Circle Error in Path on Cooling Plate
MikeK
Post by MikeK »
I noticed a circle error when I ran the PATH tool on my Cooling plate pocket profile.
Looks like only one of the circles cuts are correct.
Image attached.
Is this right? Am I doing something wrong, or is this a PATH problem.
Thanks.
Mikek
FET_Cooling_plate.fcstd
project_file
(27.37 KiB) Downloaded 16 times
Screen Shot of issue
Screenshot from 2017-01-26 17-04-29.png (391.78 KiB) Viewed 1202 times
sliptonic
Re: Circle Error in Path on Cooling Plate
Post by sliptonic »
Hard to say. You didn't post your FreeCAD info from the about page but it looks like you're running an old version of Path. (Project disappeared quite a while ago and was replaced with 'Job')
There's currently a bug in the 0.17 version that's causing some bogus path calculations though.
It looks like an old problem in the 0.16 version (the tree is not 0.17), which was fixed some time ago.
MikeK
Post by MikeK »
Yes I am running 0.16 version.
OS: Ubuntu 16.04.1 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Ok I will upgrade to 0.17, is there an ubuntu upgrade? Or do I have to install from source?
Thanks.
MikeK
kkremitzki
Post by kkremitzki »
You can install it by PPA:
sudo add-apt-repository ppa:freecad-maintainers/freecad-daily
sudo apt-get update
sudo apt-get install freecad-daily
This lets you have both versions side-by-side.
kkremitzki wrote:This lets you have both versions side-by-side.
You call the 0.17 version with freecad-daily as opposed to freecad for the 0.16.
