Eigenmode frequency always 0?
Founder
Re: Eigenmode frequency always 0?
Post by wmayer »
obj.addProperty("App::PropertyString", "SolverType", "Base", "Type of the solver", 0, True)
or
obj.addProperty("App::PropertyString", "SolverType", "Base", "Type of the solver", 1)
bernd
Post by bernd »
Thanks werner, PullRequest: viewtopic.php?f=17&t=13756
prrvchr
Post by prrvchr »
wmayer wrote:
When loading a project an object's __init__ function won't be called but its __setstate__ function is called instead. So, it should work to call
self.Object.setEditorMode("MyProperty", 1)
I do not understand because:
self.Object = vobj.Object
must be done in the attach() method of ViewObject (without self.Object is a missing attribute)
When loading from file it seem that __setstate__ () is executed before attach() !!!
I may be missing something...
Son
Post by Son »
wmayer wrote:
or
I played around with this :D and found that if you want the property hidden, set the last argument to -1 (not 2 like setEditorMode)
x1 = 2.0*App.Units.Inch
groupLabel = "Point 1"
toolTip = "X coordinate of point 1"
obj.addProperty("App::PropertyLength", "X1", groupLabel, toolTip, -1).X1 = x1
