For a symmetric object based on primitives, is it possible to directly generate gcode for a 3d-printer without generating a mesh?
In principle gcode seems to based on moving the printer head. So, would not these movements be more accurately and efficiently generated from a parametric description of the surfaces, rather than a 3d mesh?
Would it be possible to translate gcode developed on the Path/CAM workbench to gcode for a 3d Printer?
Thank you very much for your help and comments.
gcode from primitives
Re: gcode from primitives
This is possible with a special post processor.deburgess wrote: Would it be possible to translate gcode developed on the Path/CAM workbench to gcode for a 3d Printer?
However there might be two drawbacks:
1.) I am not sure if the printers really understand the G2 and G3 commands, e.g. none of the example files that came with my printer uses it, and one of the examples is a tube made of circles only! So where should it be used if not there?
2.) You have to create paths with a really minimal stepdown. It has to be investigated if FreeCAD still performs with acceptable speed.
Marlin suports G2/G3 movement http://marlinfw.org/docs/gcode/G02.html Also Slic3r supports G2/G31.) I am not sure if the printers really understand the G2 and G3 commands
I guess the problem is that the .stl are flat faces,so the are no curves involved
