i'm not able to test the new things, because on OpenSuse the 0.17 is not higher than 10236.
What Gene is writing about the order of the createt pathes, i understand as the problem i try to point out a little bit after changing to "job".
viewtopic.php?f=15&t=18148
It's nearly the same way i work..: make a path for one operation, copy the gcode to a .txt file, make the path for next operation copy it to the .txt file, and so on...I simply make the changes, output the g-code, *don't* save the file, close, reopen, make more changes, output more g-code, etc
I advise: gene is working with a router, where usually more then one peace will be cutted out at once...As an example of the latter, it may be more time efficient and less error prone to use the same tool and same operation on multiple pieces before changing and rezeroing a manual tool to continue work on the original workpiece.
