Path of pocket with inclined sidewalls
realthunder
Re: Path of pocket with inclined sidewalls
Postby realthunder » Tue Jan 31, 2017 10:18 am
bill wrote:What is the computation time to generate this Path, Mr Thunder?
I dont have Path.Area installed. Could you generate a path for the inverted LOFT Object from the stock block below?
Thanks!
It seems every challenge reveals some bug at the moment. I simply tried with a mirror of the original shape, and it didn't work. The problem is caused by flipped orientation. Anyway, I fixed it, and insert some timing code.
On my Core i5 machine, 10 sections plus pocketing took only 1 second. Path generation time is neglectable.
Screenshot from 2017-01-31 18-16-39.png (369.91 KiB) Viewed 141 times
bill
Postby bill » Sat Feb 04, 2017 7:21 pm
realthunder wrote: ...took only 1 second. Path generation time is neglectable.
Thanks reelthunder!
I think this might work!
Take Two for no three-dee! Finally stumbled across operation that can do so (Custom). Corners can actually be done by conventional End-Mill too.
Comments: fire away!
pleid
Postby pleid » Wed Feb 08, 2017 11:43 am
Hi realthunder,
thanks a lot! That is exactly what I was looking for!
It took me some time to get the compilation running with Ubuntu 16.10 but now it works perfectly.
