Frequency analysis
Re: Frequency analysis
Hello Serchu, again.
Please see my other post. viewtopic.php?f=4&p=98825#p98825
This frequency analysis is in developement. It is not available in the windows snapshots or the Ubuntu PPA to test you need to compile PrzemoF's private github branch.
I can try to post some Windows builds later today if your interested. Let me know here.
"fight the good fight"
Dear Sgrogan, I'm very interesting in following the new characterisitics of the FEA module, if you can compile a Windows64 version every so on I will be very happy and serve you as tester.
Engineering Consultor at 4P Ingeniería
http://www.4p-ingenieria.com/
https://www.youtube.com/channel/UClZPfO ... Cx-_J36o_Q
I'm also a tester, not a developer. My "service" is to do some testing and offer my insights, sometimes brilliant , sometimes irrelevant.Serchu wrote:Dear Sgrogan, I'm very interesting in following the new characteristics of the FEM module, if you can compile a Windows64 version every so on I will be very happy and serve you as tester.
Some Win builds for this branch can be found here:https://www.dropbox.com/sh/b2f3if41iww2 ... wpdba?dl=0
Oke how do i check which frequencies the mode shapes are??
I just started with a basic 4 times clamed square plate (200x200x2 mm) and only force normal pressure
According to my calculations the first six modeshapes are arround [437.46 892.31 892.31 1316.40 1599.61 1606.91] hz
I can't find that anywhere...
- Test_fem.tar.gz
- (858.17 KiB) Downloaded 68 times
Open .dat file in the calculation directory - the info you're looking for is there. FreeCAD is not importing it yet.
Don't see it
txt file is the dat file
- Part__Feature_Mesh_dat.txt
- (167.85 KiB) Downloaded 51 times
You didn't run frequency analysis, just normal static analysis. Can you send your FreeCAD version info?
The .dat file is too big to post it, but that's what I got for your model:
E I G E N V A L U E O U T P U T
MODE NO EIGENVALUE FREQUENCY
REAL PART IMAGINARY PART
(RAD/TIME) (CYCLES/TIME (RAD/TIME)
1 0.9214515E+07 0.3035542E+04 0.4831215E+03 0.0000000E+00
2 0.4324221E+08 0.6575881E+04 0.1046584E+04 0.0000000E+00
3 0.4524652E+08 0.6726553E+04 0.1070564E+04 0.0000000E+00
4 0.1116733E+09 0.1056756E+05 0.1681879E+04 0.0000000E+00
5 0.1752228E+09 0.1323717E+05 0.2106762E+04 0.0000000E+00
6 0.1775699E+09 0.1332554E+05 0.2120825E+04 0.0000000E+00
7 0.2977666E+09 0.1725592E+05 0.2746364E+04 0.0000000E+00
8 0.3142493E+09 0.1772708E+05 0.2821352E+04 0.0000000E+00
9 0.5699248E+09 0.2387310E+05 0.3799521E+04 0.0000000E+00
10 0.6258365E+09 0.2501673E+05 0.3981535E+04 0.0000000E+00
P A R T I C I P A T I O N F A C T O R S
MODE NO. X-COMPONENT Y-COMPONENT Z-COMPONENT X-ROTATION Y-ROTATION Z-ROTATION
1 -0.1101798E-07 -0.1483187E-06 0.1714749E-01 -0.7070093E-01 -0.2341264E-03 -0.4660632E-06
2 -0.1451572E-06 0.2344101E-06 -0.9910787E-04 -0.5645843E+00 -0.5053591E+00 0.1455623E-05
3 0.2309252E-06 0.1364810E-06 0.1752227E-03 0.5145110E+00 -0.5599058E+00 -0.3254505E-05
4 0.6308117E-06 -0.5468559E-07 0.2221658E-03 -0.3193214E-02 -0.2470342E-02 0.1543172E-04
5 0.1177178E-06 0.4889221E-06 -0.9959675E-02 0.4128305E-01 -0.2435800E-01 0.6536849E-06
6 -0.7556868E-07 -0.3165870E-07 -0.4837509E-03 -0.1205624E-01 0.5071206E-02 -0.1258939E-04
7 0.5082467E-07 0.3517168E-06 0.1182215E-03 0.4717605E-01 -0.3008922E+00 0.2818943E-04
8 0.5943400E-06 -0.5377066E-06 0.1007970E-03 0.2957567E+00 0.7785357E-01 -0.7355986E-06
9 -0.3385725E-06 0.2533214E-06 0.8146686E-03 -0.2277752E+00 -0.3590970E+00 -0.1507993E-04
10 -0.1200800E-06 0.1962584E-07 -0.1195887E-02 -0.3538898E+00 0.2357888E+00 -0.8678511E-05
E F F E C T I V E M O D A L M A S S
1 0.1213958E-15 0.2199843E-13 0.2940364E-03 0.4998621E-02 0.5481517E-07 0.2172149E-12
2 0.2107060E-13 0.5494811E-13 0.9822370E-08 0.3187555E+00 0.2553878E+00 0.2118839E-11
3 0.5332645E-13 0.1862707E-13 0.3070300E-07 0.2647215E+00 0.3134945E+00 0.1059181E-10
4 0.3979234E-12 0.2990514E-14 0.4935766E-07 0.1019662E-04 0.6102592E-05 0.2381380E-09
5 0.1385748E-13 0.2390448E-12 0.9919513E-04 0.1704290E-02 0.5933124E-03 0.4273040E-12
6 0.5710625E-14 0.1002273E-14 0.2340149E-06 0.1453530E-03 0.2571713E-04 0.1584928E-09
7 0.2583147E-14 0.1237047E-12 0.1397632E-07 0.2225580E-02 0.9053613E-01 0.7946440E-09
8 0.3532401E-12 0.2891284E-12 0.1016003E-07 0.8747205E-01 0.6061178E-02 0.5411053E-12
9 0.1146314E-12 0.6417172E-13 0.6636849E-06 0.5188155E-01 0.1289507E+00 0.2274041E-09
10 0.1441921E-13 0.3851735E-15 0.1430145E-05 0.1252380E+00 0.5559636E-01 0.7531656E-10
TOTAL 0.9768837E-12 0.8160013E-12 0.3956734E-03 0.8571526E+00 0.8506518E+00 0.1507892E-08
T O T A L E F F E C T I V E M A S S
0.5835370E-03 0.5835370E-03 0.5835370E-03 0.1793014E+01 0.1783589E+01 0.3575053E+01
E I G E N V A L U E N U M B E R 1
displacements (vx,vy,vz) for set NALL and time 0.1000000E+01
1 0.000000E+00 0.000000E+00 0.000000E+00
2 0.000000E+00 0.000000E+00 0.000000E+00
3 0.000000E+00 0.000000E+00 0.000000E+00
4 0.000000E+00 0.000000E+00 0.000000E+00
5 0.000000E+00 0.000000E+00 0.000000E+00
6 0.000000E+00 0.000000E+00 0.000000E+00
OS: Ubuntu 15.04
Version: 0.16.Unknown
Build type: Unknown
Python version: 2.7.9
Qt version: 4.8.6
As far as i can see know it didn't use my normal place... but can't find out(yet) where he put's the data...
Build type: Unknown
Qt version: 4.8.6
Set a directory in FEM Preferences. Did you compile FreeCAD yourself or it's a build by sgrogan?
Right now the frequency analysis is only in my github frequency branch:
OS: Linux
Version: 0.16.5423 (Git)
Build type: Unknown
Branch: frequency
Hash: 4946043643372d8a00f7a1dd625171661a86ff69
Python version: 2.7.8
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.7.1.oce-0.16
OS: Linux
Build type: Unknown
Branch: frequency
Qt version: 4.8.6
Coin version: 3.1.3
