Profile path on an Involute Gear on version 0.17
lassets
Post by lassets »
I have used the Involute Gear part design extruded to 14 mm and had a Gcode of the profile made on version 0.16.
When trying the same on version 0.17, I get some very large circles and odd looking flower arrangement on the paths :)
1. Using Part Design, make 36 teeth mod 2.5 Involute gear.
2. Using Part, extrude to 14 mm.
3. Make Path Job (Extrude as base object) and create a 3mm endmill tool.
4. Select 3mmEndMill.
5. Select Extrude object and do contour or profile on the base object.
Has anyone successfully made a GCode profile of an Involute gear on version 0.17 ?
OS: Ubuntu 16.04.1 LTS
Version: 0.17.9802 (Git)
Build type: None
Hash: bef81531eeb61b31d23b9603364511b76f1f9633
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Thanks,
Lasse
mlampert
Re: Profile path on an Involute Gear on version 0.17
Post by mlampert »
Unfortunately your build is exactly one commit before the fix for that. Profile got broken a while ago and we fixed it yesterday.
lassets
Post by lassets »
:), so if I get the latest tomorrow, the fix will be included ?
Thanks,
Lasse
mlampert
Post by mlampert »
lassets wrote::), so if I get the latest tomorrow, the fix will be included ?
I sure hope so ;)
mlampert
Post by mlampert »
just to make sure I tried it on my local build (don't wanna be responsible for ruining someone's weekend milling):
lassets
Post by lassets »
Excellent, many thanks.
Cant wait to try it out!
Thanks,
Lasse
lassets
Post by lassets »
PERFECT!
It works!
To the Garage!
Many thanks!
Lasse
lassets wrote:PERFECT!
It works!
To the Garage!
Many thanks!
Lasse
Would you mind showing a picture of the result here or in the showcase section of the forum?
