Good morning sliptonic,
good morning mlampert,
sliptonic wrote:You don't see any reasons but trust me, they are there.
That i realy trust, no doubt... And if a "old way" to do somethig has too many limits you have to go a "new way", - also no doubt.
I only want to point out early, if, in my mind, some "problems" comming up - and i know that things need time,..
mlampert wrote:Now I realise that we are starting to have two different discussion in this thread
yes, but it comes up because the themes are related...
The question I'm trying to get at here is, is Job, and the fact that it has a Base object which defines the universe for that Job, really a/the problem?
In my mind yes it is a problem, or better it will be one in many cases...
Machining a single Part is only a good workflow if you have a machine like this:
On this type of machine will be done each part at its one.
But much more people, especially private users, are using CNC machines like this:
At this type of machine you mostly froduce more than one part et once. And so the workflow (the workflow on the machine) is totaly different.
You don't workpart after part ... you work tool by tool, because it is the path with the least effort,.. you first drill all holes, than you make all things with tool 1 then all with tool2, and so on...
"Job" offers a dropdown menue for the "job type". in that moment there is only milling to select, but maybe for that two types of machine and it's differnt workflows it is necessary to go two different ways, to create the pathes for, too.
