Sketcher: Bezier curves
abdullah
Re: Sketcher: Bezier curves
Post by abdullah »
triplus wrote:The effort is ongoing here:
https://forum.freecadweb.org/viewtopic.php?f=4&t=17501
Thanks!
I am stopping the development of BSplines until our packaging experts load a working OCCT 7 version to Launchpad. From the thread, I think they are almost there. In the meantime, well, I will use FreeCAD a little bit :)
triplus
Post by triplus »
Well-earned break! :)
abdullah
Post by abdullah »
And resuming...
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10235 +20 (Git)
Build type: Debug
Branch: bspline_stage1b_2017_thirddeliverable
Hash: fb907b9cb0d6a884519949045f9f423fc302f6b4
Python version: 2.7.12
OCC version: 7.1.0
It is nice not to get a crash...
I have to find my lost context on what I have to do, but I think this third_deliverable will not have much more functionality.
My current list:
1. Fix curvature comb as indicated by Werner
2. Implement decrease knot multiplicity
3. Review return types in functions (I have some boolean returning functions that should probably better off by returning nothing and raising an exception if something happens)
4. Ask for icons and integrate icons.
5. Fix annoying bug that crashes FC when undo is effected after a multiplicity change.
6. Do something so that FC compiled against OCC<6.9.0 does not crash.
If you think I am missing something relevant speak your mind :)
triplus
Post by triplus »
abdullah wrote:If you think I am missing something relevant speak your mind :)
Nice resume. If only all Linux boxes would resume in such style. But it is getting better compared to few years back. ;)
abdullah
Post by abdullah »
I have just sorted out the code into commits and updated the branch:
https://github.com/abdullahtahiriyo/Fre ... eliverable
I do not expect testing or feedback at this time (of course if you want to update to Xenial, install Norm's libocc and compile and test and if you find any issue report it here, I am fine with that :D ). Just sorting out things.
triplus
Post by triplus »
abdullah wrote:I do not expect testing or feedback at this time (of course if you want to update to Xenial
Checked.
Nah. That ship has sailed. But looking at the horizon it's doing just OK. And that is good enough for me. ;)
It has a place on my todo list (under work in progress). ;)
Founder
Post by wmayer »
Very often the travis or AppVeyor builds fail because of this error:
ERROR: testSlotCase (TestSketcherApp.SketcherSolverTestCases)
File "C:\projects\freecad\build\Mod\Sketcher\TestSketcherApp.py", line 113, in testSlotCase
CreateSlotPlateSet(self.Slot)
File "C:\projects\freecad\build\Mod\Sketcher\TestSketcherApp.py", line 61, in CreateSlotPlateSet
SketchFeature.setDatum(9,200.000000)
ValueError: Cannot set the datum because the sketch contains conflicting constraints
If wonder why this happens and how it can be fixed.
abdullah
Post by abdullah »
wmayer wrote:Very often the travis or AppVeyor builds fail because of this error:
Aside from the obvious: delete the unit test, I will give it a try...
My current list:
7. Check Werner's solver test case issue.
saso
Post by saso »
abdullah wrote: My current list:
Since 8 is a nice number :roll: how about adding support for bezier curves to draft -> draft to sketch tool?
abdullah
Post by abdullah »
saso wrote:Since 8 is a nice number :roll: how about adding support for bezier curves to draft -> draft to sketch tool?
Draft is Python. I do not have the competence to do any decent Python. Sorry! :oops:
