Thanks and questions ;)
gdo35
Postby gdo35 » Thu Feb 16, 2017 11:12 pm
Hi all !
First thanks to all developpers for that amazing Path module ! :o :o :o :!: :!: :!: :!:
Before my questions, here is the expected result of my first milling :
It is the base of my robot.
I used the very useful sliptonic dogbone dressup which worked fine :
http://www.youtube.com/watch?v=Ix_HfaL0TxU
Just doing a profile from face was so easy... Good job !
But I have 2 questions :
  • How can I make a profile for a XZ or YZ part ?
  • How can I set an offset to avoid my CNC to start from 10mm to 0mm but to start from 0mm to -10mm on Z axis ?
Thanks,
gdo
OS: Ubuntu 16.10
Version: 0.17.10101 (Git)
Build type: None
Hash: 99fa203f323927b0dd027420d4421b577b7420c3
Python version: 2.7.12+
OCC version: 6.8.0.oce-0.17
Re: Thanks and questions ;)
Postby chrisb » Fri Feb 17, 2017 12:11 am
Thank you for sharing, I always like to see real things coming out at the end.
gdo35 wrote: How can I make a profile for a XZ or YZ part ?
Currently I think you have to make a clone and turn it by 90°
You should not work with your machine's absolute coordinates but with workpiece coordinates. If your machine controller cannot handle the latter (which I hardly can imagine) you can adapt the post processor.
triplus
Postby triplus » Fri Feb 17, 2017 12:14 am
Nice to see such projects! Thanks for sharing.
gdo35
Postby gdo35 » Sat Feb 18, 2017 12:53 pm
chrisb wrote:Currently I think you have to make a clone and turn it by 90°
Not very practical but not too difficult either.
chrisb wrote:You should not work with your machine's absolute coordinates but with workpiece coordinates. If your machine controller cannot handle the latter (which I hardly can imagine) you can adapt the post processor.
I work with absolute coordinates in linuxcnc... :( I will check deeper into docs to find if I can work with relative coordinates...
Thanks,
gdo
Postby chrisb » Sun Feb 19, 2017 10:04 am
gdo35 wrote:I work with absolute coordinates in linuxcnc... :( I will check deeper into docs to find if I can work with relative coordinates...
I am sure you can, we had this here recently.
gdo35
Postby gdo35 » Fri Feb 24, 2017 9:51 am
Thanks for your reply.
This topic is too general and I will open a more specific one on each problem.
chrisb, thx for help, I found some clues with G10 L2/L20 instructions. I have to test this.
gdo
Postby chrisb » Fri Feb 24, 2017 10:12 am
gdo35 wrote:Thanks for your reply.
gdo
You're welcome, I think it is rather the G54 - G59 series of GCodes where you can define different coordinate systems
