Default tool disappear in library
gdo35
Postby gdo35 » Mon Feb 27, 2017 10:48 am
If I create a job and if I want to change default tool diameter, the default tool disappear.
In attachment the .fcstd file.
I'm working with nightly build :
OS: Ubuntu 16.10
Version: 0.17.10276 (Git)
Build type: None
Hash: 10191e90861cf0c87d24c1980761fd1c7f3cdde4
Python version: 2.7.12+
OCC version: 6.8.0.oce-0.17
Thx for help,
gdo
test.fcstd
(133.32 KiB) Downloaded 4 times
herbk
Re: Default tool disappear in library
Postby herbk » Mon Feb 27, 2017 3:46 pm
Hi gdo,
here it works...
make the steps:
open the tooltable
change from main to job
click on "new tool" and addit the tool you want
after clicking OK on the tool editor you will not see the tool
add an other tool if you want, you will not see it, to.
click on "main" and click again on "job", - the tols will appear now.
OS: "openSUSE Leap 42.2"
Version: 0.17.10236 (Git) (Packman)
Hash: dd20ba3d068c4a0903417d93144f8ac7fed068e9
Qt version: 4.8.6
OCC version: 6.9.1.oce-0.18-dev
test.fcstd
(133.33 KiB) Downloaded 5 times
Gruß Herbert
gdo35
Postby gdo35 » Mon Feb 27, 2017 3:53 pm
Thx, I will try that workaround.
It seems it is "just" a display bug then.
gdo
