Solving problems with linux_cnc post with wrong feed rate
dlhenke
Post by dlhenke »
I have to patch my source in order to get linux_cnc post working ..
Line 137 of src/Mod/Path/PathScripts/linuxcnc_post.py
if pathobj.MachineUnits == "Metric":
UNITS = "G21"
UNIT_FORMAT = 'mm/s'
else:
UNITS = "G20"
UNIT_FORMAT = 'in/min'
Now is working ..
thanks a lot
vk3uao
Re: Solving problems with linux_cnc post with wrong feed rate
Post by vk3uao »
Thankyou
dlhenke
Post by dlhenke »
Sorry i did a mistake..
the solution is in the line 64 of linuxcnc_post.py
change it to
because pathobject is not working
dlhenke
Post by dlhenke »
File "<string>", line 4, in <module>
<type 'exceptions.RuntimeError'>: 'FeaturePython' object has no attribute 'MachineName'
gdo35
Post by gdo35 »
Got the same problem, thank you for pointing this.
I correct it and propose a pull request on github.
gdo35
Post by gdo35 »
dlhenke
Post by dlhenke »
gdo35 wrote:Done : Pull resquest #658
Ok thank you but i think that the problem is not there, something is wrong with path object because it does not have the objects :-)
gdo35
Post by gdo35 »
It solves the problem for me.
Which version do you have ?
(Help->About FreeCAD, click on the "Copy to clipboard" button and paste here.)
dlhenke
Post by dlhenke »
gdo35 wrote:It solves the problem for me.
OS: Mac OS X
Version: 0.17.10656 (Git)
Hash: 7741f74ae6f824776ab5620cc6da6e206815f298
Python version: 2.7.13
Qt version: 5.6.2
OCC version: 7.1.0
Also the same problem on My Elementary Linux ( Loki )
gdo35
Post by gdo35 »
And did you use an old .fcstd file ?
Could you share it ?
I cant reproduce. :(
