Creating a pocket operation causes FreeCAD to freeze
Re: Creating a pocket operation causes FreeCAD to freeze
Hi svg,
on the 0.17xxx version of FreeCAD is all 2 or 3 days, sometimes more often, a update with some changes. How fast it comes to the repo of your operating system is part of the maintainer of this repo...
I think sliptonic, the guy who's making the most development, is using always a little newer version...
Gruß Herbert
Hello!
I try more settings and see if i select EndMill type of a cutting tool no libarea generated path.
If i select Drill tool i have path only if tool diameter less that radial size of a pocket.
P.S. Can i realize pocket cutting like on this video (see from 1:50 timing)
https://www.youtube.com/watch?v=VU1Vs6A42vI
Hello!herbk wrote:Hi svg,
I'm not programmer and not have compiling skill.
I use only compiled releases downloaded from official GitHub place.
Will wait for resolving problem in newest published releases
While I can't say for sure what version he is using, I would suspect that it is the latest development code. It looks like the window$ version is lagging behind at the moment. Looks like 52 commits behind. Sense these development binaries are compiled by volunteers, it may be a few days until the next build is uploaded. I suspect that new libs are needed to be built for the window$ libpack due to recent changes before a new FreeCAD version can be built. These things are not at all the easiest tasks to accomplish on that OS. The Mac version and as always the Linux versions are up to date if you have a machine with one of those OS's around.svb wrote:What version you use?sliptonic wrote:Like the other, I deleted and recreated operations and was able to get a reasonable path with libarea
revised project file is attached.
Mark
OS: Kubuntu 14.04.4 LTS
Version: 0.17.7797 (Git)
Hash: 1408f0cd0a2912b72839c46877d58e0a24f0240b
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
- sliptonic
I jump between a couple different machines in the house, shop, and at work. This one is built from Master but isn't even very current. I can't stress enough the importance of deleting and recreating your Path project when diagnosing bugs.quick61 wrote:While I can't say for sure what version he is using, I would suspect that it is the latest development code.svb wrote:What version you use?sliptonic wrote:Like the other, I deleted and recreated operations and was able to get a reasonable path with libarea
OS: Linux Mint 17.3 Rosa
Version: 0.17.7732 (Git)
Build type: Unknown
Hash: b574f5497c3101b4984053b219bd4661a5e38178
Qt version: 4.8.6
OCC version: 6.7.0
Yea, Netgen is kicking my ass.quick61 wrote:I suspect that new libs are needed to be built for the window$ libpack
I would note however that there haven't been any PathWB related commits to master since the last build, so we should listen to what Sliptonic is trying to tell us.
sliptonic wrote: I can't stress enough the importance of deleting and recreating your Path project when diagnosing bugs.
"fight the good fight"
I make video for my pocket operation.
No one EndMill tool not produce path. Only 2.5mm Drill tool produce path.
https://www.youtube.com/watch?v=QtaDT3GqWnc
Hi svb,
libarea is to install separately, did you do that?on selection "libarea" algorythm i have nothing
Gruß Herbert
libarea is included in the FreeCad source, and therefore in the dev-builds, since 0.16 release on both Ubuntu and win. OpenCamLib is an unmet dependency that needs to be compiled and installed separately. I think OCL is only needed for surfacing?herbk wrote:libarea is to install separately, did you do that?
thx sprogan,
then i can remove the separat installed package now.
Gruß Herbert
