How to activate openCamLib after compiling it
adamLange
Post by adamLange »
Hello,
After trying to use the surfacing operations in the Path module I learned that openCamLib is required. I cloned the repository: https://github.com/aewallin/opencamlib, built the openCamLibs as according to the README, except I didn't do the install step. If possible, I'd like to keep the library in a unprivileged directory. I expect that FreeCAD is expecting the openCamLib to be in /usr/lib or some standard place.
I tried:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$MY_INSTALLATION_DIRECTORY
before starting FreeCAD and I still get this message in the report view:
This operation requires OpenCamLib to be installed.
Adam
OS: Ubuntu 14.04.5 LTS
Version: 0.17.9453 (Git)
Build type: Unknown
Branch: (detached from 0.16_pre)
Hash: b16fbcd4eeb9a5f9195c500e2693cba25a7916d2
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.1.oce-0.16
adamLange
Re: How to activate openCamLib after compiling it
Post by adamLange »
I think I'm getting closer to the answer. I need to make sure the 'ocl' python module can be imported. This is the code that is generating the error:
Mod/Path/PathScripts/PathSurface.py
    if obj.Algorithm in ['OCL Dropcutter', 'OCL Waterline']:
            try:
                import ocl
            except:
                FreeCAD.Console.PrintError(translate(
                    "PathSurface", "This operation requires OpenCamLib to be installed.\n"))
                return
adamLange
Post by adamLange »
sudo make install makes quick work of this. :)
Problem solved
sgrogan
Post by sgrogan »
I think adding the path to lib would work if you didn't want to install
In the python console
import sys
sys.path.append("...")
You would need to do it after every restart. or start FreeCAD with the -P switch and add the path.
Oh, or put the library in your macros folder, it's already in sys.path.
"fight the good fight"
adamLange
Post by adamLange »
I will keep those in mind. Thanks sgrogan!
luispa
Post by luispa »
I know this is an old thread. I'm having the same issue, I compiled opencamlib and did a make install, this is the output:
Install the project...
-- Install configuration: ""
-- Installing: /usr/lib64/python2.7/site-packages/ocl.so
-- Up-to-date: /usr/lib/python2.7/site-packages
-- Up-to-date: /usr/lib/python2.7/site-packages/pyocl.py
-- Up-to-date: /usr/lib/python2.7/site-packages/camvtk.py
-- Up-to-date: /usr/lib/python2.7/site-packages/procmemory.py
-- Up-to-date: /usr/lib/python2.7/site-packages/STLTools.py
-- Up-to-date: /usr/lib/opencamlib/libocl.so.11.10.73
-- Up-to-date: /usr/include/opencamlib/arc.hpp
-- Up-to-date: /usr/include/opencamlib/bbox.hpp
-- Up-to-date: /usr/include/opencamlib/ccpoint.hpp
-- Up-to-date: /usr/include/opencamlib/clpoint.hpp
-- Up-to-date: /usr/include/opencamlib/line.hpp
-- Up-to-date: /usr/include/opencamlib/path.hpp
-- Up-to-date: /usr/include/opencamlib/stlreader.hpp
-- Up-to-date: /usr/include/opencamlib/stlsurf.hpp
-- Up-to-date: /usr/include/opencamlib/triangle.hpp
-- Up-to-date: /usr/include/opencamlib/point.hpp
-- Up-to-date: /usr/include/opencamlib/ballcutter.hpp
-- Up-to-date: /usr/include/opencamlib/bullcutter.hpp
-- Up-to-date: /usr/include/opencamlib/compositecutter.hpp
-- Up-to-date: /usr/include/opencamlib/conecutter.hpp
-- Up-to-date: /usr/include/opencamlib/cylcutter.hpp
-- Up-to-date: /usr/include/opencamlib/ellipseposition.hpp
-- Up-to-date: /usr/include/opencamlib/millingcutter.hpp
-- Up-to-date: /usr/include/opencamlib/ellipse.hpp
-- Up-to-date: /usr/include/opencamlib/adaptivepathdropcutter.hpp
-- Up-to-date: /usr/include/opencamlib/pathdropcutter.hpp
-- Up-to-date: /usr/include/opencamlib/batchdropcutter.hpp
-- Up-to-date: /usr/include/opencamlib/pointdropcutter.hpp
-- Up-to-date: /usr/include/opencamlib/brent_zero.hpp
-- Up-to-date: /usr/include/opencamlib/kdnode.hpp
-- Up-to-date: /usr/include/opencamlib/kdtree.hpp
-- Up-to-date: /usr/include/opencamlib/numeric.hpp
-- Up-to-date: /usr/include/opencamlib/lineclfilter.hpp
-- Up-to-date: /usr/include/opencamlib/clfilter.hpp
-- Up-to-date: /usr/include/opencamlib/halfedgediagram.hpp
-- Up-to-date: /usr/include/opencamlib/operation.hpp
-- Up-to-date: /usr/include/opencamlib/batchpushcutter.hpp
-- Up-to-date: /usr/include/opencamlib/fiberpushcutter.hpp
-- Up-to-date: /usr/include/opencamlib/fiber.hpp
-- Up-to-date: /usr/include/opencamlib/interval.hpp
-- Up-to-date: /usr/include/opencamlib/waterline.hpp
-- Up-to-date: /usr/include/opencamlib/adaptivewaterline.hpp
-- Up-to-date: /usr/include/opencamlib/weave.hpp
-- Up-to-date: /usr/include/opencamlib/simple_weave.hpp
-- Up-to-date: /usr/include/opencamlib/smart_weave.hpp
-- Up-to-date: /usr/include/opencamlib/weave_typedef.hpp
-- Up-to-date: /usr/include/opencamlib/tsp.hpp
-- Installing: /usr/include/opencamlib/version_string.hpp
However FreeCAD doesn't find Opencamlib:
FreeCAD 0.17, Libs: 0.17R12435 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2017
Path workbench activated
Surfacing Select Mode
base object: Clone
Free Select
Where should be Opencamlib installed in order to be usable by Freecad?
Thank you very much in advance.
- Please verify if the files are in fact to be found under /usr/local/lib, especially the *.so files.
- verify if /usr/local/lib is contained in /etc/ld.so.conf.d/libc.conf
- run ldconfig and try
- run ldconfig /usr/local/lib and try.
luispa
Post by luispa »
Thank you for your reply. Files were installed in /usr/lib.
luispa
Post by luispa »
chrisb wrote: Mon Nov 27, 2017 2:24 pm - Please verify if the files are in fact to be found under /usr/local/lib, especially the *.so files.
I did it but I had no success.
luispa wrote: Wed Dec 06, 2017 5:22 pm I did it but I had no success.
Today I wanterd to get ocl running again and cannot find it anymore in Path WB. Did I miss the removal or is it something with my eyes?
Version: 0.17.12772 (Git)
Build type: None
Hash: c8c9b76f43d2c78c4afb65b756f3f07d626aac85
Qt version: 4.8.6
OCC version: 7.1.0
