That seems like a good plan to me.yorik wrote:Another idea I have: Instead of creating one more workbench, why not add the drawing_dimensioning functionality to Drawing? It's not too much work, we can even leave the module organized as it is (on y the module, no new workbench), and just add the tools in Drawing... This way, the day TechDraw is fully mature, we can retire both Drawing and drawing_dimensioning...
Merging drawing_dimensioning into v0.17, help wanted
Re: Merging drawing_dimensioning into v0.17, help wanted
I feel that deciding if merging drawing_dimensioning into v0.17 makes sense or not is easier decision. Harder decision is deciding if there should be 2 Drawing related modules available in FreeCAD 0.17 or not.
I agree 100% Yorik.
I will create an issue on Github as to contact the 5 contributors now about changing licence to LGPL2+.
It also makes alot of sense combine the drawing and drawing dimensioning workbenches.
Might be challenging though, given that one is Python and one is C++.
Agreed.triplus wrote:I feel that deciding if merging drawing_dimensioning into v0.17 makes sense or not is easier decision. Harder decision is deciding if there should be 2 Drawing related modules available in FreeCAD 0.17 or not.
Request to have the drawing_dimensioning licence changed:
https://github.com/hamish2014/FreeCAD_d ... /issues/99
- wandererfan
Somewhere on my TechDraw list of things to do is "salvage neat bits of Hamish's wb?". Now, that is said from a position of ignorance since I've only used DrawingDimension once or twice.hamish wrote:It also makes alot of sense combine the drawing and drawing dimensioning workbenches.
I assume DrawingDimension works by adding chunks of Svg to Page.ViewResult? There is the DrawViewSymbol feature of TechDraw that will display Svg on the screen. It is the basis for the DrawViewDraft function. We call Draft Module python code from C++ to create the view.
I'd be happy to see somebody take a look at this, since I won't get to it for a while.
wf
As it looks like 2 drawing related workbenches will be part of FreeCAD 0.17:
Would something like importing Python module and setting up toolbars/commands in InitGui.py suffice? I guess if it would be as easy as that it would be explored in the past already.
This indeed would most likely be interesting to tackle. That is on how to combine current C++ Drawing WB with i guess a Python module having Drawing WB related commands in it.hamish wrote:It also makes alot of sense combine the drawing and drawing dimensioning workbenches.
The great news is that the licence for drawing_dimensioning has now been changed to LGPL-2.1.wandererfan wrote: Somewhere on my TechDraw list of things to do is "salvage neat bits of Hamish's wb?".
So please help yourself to any neat bits
FreeCAD allready has a wb in which python tools an C++ tools coexist side by side. FEM wb is developed in C++ and python.triplus wrote:As it looks like 2 drawing related workbenches will be part of FreeCAD 0.17:
I see. Therefore if my understanding is correct:bernd wrote:FreeCAD allready has a wb in which python tools an C++ tools coexist side by side. FEM wb is developed in C++ and python.
Drawing WB and TechDraw are not the same under the hood. Drawing Dimensioning module works good with Drawing WB. Down to parametric dimensions. Combining this two could be a good fit and likely the combination should be enabled side-by-side with TechDraw in FreeCAD 0.17?
