Confirmed. I'm working on a version that uses @realthunder's PathArea for contour and millface and it generates a correct path for this shape. It's not ready to go yet, but it's promising.herbk wrote:
and i have an other thing what seams a little odd...
I want to cut out this profile, but the path generator ignores the cut for the "corners/pockets", it takes only the outline of the basic object.
I want rustlers, cut throats, murderers, and methodists
- sliptonic
Re: I want rustlers, cut throats, murderers, and methodists
Hi sliptonic,
maybe this problem is based on the way i made the baase object. It is a .svg import (made with Libreoffice). If i make on this import boolean operations, some path operations don't work, other do or do partial.
Whats warking partial is:
- geting a drilling path. If i select the wall of the hole i don't get a path, if i select the edge i get a path.
- geting pathes by edges
on both operations path set's the final depth simular to the start depth, bot it is possible to change it manual.
What's working as aspected is geting a "path from face" and "path from contour" if no outline affecting booleans are done.
In my mind some of the problems are based on a foulty solid if i make it the way i do (.svg import and extrude). Some other things are not working on a this way made part to, e.g. selecting a single face. Depending the of the way the face is made, it works or it don't.
Gruß Herbert
- sliptonic
Sounds like the wall is not precisely vertical. I'll need a file to look any closerherbk wrote: Whats warking partial is:
I'm hopeful that a lot of this weirdness will clean up when we're using PathArea more universally.What's working as aspected is geting a "path from face" and "path from contour" if no outline affecting booleans are done.
Hi sliptonic,
the file you can have, of course.
But if you think the problems will be solved with the change to patharea, don't spend much time for it.
- C_6_Traeger_3.fcstd
- (29.56 KiB) Downloaded 48 times
Gruß Herbert
Hi sliptonic,
again a have a part where i can't gt a path for. It's alike the part before and again basicly i made it with LibreOffice an import via .svg.
As i get always only partial pathes, i rebuild the whole thing with FreeAD and tried to get a path...
But the same thing like before: I got always only partial pathes, no matter which operation i use. So it seams, the problem is not based on the imported .svg as i had thought before...
OS: Linux Mint 17.3 Rosa
Version: 0.17.10893 (Git)
Build type: None
Hash: a75a98ef279e9e067abf5cef3a6de6f09fba2c94
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
A other problem i have, if i use the newer FC build: I can't change the tool. If i select my tooltable i can ad new tools and they are there next time i open it, but if i want to change the tool on the toolcontroller.
I think to remember, you wrote somthing about it somewhere, - but i can't find it ...
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
- Traeger_mittelteil.fcstd
- (253.09 KiB) Downloaded 66 times
Gruß Herbert
So it is again a bspline. I think the problem is in the function PathUtils.cleanedges, where I am not sure if the kernel operates correctly.
One without b-splines, just good ole straight lines: on the tiles object, face profile will only create a path for a single face (it is also a torture test for the constraint solver, don't try opening the sketch and adding / moving stuff around if you don't want to stare at an unresponsive screen for 15 minutes afterwards...)
- hexpath.fcstd
- (151.92 KiB) Downloaded 46 times
OS: Ubuntu 16.04.2 LTS
Version: 0.17.11422 (Git)
Build type: None
Hash: a4e0d79e6581ce96b376cbd93e37a811f5dd8df2
Python version: 2.7.12
OCC version: 7.1.0
There's some issues with pocket operation, check the attached file, and image.
I've noticed something strange in the pocket operation. I have several pockets, and used the spiral strategy for the path pocket operation. All pockets seem fine, except for one, that has a strange path inside.
- All of them have 4 mm width, I'm using a tool with 3 mm.
- See the image below
- I'm using freecad-daily version, that is built from the master branch
- Let me know if you need additional information to track whats wrong.
Cheers,
Mario
Build type: None
OCC version: 7.1.0
Cheers,
Mario
- router-sloted-base.fcstd
- (41.26 KiB) Downloaded 60 times
- pocket-operation-2017-06-22 11-42-25.png (24.12 KiB) Viewed 1724 times
snip: not relevent.
Luckily this doesn't belong in this thread, it's just a precision issue. And you can even fix it yourself by setting Preferences->Path->"Default Curve Accuracy" e.g. to 1,0000 µm.
