and polar.
The use of assembly2 can becomes clearer if you inspect the youtube channel of cad1919. There are some good demonstrations
Assembly2 support offsets but there are other tools too, look at the lattice2 workbench. Part Compound is an other good friend.
Look at these first and then ask your specific questions again. We will support you. :)
Science-projectsW
*Checks out a video*
*What's that button with the bolt on it, why don't I have that?*
*Finds that the "flip plane", "lock rotation", "bolt" toolbar has been hidden*
What took me an extra 2 hours of doubling up parts yesterday has just taken me 2 minutes. ARGHHHH!
CharlieMAC
Post by CharlieMAC »
microelly2 wrote: The Draft module has clones which allow to duplicat, scale and "mirror" objects.
Please note that scaled clones DO not accept sketches on planar faces anymore, since the resulting faces are based on flat splines after the scaling. Also, snapping center won't work for the same reason. This won't be solved until the sketcher supports flat spline faces.
Check this thread out:
viewtopic.php?f=3&t=14317&p=114800#p114800
Charlie
pk_rulz
Post by pk_rulz »
Hi
I am very new to FreeCAD and have a decent knowledge of Python. I dont have a background in CAD neither have I used any one before.
I would like to contribute to the Assembly2 module to bring it to more usable/production level faster. Any specific python code that you think needs help.
I am working between two jobs and might take a bit longer to contribute.
Look forward to your inputs
Cheers
PK
ickby
Post by ickby »
as the Assembly module is a community driven workbench you may have better chances of reaching the respective developers via their github side. I think there are also quite a few issues which can be a basis for start coding.
