Is an increase of precision possible?
I have an object with an end of an arc at (145,3,someZ). When I create a path on the corresponding line I get (145,2.999). I checked with "Inspect GCode" it shows
X145.000000 Y2.999000
It seems as if the internal representation is taken and cut (not rounded) to a precision of 3 decimals with a subsequent extension to 6. Can I change the behaviour to either use the value from FreeCAD or use at least 4 digits precision?
mlampert
Re: Is an increase of precision possible?
Post by mlampert »
chrisb wrote:I have an object with an end of an arc at (145,3,someZ). When I create a path on the corresponding line I get (145,2.999). I checked with "Inspect GCode" it shows
Last time I looked into that code there was no restriction to 3 decimals - if that has changed then we should probably fix it. If you have a fix, please go ahead and create a PR - otherwise creating an issue would be great.
My plan is to get into the Git stuff during this week. Then I will give it a try to find and eliminate the bug. If I don't succeed I will create a ticket.
