STEP reader improvement (Pass 2)
- vejmarie
Just opened this PR https://github.com/FreeCAD/FreeCAD/pull/465
to fix this reported issue viewtopic.php?p=154559#p154537
- vejmarie
Re: STEP reader improvement (Pass 2)
I had to cancel it. One of my reference STEP file doesn't open properly with this update unfortunatly.vejmarie wrote:Just opened this PR https://github.com/FreeCAD/FreeCAD/pull/465
- vejmarie
I fixed the issue and reopen a new PR
https://github.com/FreeCAD/FreeCAD/pull/466
Great!vejmarie wrote:I fixed the issue and reopen a new PR
looking forward to test it (I need to wait for a fresh windows build, maybe also with the new multi-thread reader ...)
thx
Maurice
Hi @vejmarievejmarie wrote:I fixed the issue and reopen a new PR
I managed to build it on ubuntu 16.04 and it works!
Great improvement the assembly structure is conserved (assembly & sub-assembly) ...
What I miss now are the colors...
would it be possible to add colors to the importer?
thx again for your valuable work!
Maurice
- vejmarie
Hi Maurice, the Colors are still there. This is because with the new PR I made, the Compound are a single Shape and I didn't transfer the color from the faces. One part of my strategy is to activate only sub elements from the Compound instead of the Compound (aka the leaf the tree instead of the nodes and roots). Assembly element have there colors. So if you disable the root nodes, and enable the leafs you will see the colors there. I like to make it first the way I describe, and if this is too disturbing for end users I will copy the color from the subelement to the Compound shapes. I like the idea to have in grey elements you can't change, and in color things which are coming from the root file.easyw-fc wrote:Hi @vejmarievejmarie wrote:I fixed the issue and reopen a new PR
Maurice
vejmarie
that is a strange behavior compared to other CAD sw ... CADAssistance or DesignSpark Mechanical just load the STEP assembly and display colors as they are; I have some feedback that Catia, SolidWorks and NT do the same... I don't know about ProE...vejmarie wrote: Hi Maurice, the Colors are still there. This is because with the new PR I made, the Compound are a single Shape and I didn't transfer the color from the faces. One part of my strategy is to activate only sub elements from the Compound instead of the Compound (aka the leaf the tree instead of the nodes and roots). Assembly element have there colors. So if you disable the root nodes, and enable the leafs you will see the colors there.
If possible I would suggest to keep the colors or eventually add a check box in Pard Design settings to enable or not this feature...vejmarie wrote: I like to make it first the way I describe, and if this is too disturbing for end users I will copy the color from the subelement to the Compound shapes. I like the idea to have in grey elements you can't change, and in color things which are coming from the root file.
vejmarie
what do you think?
thx
Maurice
Pro show also their colorseasyw-fc wrote:I don't know about ProE...
- vejmarie
This will require a Pass 3 of the reader, but this shall be doable . Let's see the positive thing we are progressing.
Great!vejmarie wrote:This will require a Pass 3 of the reader, but this shall be doable .
I'm not underestimating your contribution...vejmarie wrote:Let's see the positive thing we are progressing.
I was waiting for a STEP hierarchy parser since my first approach to FC (0.14 release I think...), and I suppose I'm not the only one!
... so I really appreciate these improvements
and there is also multi-threading in STEP reading
Thx
Maurice
