the new path workflow, my first impresions
Re: the new path workflow, my first impresions
This is a great idea - if you guys have access to the tracker, it would be great to have an issue for it so we won't forget. If not, let me know and I will.
Good morning mlampert,
I have and can do...if you guys have access to the tracker
Gruß Herbert
one question to the entry theme: In this moment "Contour" and "Surface" only works with the part selected in "Job", all other operations works with each part i have on my machinetable.
Do you think about to change the workflow of this other operations that they work also only with the in Job selected part, or should they remain as they are?
Gruß Herbert
- sliptonic
They will eventually change too. This will simplify the code for validating the base object and make the gui cleaner and more consistent. It isn't a big change but affects a lot of operations so I'm holding off until we get our testing strategy nailed down.herbk wrote:Hi,
