Sketcher: Bezier curves
abdullah
Re: Sketcher: Bezier curves
Post by abdullah »
jean.thil wrote:Edit "sketch001". Push the "create edge link to external geometry" (I think this is the correct name in English). Click on the nurbs.
FreeCAD: /home/alain/Documents/build_FreeCAD/freecad/FreeCAD/src/Mod/Sketcher/App/planegcs/GCS.cpp :3674 : int GCS::System::diagnose(GCS::Algorithm):  l'assertion « R(i,i) != 0 » a échoué.
It crashes also if I close the nurbs, extrude the area and try to link to the edge of the extruction.
I am doing exactly that and I do not get the crash.
I am using my development branch, as the freecad-daily is not yet published and I cannot "apt-get" it (yet).
In this branch:
https://github.com/abdullahtahiriyo/Fre ... iverable_2
you should not get a crash.
Now, tomorrow I will try to install the daily build and see if it crashes there.
Soon also I will pull master and start a new branch for further development. We can also check it there...
EDIT: Update. I have just pulled master and compiled it. I do not manage to get the crash there either. Can anybody confirm?
jean.thil
Post by jean.thil »
I should have published it before.
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10232 (Git)
Build type: Unknown
Hash: 3136b42830f6da733cef1cc649760b97a6cdc836
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
triplus
Post by triplus »
As for some tests. I did a few basic tests and it works good. I like the view related control commands. I do have one question. Do you feel it would be possible and would make sense for the user being able to propagate curvature combs to the 3D View?
As if that would be possible. You can select such geometry directly after and create Drawing Views out of it:
As long as OCC version is high enough. That would therefore in addition enable the end user to observe the curvature combs in the 3D View and create drawings of splines with curvature combs.
P.S. On a bit unrelated note. And to break all this spline talk for a bit. Arc length constraint in Sketcher. Do you see something like that as a viable option in the future or as something impossible to achieve? ;)
microelly2
Post by microelly2 »
triplus wrote:P.S. On a bit unrelated note. And to break all this spline talk for a bit. Arc length constraint in Sketcher. Do you see something like that as a viable option in the future or as something impossible to achieve? ;)
I did some investigation on the dependency of length of a curve depending on one point.
The result is not realy simple https://youtu.be/526SwK8JZnw
abdullah
Post by abdullah »
jean.thil wrote:I should have published it before.
Build type: Unknown
Qt version: 4.8.6
OCC version: 7.1.0
Todays ubuntu daily has that git commit and hash. With it I can not reproduce the problem:
OS: Ubuntu 14.04.5 LTS
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
I just load your file, double click sketch001 to enter edit mode, then I select the tool to link external geometry and just go to the X axis (because the BSpline is behind it), click and I get the imported geometry, which is a line on the X axis...
abdullah
Post by abdullah »
triplus wrote:Do you feel it would be possible and would make sense for the user being able to propagate curvature combs to the 3D View?
I see the usefulness of what you propose. However, for that, I do think it is not a sketcher visualization layer anymore. It must be something more general to work inter-workbenches. For that it should probably be real geometry and not just some lines pushed directly to coin3d. I believe that is in line with what Werner was explaining, that curvature combs have a more generalized scope that the one I was giving them. We arrived to a compromise, which allows us to have curvature combs for B-Splines today, but will eventually be made into a full breadth feature when somebody invests time in providing a general curvature comb support, likely as part of a surface WB.
I agree to MicroElly's remark. It requires a very big investment for a teeny tiny benefit (IMO). What is possible today, is to ask the length of any curve from python with the GeometryCurvePy::length command. An in-the-middle idea, could be to allow a geometry information overlay for curves indicating in text their lengths. Such a tool would not be Bspline specific. Then you could make an angle constraint driven (reference constraint) and move it until you see in the information layer your wanted value and the make it driving again... I would like to know if there is interest and/or potential conflict with such an idea.
jean.thil
Post by jean.thil »
Very strange indeed. The failed assert is the the code that resolves the sketcher. It fails both in a release build and a debug build. Gonna try a full reset of the code.
Edit : still crashes
abdullah
Post by abdullah »
jean.thil wrote:Very strange indeed. The failed assert is the the code that resolves the sketcher. It fails both in a release build and a debug build. Gonna try a full reset of the code.
Yes, the assert is in the solver. May I suggest that you download the file you uploaded to the forum and try again, just in case the file somehow is different?
Can anybody please try to reproduce this crash?
jean.thil
Post by jean.thil »
Further investigation.
If I lock the point in the sketch, I can project the nurbs. It is thus a sketcher solver bug.
(Edit : and yes, it crashes also with the file downloaded from the forum)
BTW, one can't constrain a point to the projection of the nurbs... :oops:
abdullah
Post by abdullah »
jean.thil wrote:Further investigation.
I wait for further confirmation, because I can not make it crash.
I can constraint a point to the projection :
The first constraint is a vertical length between one endpoint of the projected bspline and the center of a circle, the second is a point of projected bspline on circle edge (Point on object)...
